    Vesc specific batteries
    13654
      Does anyone have a link to where I can learn more about this TORque box enclosure? Is it only for VESCing, or can it be a better way to install a CBXR?
        Samuraipunch last edited by
        It will likely be some time before word on them starts spreading. Most people with a board that dies, usually part it out, if not junk the whole thing, if they don't send it back to FM for a full fix. Also going up to a 84v system to match the GT is likely another big additional expense.
        This makes it more unlikely that we'll see Pint VESCs, which seem to be pretty common from kids killing their boards. As we're talking well over the cost of a new Pint/PX. Even as an XR conversion, the only thing that'd be left at this point would be the motor... So a lot would have to go wrong, and I don't really see that a lot of people that have gotten into OWs over the last year as being competent, or interested enough to do a VESC conversion.
        I think that maybe by year end/black friday, depending on how things are with the GT would be telling on how much VESC feasibility and adoption goes. As a ground up VESC in an XR form factor that's competitive with a GT would be a fun winter project, that doesn't use FM parts.
        M NotSure 2 Replies Last reply Reply Quote 2
          @biell There's no info so far. Maybe on Fecesbook?
          Either way it should be possible to put a CBXR in it, but you'd need bumper adapters for it as im certain the box will be higher (and less tail clearance). According to Igor it was a collab with Badgerwheel so they might know something?
            MacIak DIY GT XR Plus @Samuraipunch last edited by
            @samuraipunch
            -not limited by battery type
            -not limited by vesc used
            • Extra box with modular battery for air travel?
            • All XR aftermarket at disposal
            • repair at will
              -Adjustable behaviour including pushback
            Yea, my current project will cost more than a GT but above alone will be worth it. It's not for everyone but kit-type of options are very close.
              @samuraipunch said in Vesc specific batteries:
              seems counter intuitive to me. i would figure there are gonna be so many orphaned og pints around, that the expense for a vesc pint x would be on par with a stock pint. i would be interested in converting my xr to vesc gt when the time comes.
                To fully convert a Pint i don't think it's worth it, especially if you were the one to kill it. As the conversion becomes nearly as expensive.... Also I'm referring to most of the newer people, that wouldn't be pursuing such a conversion... Especially if they're bankrolling it out of their own pocket.
                Now, for someone looking for a husk/skeleton of a board to start with it makes things a lot easier.
                I'm also pretty certain that we won't see the TORque pack in a pint formfactor. Which then makes the Pint sized VESC more unlikely, as most will want to focus on increasing voltage and capacity for a build.
                  @maciak Thanks, if you do hear something more concrete, please post back for us to take a look.
                  My CBXR fits nicely in my battery compartment. I'm pretty confident I only squeeze down on the foam to close mine, but I know others have a tough time. They have to squeeze the batteries, which you aren't supposed to do. I have always felt Chi should sell battery box that didn't have to be modified. Well, at least the plastic part of the box.
                  M 2 Replies Last reply Reply Quote 4
                    @biell Sure will do! Honestly no single CBXR fits in the casing properly. It's not that the foam only compresses. If you measure, even visual you will see a slight bulge both on the lid and casing. I too had not much issue installing it, just hold down by hand and cross-tighten the bolts. But this force is not to be underestimated. Now if i remove the lid i can put it back on an it just falls into place without pressure.
                      @biell What i got so far:
                      -Badgerwheel makes the casing.
                      -ETA about 3 months
                      -Compatible with stock harness
                      -NOT compatible with stock lid
                      -Has it's own lid!
                      -NOT compatible with existing bumpers
                      -Great waterproofing (logical if Badger makes em;)
                      -Price around $100, cheaper possible if there's enough demand for it
                      -He will try to have made compatible bumper at time of release.
                      -CBXR will fit no problem!
                      Confirmed: it comes with a lid and CBXR fits. Will edit this post if i have the info. No supplier i contact actually answers all questions asked. Pretty fuckin annoying as i do not correspond in Arabic..
                        @maciak Thank you, this is great information. It is a shame that it won't support BANG bumpers. But, given what they are trying to accomplish, that is understandable. I will definitely be keeping my eye out. And, at an ETA of 3 months, would likely recommend to anyone thinking about a CBXR to hold off and see what they release.
                          @biell Above updated: comes with lid, CBXR will fit no problem!
                            Bit off topic: IT'S ALIVE!
                            Just need Ali to deliver my 20s charger🤣
                              @maciak You tease, I need to see some build pics :D
                                MacIak DIY GT XR Plus @Lia last edited by MacIak
                                @lia Lol i was just assembling some parts to see if my custom harness fits and to explore the focer..before i knew it the build was complete (except yesterday, different story) but i will re-do it for a complete reference). I cannibalised the + box lid for the printed battery case. Looks over-wired but i prepared the lot for a revised version of rEscue/lights. Dunno if it will fit though🤣.
                                Vesc build https://imgur.com/a/lHpHWoG
                                  @maciak I know that feeling. Everything overdone so you've got options down the line to redo something only to wonder if you have room. Loving those pics in the imgur album too. Very nice to look at.
                                  @ed_co I think you'd enjoy seeing some of that :)
                                    ed_co XR @Lia last edited by
                                    @lia said in Vesc specific batteries:
                                    Following his process since the very beginning. Of course I like it ;)
                                      Well, things get even more promising. If you can buy a VESC in it's own Plus compatible controller box with OW connectors, then that really makes it much, much, much more accessible.
                                      At this point, I think it is unlikely FM changes there tune enough that my next board won't be a VESC. I'm pretty happy for now with my Two-X, CBXR, and GT. But, this is very likely the next evolution of my Plus rails and motor (coupled maybe with something like the battery box mentioned earlier and a Chi battery).
                                        @biell I just came back from my first ride on 20s. Think "Tuco" will be my main board, its unreal.
                                        B NotSure 2 Replies Last reply Reply Quote 4
                                          @maciak Does your battery pack have a BMS to balance the cells, or do you have to do something to balance them, or is that not an issue for some other reason?
                                            @biell the 15s setup i just charged unbalanced, worked fine.
                                            On this setup i have a charge-only bms.
