    XR Error 21 (repaired)
    e21 error 21 xr controller
    17016
      I think I found it!
      The LED driver circuit has parts of it where both ends of a cap ground. This literally makes 0 sense so I think that's the problem. Looks like I had my probes round the wrong way. It only goes to ground in one direction so there must be a diode going back to ground off Vin that I was catching.
      Appears to be on the front side of the driver circuit, I didn't realise what it was till drawing the traces.
      Bare in mind the blue traces are my guesses. There are only certain ways they can route without interfering with the other traces on the same layer and the vias that go throught the whole pcb.
      Edit 1
      Still mapping stuff out... All I have to say is.... why.... WHY is this so confusing!
      Bare in mind the blue lines are guesses (as are any red that are under a chip). I can tone them out but I can't see through objects :(
      Edit 2
      Going to stop for tonight, hit the wall trying to trace how the maps back to the chip without hitting the other traces. There must be either another way some of the other traces route or there's another layer somewhere. For now I've put those as purple traces.
      I do feel that maybe there is a 3.3v layer on this PCB since it goes to so many other pins on a hidden layer that seem to conflict with the other trace paths. Suggesting it could be a 4 layer PCB.
        @lia You have so much dedication and patience, kudos to you!
          @lemur Thanks :)
          I know a schematic for the controller will allow 3rd party repair to get much better so putting in the effort seems like the right thing to do.
          Still working on the spagetti part near the ARM chip. Got maybe 1 or 2 traces not routing on appropriate paths making some other traces hard to connect however I'm nearly making sense of it all.
          Highlighted 2 traces I think are wrong (yellowy-green with the angee face pointing at them) that is stopping me route the 3 traces for the BMS/Controller communication. Hats off to whoever painstakingly routed these traces, no way did an automatic tool do this.
          Full image for V4 below.
          Red is the bottom layer
          Blue is the middle layer
          Green is the top GND layer
          Pink is 3.3v that I haven't decided how they route yet
          I can safely say I am much more familiar with how this works even if I don't understand what some parts do exactly. Will probably be able to give a full pinout for it soon or recreate the PCB as a gerber file for 3rd party manufacturing 0:
          Edit 1
          Thought I had it... AAAAAAAAAAAAAAH
          Edit 2
          Okay I figured out a way to route the blue traces that makes sense and isn't too weird. There are definitely ways the via's could have been placed to be more sensible but... oh well.
            @lia In awe, I am, at your ability to figure these workings out!
              @s-leon Thanks :)
              I like to think of it like those games where you try to arrange pipes to connect the inlet to the outlet. Just in this case there are lots and I have to find where the inlet and outlets are.
                @lia I reflowed the solder on a ASIC miner hashboard today and fixed an intermittent issue. Was feeling awesome then read this post and reaffirmed I'm not even on the same playing field as you. 👏
                  @stinkyface Congrats on the repair! Reflowing isn’t nearly as easy as they make it look on YT.
                  Funny side note, a few years ago I absolutely toasted a Toshiba laptop that had a lifted CPU… but because I’m a moron I used a heatgun @400c and some tin foil to try protect the rest of the board from the heat.
                  That day I learnt what popcorning a pcb looked like.
                  Since then I got myself the right tools for some reflowing. CPU reflowing is still out of my league.
                    I have spent this entire time trying to find where the LED drivers get their power from.
                    Thought I already checked this but apparently not since I accidentally discovered they're driven straight off the main battery rail. I am omega dumb.
                    I now somehow have to figure how Batt+ reaches an of the vias on the LED side
                    Can't go to that pad for D5 since there is no surface trace leading to it or a via under it to connect to.
                    Presumably the 4 blue traces going vertical between them route differently but I can't see a valid way to move them in a way that exposes a direct path between them. I imagine there is a sensible pathing that's just been clouded by my existing guesses, sort of like trying to solve a Sudoku by guessing a few numbers that later comes back to haunt you on the last few empty squares.
                      Still can't quite sus that routing so I'll sit on it a bit longer. In the meantime I've created a key down in the bottom with links to datasheets for each chip I've been able to identify.
                      Q1 - Q6 : IRF7759
                      U1 - U2 : ACS781xLR
                      U3 : LM5007
                      U4 : TI 78LO5A
                      U5 : HIP4086ABZ
                      U6 : LVC541A
                      U7 : LF33A
                      U8 : ILT254S (CC2541)
                      U9 : STM32F103VB
                      U10 : LSM330DLC
                      U11 : N/A
                      U12 : N/A
                      U13 - U16 : LM3402
                      U17 : VP1781
                      Edit : Thanks to ChunkDunkerson for U1- U3
                      Thinking of posting this on Reddit and seeing if anyone's got any ideas on U1-U3 and suggestions on the last missing traces. Nevermind I posted it anyway :)
                      EDIT : This has been continued in another thread
                        @lia said in XR Error 21:
                        ChunkDunkerson
                        lmao
                          b0ardski last edited by
                          so what was the final solution to end error 21? new lightbars?
                            @b0ardski Nothing yet, still sitting waiting for me to pick it up again. I'm going to remove the LED drivers to see if that fixes this one since the error occurs even when nothing is connected.
                              b0ardski @Lia last edited by
                              @lia isn't there a chip added to the 4209 after 4208 to defeat charge n ride? was thinking that was a likely issue.
                                  Don't you just hate it when you dink about and things just work? Not even any smoke?
                                  Figured I'd give the LED drivers a bit of heat in case something wasn't connected up right. I don't know if that was it or I accidentally fixed it while probing it for hours but she lives!
                                  Nothing proper to hook up so piggybacked off my charger and soldered some leads onto Batt+ and Batt-
                                  Still gives E16 but that's kind of a given since it's only the brains.
                                  Guess it now needs a body. Another project?
                                  b0ardski 1 Reply Last reply Reply Quote 6
                                          @lia thanks for that i'll get pics posted later this evening, after I open it up and rig up the spare battery
                                            @lia will upload pics tonite, on the way to last day of the season party at the ski hill.
                                            plugged in the spare battery to the control box , unplugging lights button and charge plug made no difference.. the mastic pads on the components felt damp but no sign of corrosion.
