    40251
      Hello everyone
      I'm still alive, just busy with summer internship and stuff.
      The board is fine, switched the controller box to an ASA Easy-Access modified to fit the stock XLR and power button.
      I will post a more detailed writeup later on, concerning what progress I have made with my board
      In other news:
      Pushed my board to 30MPH. Stock htpercore motor with 4000 mile old bearings, ubox 100v and the ME4T pack from TheBoardGarage
      I may have a problem, and I think it concerns my sense of self-preservation
        @loaffette -- I suggest that you might want to wear some armor. A Fox Titan Pro Jacket (with some extra CE padding in the leading shoulder and elbow) has let me get back up and ride away from an handful of high speed crashes. That with a helmet, knee pads, and wrist guards. Also, on my hips, I wear knee/shin guards -- no more bruised thighs.
          @s-leon I'm already working on that. Got a new full-face helmet, knee pads and wrist guards. Going to save up a little more and then buy something for the chest.
            Alright, update time:
            This time, properly.
            So, for the past year I've been dealing with a problem on my board. The threads on my rails keep going out. I've had press-fit inserts put in, but they keep falling out. I've JB-welded in some 10-32 nuts, but those don't hold. There isn't much metal left in the rails where the threads are to even do heilicoil.
            So, what's man got to do to get his threads back?
            You make your own threads somewhere else
            The way I see how the onewheel is assembled is that everything attaches to everything. The bumpers attach to the rails, controller and the footpads all at the same time on the XR. The kush wide attaches similarly, and controller boxes are just bolted in with screws threading into the box itself.
            So why not just cut the rails out of the picture if they are just a problem? The only screws holding my bumper on are attached to the footpad and controller anyways. So, why not just have the footpad and bumper attach directly to the controller itself?
            I took Fungineers Easy Access box and made the holes underneath the footpad screws small enough for heated inserts to fit snugly into. I extended out a small block for each bumper, and added a hole for a heated insert. I'm going to print this out on my new Bambu A1 (I got so fed up with my CR-10 Smart that it now permanently lives inside of its box in the garage). I'll print it using PETG, but I'm going to compensate by making the walls on this thing thick. I'm shooting for at least 5-6 walls thick, and I'm going to crank up the infill to 40 percent.
            I'm also printing off a new footpad for the future. My old one has the sensor peeling up on one of the back corners, and it's ghosting on the left side of the board. Going to print off VOW's Mushies in PETG, but I'm going to make it pretty dense and add a couple mods of my own I'll show later.
            Apart from that, I'm going to clean up the wiring in the board and make it a little prettier, add an Avaspark RGB Mini.
              LOAF XR @LOAF last edited by LOAF
              picture of the box
              I had to shrink the m3 heated insert holes around the top because they were way too large for the inserts I had on hand. Made little legs that stuck out, and made the screw holds small enough for heated inserts
              I have a devious plan with his
              Expanded the holes for 19mm buttons, same for the plug
              also, I found out today why my threads on my board got stripped.
              apparently thunder rails are tapped for M5, not 10-32
              XR uses 10-32 screws
              Thunder rails are tapped for M5
              my reaction to this information:
              sadge
                @loaffette Ouch :(
                I think all the Fungineers stuff is metric. Mostly because we're all from predominantly metric based countries 😅
                  Ubox 100v stopped working after I shorted the 12v Power port on the controller itself. (the unmarked 2-pin PH 2.0 plug beside the SWD one on the side)
                  Emailed spintend to see if there's any fixing it, but this seriously puts a pause on my plans
                  I did get everything wired up for the LEDs, but it still sucks that the controller is busted.
                    @loaffette Hope they get back with a fix. Probably something replaceable has blown if you know someone with a reflow iron and steady hands.
                      @lia they just told me it's dead and needs to be sent back
                      I'll probably poke around inside and see if anything looks broken or busted
                        @loaffette Assuming the fuses did their job you should be fine.
                        https://spintend.com/products/single-ubox-100v-100a-motor-controller-based-on-vesc
                        Check continuity between the highlighted components. If one shows Open Loop then that needs replacing with another fuse.
                        Good luck!
                        LOAF 2 Replies Last reply Reply Quote 1
                          @lia I'll check
                              Update
                                That's a later project though
                                      New update:
                                      A little confused now
                                        I'm ALIVE!
                                          No?
                                          too bad
                                            @loaffette Nick and I thought about something like this but I've never seen PD outlets in the wild (at least in the UK). Especially any spec'd for high wattage.
                                            I know the spec can go to 240W which is insane but other than a few premium battery banks that might give you 5-10% charge after losses it's not something you'd see a lot to make work in a pinch.
