    GT production update January 14/ 2022
    167
    91506
      @lia said in GT production update January 14/ 2022:
      Gotta see you do some laps on those trails then, see if you can line up your laps with theirs to see how you compare
      Now THAT would be embarrassing!
        @lemur Bob Nicholson has taken apart their GT and attempted an XR hub transplant only to find FM have indeed modified the stator... not for performance but seemingly just to not work.
        Don't have the link to the video but Duhherroooo posted a screenshot on reddit.
        Bob Nicholson took apart the motor live. The magnets and bearings are the exact same size in the GT as XR and Pint. The only difference that doesnt allow it to work is the lip on the axle has been extended by around 1mm (where I circled) causing the motor lid to not fit
        Now.... in theory if the lip is just extended by 1mm you could in theory slap it in a lathe and take that 1mm off but... not sure many of us have a big ass lathe laying around to turn that D:
          @lia Just watching the live stream too. Doesn't look good. I have a lathe large enough, but may be a one way procedure.
            @lemur True, using a spacer to revert could work but might also come with it's own issues.
            I'm sure some crazy floater will do it further down the line where parts are easier to come by.
              @lia Wait and see for now, looks like something happened to his Gt, it started flashing red and the video feed cut out.
              Lia 2 Replies Last reply Reply Quote 2
                @lemur Oh damn that doesn't sound good. Hope everything is okay.
                I assume this livestream was on FB?
                  @lemur Just been informed disconnecting the BMS bricks it!
                  Edit: Confirmation
                    Edit: Confirmation
                    oh shit that's fucked now! thats really bad news... i'm guessing a cr2032 won't quite do it either. servicing just got way trickier.
                      Lemur @NotSure last edited by Lemur
                      @notsure Maybe there is a procedure or "keep alive" dongle that keeps the controller/bms alive during servicing?
                        @lemur Maybe, I wonder if they pop the MR30 connector for the charge port off and conenct into that to retain power or connect up to the test pads somehow.
                        At worst I guess they just deal with it and re-flash it during re-assembly.
                          No overreacting but heads up with the first make GT's!
                          https://www.youtube.com/watch?v=zr_5G4nboUg&ab_channel=FloatCarveRide
                          This would be just another brief ghosting video if not to remark this part of OP comment:
                          " - ... the GT did roll several times and once it landed right side up the motor did not disengage and it continued to take off as you can see in the footage. ... - "
                            @sirgu Damn! With that kinda power and accelleration who knows what will happen in traffic!!
                              Sirgu XR last edited by Sirgu
                              Lots of GT ghostings get registered in FB these days. Surely, gotta stay critical in context. As some might be just bummering for fun. But guess yourself:
                              To put that in comparision -- really feels like this (seemingly less tested) concave front pad has some disagreement with 33°F [~0°C] conditions down to material wise. As this seems to be common line with all somewhat reasonable posts.
                              -> Surely the thrill is overwhealming out of the box .. but with all those stated experiences now .. I'd suggest bringing this thing to a first ride out in a wild priorly. For multiple times AND variable conditions. Before ever ... EVER .. ride it in urban structures.
                              EDIT: By the time I finished this forum post of mine "8 comments" turned into 51 comments @FB.
                                @sirgu What… damn that is terrifying!
                                I feel like FM managed to anger the production gods. In making a board harder to repair to save their image on faulty mods they in turn created a single wheeled reincarnation of Christine thats evidently out for blood.
                                I joked to Float Carve Ride I’ll be keeping mine on a lead but I think I might now.
                                In the cases I’ve seen or heard of these have been irregular dismounts. Float Carve Ride did a quickstop and Zack here fell off while it was moving. It sounds like the only way to really prevent this is a standard heel/toe lift to force it to disengage before the tail drops. That being said it won’t do anything for Zack’s case nor is it acceptable to fear a runaway board.
                                Sirgu L 2 Replies Last reply Reply Quote 3
                                  Sirgu XR @Lia last edited by
                                  @lia said :
                                  ... a single wheeled reincarnation of Christine thats evidently out for blood.
                                  LOL, I don't get that reference.
                                  But yeah,
                                  ... I haven't spotted anyone to claim failed heel-lift dismount attempt so far. (Which is the remaining favour to front concave pad & sensors not to be the case of particular ghosting issue.)
                                  I'd really loved to see some GT owner to do the test as following:
                                  1.) Go for a steady LONG ride in equal/below 33°F/0°C temps.
                                  2.) With stubborn cramped ankles ride straight off the 5+miles/8+km WITHOUT ever heel-lifting / off-dropping / dismounting of any kind.
                                  3.) Then moderately breaking down to 0 mph/kmh and attempt heel-lift straight on spot.
                                  -If the reaction "wtf?!..it's not dismounting!" is not present, then the front pad & pressure-sensors will be forgiven really.
                                  Thus leading us to the guess, the demon lies in board electronics, accelerometer etc ... because, yes, all of them have been irregular dismounts / power-stops (with board roughly angeled while tire momentary wheelslippin' on the ground).
                                    @sirgu said in GT production update January 14/ 2022:
                                    Film about a car that's possessed and hunts people.
                                    I feel the ghosting is much like when someone fails a griptape change and causes at least one sensor to stick active. Guessing in the cold the pad might shrink a little and keep a side active because it doesn't deform back as quick.
                                    It could also be due to the new sensors, which if that's the case is pretty bad considering similar sensors have been used in the DIY scene without much issue even on kush and concave pads.
                                      @lia and @Sirgu It is a film to be sure, but to internalize the horror of it all, it is helpful to know the film is based on a Stephen King book of the same name.
                                        @lia Possible problem with GT hall senor wires.
                                        While I had the Gt stator removed to do the XR rim conversion, I noticed the hall sensor wires are really close to the end plate, which is part of the wheel and spins, possibly damaging them.
                                        Compared to the XR stator the hall wires are sheathed and glued down, very poor workmanship on the GT.
                                        I tied mine down with braided fishing line and super glued the knot.stator 2.png stator 3.png stator.png stator 4.png
                                          @lemur That's a little concerning. I wonder if that was an assembly error or the process changed and this is the "new normal".
                                            @lia holy shit! do NOT posi ur GT!
                                            https://www.reddit.com/r/onewheel/comments/tf3z5k/gt_ghosts_at_top_speed_and_nearly_takes_out_a/?utm_source=share&utm_medium=web2x&context=3
                                            M Lia 2 Replies Last reply Reply Quote 1
