    Kush low as front footpad
    9216
      Lemur @Lemur last edited by Lemur
      I installed the Kush low with fsr 406 sensors on my XR and tested it out on a long ride. It performed flawlessly, no false starts or ghosting.
      It did take me a while to get used to the concave, it would be great if they can incorporate a "love hump" in the Kush pad. I think there is a company that made that style than OW.
        b0ardski @Lemur last edited by
        @lemur said in Kush low as front footpad:
        Did you make the toe hook?
        landsurf platypus has the arch hump
          Lemur @b0ardski last edited by Lemur
          Yes , I made that out of 1/4" abs and doubles as a float plate.
          The toe hook really helps me on the heelside turns, I snowboarded for all my life and you really need to be locked in for the heelside carve, turn or slide.
          NotSure b0ardski 2 Replies Last reply Reply Quote 3
            @lemur @b0ardski i have an old kush hi that i replaced with the airpad. could i use it to make one too?
              Lemur @NotSure last edited by
              @notsure I went with the low because I wasn't sure if the sensors would conform to a deeper concave.
              I think they might, I have a Kush Hi that I will try later.
                @lemur cool! the bottom isn't waffled like urs is. that concave front looks awesome tho!
                edit: nevermind. i dunno i thought the lo was waffled for some reason.
                  b0ardski @Lemur last edited by b0ardski
                  thats why I made a toe hook and use a flightfin for the back foot.
                  love the incorporated float plate
                  btw I had a Kemper bullet181 raceboard back in the day
                    Interesting project @Lemur
                    Eager on hearing from it how it goes in time being!
                    BTW ppl ... recently mr. Matt Hoover (from Land-Surf) have hinted numerous times in variety of FB groups recently that hes been working on FRONT PLATYPUS ;)
                      NotSure XR Pint @Sirgu last edited by
                      @sirgu honestly its the sensor pad innovations that have me most interested. concave front foot pads sound really cool.
                        Sirgu XR @NotSure last edited by
                        @notsure Understood.
                        As for myself .. aside the exitement on concaveness .. I do value the extra wideness that comes with Platypus. Although my feet are not that large (~10,5") dual platypus.jpg
                        Lia M 2 Replies Last reply Reply Quote 2
                          @sirgu Ooo that green looks nice!
                            Just an addition for the topic: Kush-lo+ pint sensor.
                            Added diy CF plate as anti-ghosting and sturdy bottom plate, kush is kinda flexible;)
                            NotSure 2 Replies Last reply Reply Quote 3
                              @maciak said in Kush low as front footpad:
                              diy CF plate
                              printed or purchased?
                                @notsure
                                Neither lol, hand laminated using the bottom of the pad for shaping since the front part curves up.
                                3(or 4, dont remember) layers of unidirectional 340g/m2 fiber.
                                  @sirgu really like this. Im curious what it looks like under that grip!
                                    i wonder if this could be done for the airpad? it already has a sturdy base plate. i never tried peeling off the gel tho. i'd love that. id buy it immediately.
                                      @notsure said in Kush low as front footpad:
                                      Is the gel part not inside the pad?
                                        that whole yellow piece is the "gel". its just soft rubber. under that is an aluminum base plate that provides the rigidity.
                                          @notsure
                                          I get it. Well, it depends. If that pad flexes enough so the toeside pressure deforms the heelside for instance, it could lead to undesired behaviour : such as heel-lift at standstill wont disengage the board.
                                          Also i can think of slow recovery of the pad back into shape after compression. So the moment you lift your foot the pad stays in that shape a bit longer. This would certainly lead to ghosting.
                                          I think you can determine by the feel of that pad if it has any characteristics i described above.
                                            NotSure XR Pint @MacIak last edited by NotSure
                                            thats a good point. what if the sensors are applied to the aluminum instead of the pad and covered with a low friction film of some kind? maybe kapton or pfte tape? the rubber does compress easily but it does not travel with respect to the base.
