    40252
      @loaffette Ouch :(
      I think all the Fungineers stuff is metric. Mostly because we're all from predominantly metric based countries 😅
        Ubox 100v stopped working after I shorted the 12v Power port on the controller itself. (the unmarked 2-pin PH 2.0 plug beside the SWD one on the side)
        Emailed spintend to see if there's any fixing it, but this seriously puts a pause on my plans
        I did get everything wired up for the LEDs, but it still sucks that the controller is busted.
          @loaffette Hope they get back with a fix. Probably something replaceable has blown if you know someone with a reflow iron and steady hands.
            @lia they just told me it's dead and needs to be sent back
            I'll probably poke around inside and see if anything looks broken or busted
              @loaffette Assuming the fuses did their job you should be fine.
              https://spintend.com/products/single-ubox-100v-100a-motor-controller-based-on-vesc
              Check continuity between the highlighted components. If one shows Open Loop then that needs replacing with another fuse.
              Good luck!
              LOAF 2 Replies Last reply Reply Quote 1
                @lia I'll check
                    Update
                      That's a later project though
                            New update:
                            A little confused now
                              I'm ALIVE!
                                No?
                                too bad
                                  @loaffette Nick and I thought about something like this but I've never seen PD outlets in the wild (at least in the UK). Especially any spec'd for high wattage.
                                  I know the spec can go to 240W which is insane but other than a few premium battery banks that might give you 5-10% charge after losses it's not something you'd see a lot to make work in a pinch.
                                    bought a Superflux HS Mk2
                                    Will drop it in soon
                                    Also working on a couple things rn, will keep ya'll posted once I finish it
                                      Got the Superflux on, currently don't have a picture yet
                                      Things to note about installing a superflux-
                                      The thunder tire is literal landfill. Just throw out the tire, it's not worth it. I had my tire for about two days, went on a trail ride and the tire developed a flat. Swapped it out for my old Enduro and it was much better
                                      The male connector has way too much meat on the connector. IT needs to be trimmed because making it fit within the rails is a hassle and a nightmare. They should cut it by about half an inch from the cable in terms of connector for better flexibility. I already know two trail riders local to me who have done this.
                                      The superflux hs HAS SOME GAS
                                      That thing flies like a bat out of hell
                                      It's one hell of a motor, and it was worth every penny
                                        Here's a pic of the tire change. You can see how terrible the old motor was (the motor with the purple cable)
                                        I'm not even going to sell the motor. It's got 6k miles, the cable is messed up and the bearings are the same ones from day one. I'm going to bring it to a lecture one day to take it apart for a lab then keep it as a trophy.
                                        The current goal now is to waterproof the board, finish my headlight project and then to give the board a visual overhaul
                                          Lemur @LOAF last edited by
                                          @loaffette I use to carry a solar charger, a 36v hoverboard battery, charging adapters, in a camera bag for group rides.
                                          The solar charger converts the 36v to any higher voltage up to 90 v all programable with memory for different boards.
                                            LOAF XR @Lemur last edited by
                                            @lemur very interesting
                                            I'll have to look into that option
                                            I remember Wren for CD using a setup like that for his board
