    Kush low as front footpad
    9216
      Lemur @NotSure last edited by
      @notsure I went with the low because I wasn't sure if the sensors would conform to a deeper concave.
      I think they might, I have a Kush Hi that I will try later.
        @lemur cool! the bottom isn't waffled like urs is. that concave front looks awesome tho!
        edit: nevermind. i dunno i thought the lo was waffled for some reason.
          b0ardski @Lemur last edited by b0ardski
          @lemur said in Kush low as front footpad:
          Yes , I made that out of 1/4" abs and doubles as a float plate.
          The toe hook really helps me on the heelside turns, I snowboarded for all my life and you really need to be locked in for the heelside carve, turn or slide.
          thats why I made a toe hook and use a flightfin for the back foot.
          love the incorporated float plate
          btw I had a Kemper bullet181 raceboard back in the day
            Interesting project @Lemur
            Eager on hearing from it how it goes in time being!
            BTW ppl ... recently mr. Matt Hoover (from Land-Surf) have hinted numerous times in variety of FB groups recently that hes been working on FRONT PLATYPUS ;)
              NotSure XR Pint @Sirgu last edited by
              @sirgu honestly its the sensor pad innovations that have me most interested. concave front foot pads sound really cool.
                Sirgu XR @NotSure last edited by
                @notsure Understood.
                As for myself .. aside the exitement on concaveness .. I do value the extra wideness that comes with Platypus. Although my feet are not that large (~10,5") dual platypus.jpg
                Lia M 2 Replies Last reply Reply Quote 2
                  @sirgu Ooo that green looks nice!
                    Just an addition for the topic: Kush-lo+ pint sensor.
                    Added diy CF plate as anti-ghosting and sturdy bottom plate, kush is kinda flexible;)
                    NotSure 2 Replies Last reply Reply Quote 3
                      @maciak said in Kush low as front footpad:
                      diy CF plate
                      printed or purchased?
                        @notsure
                        Neither lol, hand laminated using the bottom of the pad for shaping since the front part curves up.
                        3(or 4, dont remember) layers of unidirectional 340g/m2 fiber.
                          @sirgu really like this. Im curious what it looks like under that grip!
                            i wonder if this could be done for the airpad? it already has a sturdy base plate. i never tried peeling off the gel tho. i'd love that. id buy it immediately.
                              @notsure said in Kush low as front footpad:
                              Is the gel part not inside the pad?
                                that whole yellow piece is the "gel". its just soft rubber. under that is an aluminum base plate that provides the rigidity.
                                  @notsure
                                  I get it. Well, it depends. If that pad flexes enough so the toeside pressure deforms the heelside for instance, it could lead to undesired behaviour : such as heel-lift at standstill wont disengage the board.
                                  Also i can think of slow recovery of the pad back into shape after compression. So the moment you lift your foot the pad stays in that shape a bit longer. This would certainly lead to ghosting.
                                  I think you can determine by the feel of that pad if it has any characteristics i described above.
                                    NotSure XR Pint @MacIak last edited by NotSure
                                    thats a good point. what if the sensors are applied to the aluminum instead of the pad and covered with a low friction film of some kind? maybe kapton or pfte tape? the rubber does compress easily but it does not travel with respect to the base.
                                      @notsure
                                      Yes, a guy on the Onewheel subreddit is using it successfully like that. Here's a link to one of his posts:
                                      link text
                                        Sirgu XR @MacIak last edited by
                                        @maciak Yea, the day I posted it I had no idea the PlatySense v4 design involves single pressure sensor. Which is bummer for me. I'm keen on heel-lift disengage. :/
                                        For now there's bunch of FB short vids of how on point sensitive it turned out.
                                        Recent YT video here:
                                        https://www.youtube.com/watch?v=JmKEnJOfZJM&ab_channel=BartMiller
                                          MacIak DIY GT XR Plus @Sirgu last edited by MacIak
                                          @sirgu
                                          Oh dang! I watched that vid but missed the single sensor part coz i got pissed off by how he was slamming on the stock pad like an ape. This vid is very stupid tbh.
                                          Edit: I dont like posi either tbh. The dual pad is about the only fail-safe we have and im no trickster.
