    XR Error 21 (repaired)
    e21 error 21 xr controller
    17016
      I have spent this entire time trying to find where the LED drivers get their power from.
      Thought I already checked this but apparently not since I accidentally discovered they're driven straight off the main battery rail. I am omega dumb.
      I now somehow have to figure how Batt+ reaches an of the vias on the LED side
      Can't go to that pad for D5 since there is no surface trace leading to it or a via under it to connect to.
      Presumably the 4 blue traces going vertical between them route differently but I can't see a valid way to move them in a way that exposes a direct path between them. I imagine there is a sensible pathing that's just been clouded by my existing guesses, sort of like trying to solve a Sudoku by guessing a few numbers that later comes back to haunt you on the last few empty squares.
        Still can't quite sus that routing so I'll sit on it a bit longer. In the meantime I've created a key down in the bottom with links to datasheets for each chip I've been able to identify.
        Q1 - Q6 : IRF7759
        U1 - U2 : ACS781xLR
        U3 : LM5007
        U4 : TI 78LO5A
        U5 : HIP4086ABZ
        U6 : LVC541A
        U7 : LF33A
        U8 : ILT254S (CC2541)
        U9 : STM32F103VB
        U10 : LSM330DLC
        U11 : N/A
        U12 : N/A
        U13 - U16 : LM3402
        U17 : VP1781
        Edit : Thanks to ChunkDunkerson for U1- U3
        Thinking of posting this on Reddit and seeing if anyone's got any ideas on U1-U3 and suggestions on the last missing traces. Nevermind I posted it anyway :)
        EDIT : This has been continued in another thread
          @lia said in XR Error 21:
          ChunkDunkerson
          lmao
            b0ardski last edited by
            so what was the final solution to end error 21? new lightbars?
              @b0ardski Nothing yet, still sitting waiting for me to pick it up again. I'm going to remove the LED drivers to see if that fixes this one since the error occurs even when nothing is connected.
                b0ardski @Lia last edited by
                @lia isn't there a chip added to the 4209 after 4208 to defeat charge n ride? was thinking that was a likely issue.
                    Don't you just hate it when you dink about and things just work? Not even any smoke?
                    Figured I'd give the LED drivers a bit of heat in case something wasn't connected up right. I don't know if that was it or I accidentally fixed it while probing it for hours but she lives!
                    Nothing proper to hook up so piggybacked off my charger and soldered some leads onto Batt+ and Batt-
                    Still gives E16 but that's kind of a given since it's only the brains.
                    Guess it now needs a body. Another project?
                    b0ardski 1 Reply Last reply Reply Quote 6
                            @lia thanks for that i'll get pics posted later this evening, after I open it up and rig up the spare battery
                              @lia will upload pics tonite, on the way to last day of the season party at the ski hill.
                              plugged in the spare battery to the control box , unplugging lights button and charge plug made no difference.. the mastic pads on the components felt damp but no sign of corrosion.
                                @b0ardski Sounds like a sneaky problem. Hope you enjoy the party :)
                                  @lia Is that component with the messy soldering some kind of fuse?
                                  I repaired a Xr bms with a blown U1 chip(I249a1) chip, it works with my good Xr 4208 controller, but when I connected the repaired bms to the original controller, the controller would blink blue once and not turn on.
                                  When I connected the charger to the original controller and the repaired bms, the same U1 chip blew again.
                                  Luckily, I had a few new U1 chips around and the solder pads were still intact, with my fingers crossed, I connected the charger to my good 4208 controller and the repaired bms( second repair) and the charging went fine.
                                  I'm just going through your excellent pictures to learn what about all the components on the controller.
                                    @lemur said in XR Error 21 (repaired):
                                    This one just above the battery connector on the controller?
                                    That appears to be a 10H10 schottky diode from what I can tell.
                                    I can't find the I249a1 chip, do you have a link for it? Also what version is the original XR running?
                                    Haven't diagnosed a BMS yet but I've got one next to me to look at. U1 being the tiny 8 pin IC below the XT60?
                                      @lia Sorry, I must've have mistyped the U1 chip on the bms, it's I240A1 chip. some kind of current sensor?
                                      The original controller was a 4210-4150, but I had a Owie on it at first, but needed a reboot on the power button to work, so I switched to a Jw chip and that worked great.
                                        @lemur Oh I see now. Seems sort of common.
                                        https://www.reddit.com/r/onewheelpint/comments/ia0zkr/fried_onewheel_pint_question/
                                        Oddly the Pint uses the longer one that has a different pinout (page 3)
                                        https://www.ti.com/lit/ds/symlink/ina240.pdf?ts=1652609679914
                                        Looking at it the chip amplifies the difference between both sides of the current sense resistor so the main IC can see what the output current looks like.
                                        That being said I'm at a loss as to why it's blowing when hooked up to the correct controller and working instead with an older gen one. If the opposite was true I'd assume some sort of reverse polarity somewhere.
                                          @lia These were Pint bms's before I flashed one to 4208, I see the short body chip and the long body I240a1 chips. The boards have different revision numbers.
                                          I dis save the original firmware associa ted with the bms serial numbers.
                                          I have a bms I trying to repair that gets hot by the large chip that shuts down the controller and destroys owie chip. Haha.
                                            @Lemur A fine collection of parts. Pretty useful for looking at what changes and what might be wrong on other kit.
                                            I wonder if maybe the voltage regulator for the BMS isn't working correctly and feeding to much voltage into the IC's power rail. I would expect no more than 5v.
