    OW Pint VESC Repair
    pint vesc
    82
    36965
      @lia There are two sensors(2 zones) Pints are opposite from vesc that's why that trace has to be cut otherwise the vesc 3v3 will ground out and fry your vesc.
        @lemur Oh right thanks for pointing that out.
        Haven't taken the time to lookup the pinout of the VESC yet but I'll keep that in mind.
        Uploaded the files for the footpad connector if anyone wants it.
        https://www.myminifactory.com/object/3d-print-206107
          "Hey, You. You're finally awake"
          Quick and dirty adapter to connect the charger to the controller. It turns on and if I ignore the E16 it looks functional. So good to know I have another working controller laying around. 5301 too which is cool, early gen gives me the best possible chance of tweaking things if I ever want to use it.
          2063km too, lived a good life prior to being converted.
          L NotSure 2 Replies Last reply Reply Quote 5
            @lia Thanks, I checked my cannibalized Pint board, and it gives a code 16 too with 5314 and gemini 5050. No idea what we can use the board for unless we can find a way to run without the bms.
            Lia NotSure 2 Replies Last reply Reply Quote 4
              @lemur I bet just a chip sending the same data packets as the stock BMS would keep it happy.
              Assuming early gen weren't serialised replicating the signal and passing it from a little arduino shouldn't be too hard. Serialised ones I guess using some of the work on that github project you found the other day would come in handy correcting it.
              Love the project but I hope the guy working on it kept their identity well hidden. FM could come after them with a DMCA in a similar manner that they came after JW and the JWFFM chip. Speaking of which is that still ongoing?
              L NotSure 3 Replies Last reply Reply Quote 3
                @lia JW is still selling the chip, however the price has gone from $150 to $250 and doesn't advertise as being able to match bms'. I did confirm that it will match bms' via email a few weeks ago. I do have a early production Jw chip I bought used, only powered it up but never put it to practical use.
                Not sure on the lawsuit, I think it's still in the discovery stage.
                  @lemur said in OW Pint VESC:
                  that case is soft. i asked a patent lawyer for ibm. far from ironclad. probably end up settling for peanuts.
                    @lia said in OW Pint VESC:
                    his name is robert paulson...
                      fus ro dah!
                        maybe test to see how much we can 'overclock' a stock board? ramp up voltage to 68? 72v maybe? 60v is lame. might as well be 59v.
                          @notsure Depends what components are used. I'd guess the 3 main things to check are the max for the filter caps, mosfets and whatever chips are responsible for stepping down voltage plus anything passive that touched the battery voltage.
                          The caps are Panasonic Aluminium Electrolytic Capacitors however I'm not able to verify the specs outside of being 390uF. I think it could be 80v since mouser only gives results for 80v when looking at the 390uF on the TP range of those caps.
                          Mosfets I can't see from the coating on them that I don't fancy peeling off yet.
                          Thinking about it, if not for the software limits the Pint would in theory be so much more modable. It's much simpler with less clutter unlike the prior generations that had countless components.
                            Oooh i like that hint of optimism! i look forward to captain morganing my way past the sound barrier.
                            [cue b2tf instrumental]
                              @lia Looks like a update on a OW BMS JW style chip.
                              https://github.com/lolwheel/Owie
                              Coincidently, JW just lowered their chip to $49 and free if you buy a battery.
                                @lemur Oh sweet, looks really good and well documented.
                                I did see they dropped the price, apparently some speculate it's because this project was available now which makes sense.
                                B L 2 Replies Last reply Reply Quote 2
                                  @lia It could be competition causing the price drop. Although it could also be that they are planning on releasing a new model, so they are selling off the existing stock. I don't know that they should be afraid of Owie just yet, we are still figuring out how to relay battery % (https://github.com/lolwheel/Owie/issues/1). Ah counting will be the way, but it isn't quite ready yet.
                                  In the long term, I fully expect JW to copy Owie's code b/c they are hacks with no originality.
                                    Lemur @biell last edited by
                                    @biell Could also be financial problems due to the lawsuit, trying to bring some money in with the free chip offer with the purchase of a battery. Can't make any money with chip sales alone.
                                      @lemur Excellent point, it could be.
                                        @lia Just uploaded on discord, a diy for the JW style chip.
                                          @lemur This is an exciting development.
                                          The comment on the shipping for the previous JW chip had my jaw drop. $100 for international shipping???
                                            @lia Yeah, shipping outside of the US is crazy. Haha, I just checked the JW site and the chip went back to $250, it was $49.69 yesterday, I bought one a couple of days ago at the discounted price.
