    GT Rebuild
    gt rebuild superflux floatblocks
    42
    16030
      So there I was, finally go the floatblocks adjusted to size (A witch never reveals her secrets)
      I used a 35mm hole saw with a printed guide to perfectly centre it and save off 0.1mm off the walls
      Barely a hair over 0.1mm difference between the printed guide and the outer edge of the blade. Then after you bottom out the print you remove the adapter and use the existing cut hole to guide the saw the rest of the depth.
      It was a success... ful failure!
      It now fits but unknown to me until now was the Superflux axle length and the Stock axle lengths are different. Why? No idea but that was a waste of time and $125. I'll find a use for those blocks one day, maybe if I get a stock GT motor I can reclaim the superflux for another board.
      So tossing that to the side I'm probably going to get a set of these fabricated. My CNC isn't running yet but I sort of have other things I want to be doing atm so ordering these will save me time.
      https://www.thingiverse.com/thing:6078798/files
        In the meantime I've printed those new blocks to test them prior to getting a quote for some CNC'd from 6061.
        Desperately needs a splash of colour but till it's working I don't want to style it any further.
        OneDanGTS-XL TheAdman NotSure 3 Replies Last reply Reply Quote 5
          @lia Slush gonna be jealous!
          • TheAdman
            @lia that looks great in black tbf
            Smiles per hour.
              @onedangts Oh she is. Last night after taking this pic I went to take her off the dirty mat from a wet/muddy ride earlier in the week. Snagged somehow on the tire and just littered my floor in dirt >.>
                @lia Thats a GT?! i want those rails!
                  @notsure TFL Steep and Deep rails ^-^
                  They were dead cheap on the black friday sale. There are different versions that probably ride different but I let my purse decide for me 😅 Below are the differences.
                    @lia how steep is that in degrees please?
                    nm i used some internet
                      Anyone had any luck with re-calibrating a GT using FixMyPEV's tutorial?
                      https://www.fixmypev.com/diy/onewheel/gt/calibrate/
                      I'm getting stuck on just connecting via the webpage in Webler 😭 Sent them a email but had nothing back so I assume they're busy.
                        @lia Iphone Webler hasn't worked or months now.
                        You have to use FFM on the "live" tab on a Windows laptop and I think Android works too.
                        Do you have FFM ?
                        If you do the calibration and pairing , level the board, the board may time out and shut off, so it may take a few tries.
                          @lemur Oh I never even tried Windows or Android since it said incompatible. Should have seen the little asterisk 😅 Will give it a shot in the morning after I dig out an old android device.
                          B 1 Reply Last reply Reply Quote 0
                            @lia I use nRF Connect along with the original instructions on Android and have had success re-leveling the board. I never disconnected the battery, but that shows factory mode works.
                            It will have to be a non-upgraded GT. If you have the buzz, FM changed things from what I understand.
                              @biell I'm 6109 atm (HW6408). Waiting on a GT motor to come sometime next week so I can at least get rid of one of the errors and sort it out. Seems to turn itself off after like a minute so I assume that's related.
                              I did have a go on Android but the FM app would refuse to see the board after pairing via the FixMyPEV button. Probs that BLE handshake thingy so will need to try the rewheel fix :3
                                @lia I think the GT BLE commands are different, but I remember the rest being the same for my GT as for my XR: https://owforum.co.uk/topic/210/rewheel-app-to-access-factory-mode-on-onewheels/4?_=1707077559784
                                Rewheeling is the way to go anyway, because after you disable the handshake, you can use OWCE to manage the board (for most things, at least).
                                The key is to use nRF Connect while the app is still connected.
                                  Kinda been a bit busy but I would like to share the new member of the fam.
                                  I haven't named it yet or styled it out. I don't wanna keep it all black.
                                  I ended up not using the superflux motor as it made it super heavy. Thankfully @dajw had a GT motor needing a new home so I was able to buy that and get it running.
                                  Not before fixing the pairing issue. I reached out to Justin at FixMyPEV and he was able to share some knowledge on the topic since I'm not super up to date in the GT fiasco. This guide was what I ended up following.
                                  Will need to unlock it with the tool that shall not be named so I can use the OWCE app.
                                  I also modified a model on Printables to allow an airtag to be mounted ^-^
                                  Might upload it another day as a remix.
                                  LOAF 1 Reply Last reply Reply Quote 6
                                    @lia That looks amazing!
                                    I wish my board looked that nice!
                                      Not gonna lie, flexy fender top gives Slushy looks to it. :}
                                      Clean build!
                                        @loaffette Thank you ^-^ I do wanna give it a makeover at some point since I'm not super into just black but at least it looks nice as is :3
                                        @Sirgu Aha yeah I had some spare bits so those were migrated over. Slush remains intact though. I want to try without the fender and just the fins but I need to stop the dirt somehow.
                                        • TheAdman
                                          TheAdman XR FW adv Pro last edited by TheAdman
                                          I honestly think it looks so good all black, so mean looking.
                                          Smiles per hour.
                                            It haunted me till now when suddenly realized why I like BLACK so much in here.
                                            -- You heard of why fat people wear black clothes? - Yes!
                                            Whenever GT first made into public, prof. Jake Leary criticised it for fat rails and bulky looks in so many reasons. (I agreed all those hands down.) Aside of aspects from practical considerations, one was just the looks.
                                            And yes .. one does not need to be obsessed in black tone in general ... black just makes GT / GT-S look pleasantly slimming.
