    GT production update January 14/ 2022
    167
    92651
      @lia Very clean inside. I made some crude measurements of the motor width and it looks promising for the XR rotor exchange. There's a bit of variation in my measurements, but that may be due to the different contours of the hubs.
      I will pull the motor apart after riding the GT a bit to make sure there are no warranty problems. I have a Xr rotor with a fresh Hoosier ready to swap over.
      Lia B 3 Replies Last reply Reply Quote 6
        @lemur Nice one taking those measurements. The hub plates will probably differ in depth, the Pint and XR ones are pretty different.
        Hope you have a good ride out. No rush to swap that hub since it sounds like these stock tires are built to last.
          biell DIY @Lemur last edited by
          @lemur I am very interested in your findings. When you do, can you also check to see if the GT motor plate fits on the XR/Plus Hub?
            @lemur XR is faster than GT on Apex confirmed! click for video.
              @lia said in GT production update January 14/ 2022:
              hopium
              we all know Leary's a skeptic. here's his opinion. talks about battery.
                @notsure Still going to wait and base my opinions on what I get before watching these vids. I don't do tricks and speed isn't a concern for me so will see how I feel it rides really.
                I expect it to ride differently but between weight, ride modes not being alike and the footpads altered I expect a lot of people won't truly lock in with it initially. Might explain a lot of the "wobbly" comments I've been seeing. I mean if anyone's gonna complain if it's wobbly it'll be me lol.
                On another note I've been seeing a lot of ghosting posts crop up so might be worth tying a lead to the board in case it spots a squirrel as you dismount ;)
                  @lia I'm the same kind of rider . . . just carving around 17 mph, mostly pavement and hard packed dirt and gravel, no tricks. Been riding the Pint X for a few days now and it definitely feels wobbly compared to my XR and I have a treaded Hoosier on instead of the round tire it came with. I really don't mind it TOO much and I'm starting to get used to keeping the speed under 15 mph with the aggressive pushback in the upper 16+ mph range. It's still fun, but not AS fun as my XR. Sounds like the GT will have more power/torque than the XR along with the carvey/wobbliness of the Pints. I'm a bit (ok, a lot) heavier than you at 185+ lbs, so hoping I can squish down the tire a bit so it's not as round, yet still get the 20+ mile range Jake's buddy in the video is getting (he's about the same weight as I am).
                  I can't help but watch the Float Life videos as I live right there and they're riding the GT on the EXACT paths that I ride (so fun to watch) . . . albeit, way more technically than me and hitting bumps and curbs that I simply go around!
                    @onedangt Agreed, Pint is very wobbly compared to the XR. First spin was laps on my carpet and although I appreciated the tighter turning circle it was quite the board to control.
                    With the range assuming Jake wasn't ripping hard on and offroad I wonder how FM got the 32mile number. Think once I get mine I'll be seeing if I can crush out 32miles on my usual "cruise" route that's not super brutal to give me the best chance of replicating some decent range.
                    I haven't weighed myself in years but last I checked I was 57kg (126lbs) but I've definitely put on some weight since then so probably a bit more since then. Totally muscle though... totally... >.>
                    Gotta see you do some laps on those trails then, see if you can line up your laps with theirs to see how you compare :D
                    OneDanGTS-XL 1 Reply Last reply Reply Quote 4
                      Now THAT would be embarrassing!
                        @lemur Bob Nicholson has taken apart their GT and attempted an XR hub transplant only to find FM have indeed modified the stator... not for performance but seemingly just to not work.
                        Don't have the link to the video but Duhherroooo posted a screenshot on reddit.
                        Bob Nicholson took apart the motor live. The magnets and bearings are the exact same size in the GT as XR and Pint. The only difference that doesnt allow it to work is the lip on the axle has been extended by around 1mm (where I circled) causing the motor lid to not fit
                        Now.... in theory if the lip is just extended by 1mm you could in theory slap it in a lathe and take that 1mm off but... not sure many of us have a big ass lathe laying around to turn that D:
                          @lia Just watching the live stream too. Doesn't look good. I have a lathe large enough, but may be a one way procedure.
                            @lemur True, using a spacer to revert could work but might also come with it's own issues.
                            I'm sure some crazy floater will do it further down the line where parts are easier to come by.
                              @lia Wait and see for now, looks like something happened to his Gt, it started flashing red and the video feed cut out.
                              Lia 2 Replies Last reply Reply Quote 2
                                @lemur Oh damn that doesn't sound good. Hope everything is okay.
                                I assume this livestream was on FB?
                                  @lemur Just been informed disconnecting the BMS bricks it!
                                  Edit: Confirmation
                                    Edit: Confirmation
                                    oh shit that's fucked now! thats really bad news... i'm guessing a cr2032 won't quite do it either. servicing just got way trickier.
                                      Lemur @NotSure last edited by Lemur
                                      @notsure Maybe there is a procedure or "keep alive" dongle that keeps the controller/bms alive during servicing?
                                        @lemur Maybe, I wonder if they pop the MR30 connector for the charge port off and conenct into that to retain power or connect up to the test pads somehow.
                                        At worst I guess they just deal with it and re-flash it during re-assembly.
                                          No overreacting but heads up with the first make GT's!
                                          https://www.youtube.com/watch?v=zr_5G4nboUg&ab_channel=FloatCarveRide
                                          This would be just another brief ghosting video if not to remark this part of OP comment:
                                          " - ... the GT did roll several times and once it landed right side up the motor did not disengage and it continued to take off as you can see in the footage. ... - "
                                            @sirgu Damn! With that kinda power and accelleration who knows what will happen in traffic!!
