    11
    52
    20106
      Had a small hiccup with the design.
      Turns out the footprint for the 5050 LEDs were rotated 180 out of order compared to the actual footprint. The fab told me they couldn't just rotate the pick and place operation so I've had to re-submit it after making an amendment to the EasyEDA library for that component in hopes it doesn't trip anyone else up lol.
      Just confirmed the pick and place pre-production file so ideally I should have these in a few weeks :)
      Then it's a case of getting a set off to Ed and Maclak before looking to sell off the first batch. No idea on what I'll price these at yet, something sensible of course though.
      I have 20 pairs manufactured currently since that made the most economical sense taking into consideration shipping costs balloon after you hit around 1.5kg total weight.
        Still waiting on the lights, but they have at least touched down in the UK :)
        In the meantime I'm working on the packaging since I can't just ship these things in boring boxes. No no no no nooooo~ I spent too much time in Product Design to NOT put that bit of education to use. Besides the difference between a villain and a super on is presentation and I simply cannot settle for less.
        This is one of the lids to the boxes I've decorated with a stencil. I like the look (even if I got paint all over me. Thankfully not my new cute white top)
        These will of course go inside actual protective postage bags and not just left bare like this.
        Each of these will contain 2 headlights, one with pre-applied double sided thermal adhesive for heat dissipation into the ELM controller housing and the other will remain without.
        Also included will also be 2 little transparent EML stickers because who doesn't like free stickers.
        S. Leon LOAF 2 Replies Last reply Reply Quote 7
          @lia -- Stunning packaging! It makes my mouth water -- although I do not even use lights on my Onewheels.
            @s-leon Thank you <3 The box is a premade one for necklaces but the innards and decor will be all me :)
            They're sadly not drop in replacements for the XR but rather designed for modded boards that can interface with an RGB signal (RGBW in my case)
              cheppy44 XR DIY last edited by
              most excellent @Lia!
                @lia That's pretty cool! Can't wait to see them out in the wild!
                  Well look what decided to show up. So many LEDs 0.o
                  Work is busy today though and I'm the only one covering support so haven't been able to take pics of the test I did but they work!
                  Going to make a jig to separate and test these all then see how they compare to the XR, Pint and even my initial version.
                  Update post to follow in a few hours x
                    NotSure XR Pint @cheppy44 last edited by
                    @cheppy44 said in ELM custom headlight and taillight (VESC):
                      I spent way too long trying to validate this and my eyes are on fire. I can still see multiples of 17 dots across my vision and a headache to go with lol πŸ˜–
                      Testing is done (I hope) and it looks like it's keeping up just fine with the XR. Hard to get on camera but I gave it my best with my iPhone on a tripod so it didn't move too much.
                      For each test I had an A1 sheet of foamboard 2.5m away from the boards in each since that's as much room I had to work with and felt like a good way to validate the brightness :)
                      Also did the Pint but it wasn't worth adding in the above gif.
                      (Yes the Wii and games are certified scientific testing apparatus)
                      So what's with this "Bumper Mod" mentioned in the images I hear you ask (I'm in your walls). As it turns out the stock bumpers have a tiny window that was blocking some of the LEDs seen below.
                      The dedicated white segments of the LEDs were obscured so although they shone nicely below it didn't do much up front. However there is a bit of overhanging plastic you can easilly remove with a file where you get the below results.
                      The mod as you can see makes a slight difference in how much extra light makes it forward rather than just down where you get a clearer cutoff line for where the white channel reaches.
                      V2.3 Might have the LEDs rotated 180 if I can pull that off without completely changing the layout of everything else however I'd doubtful it'll make that much of a difference so either version should be fine.
                      Guess I need to finish the packaging then and sort out how I'm going to sell the first batch off.
                      Stats in case you wanted.
                      Full white (That's RGB set to 255 and the White channel too) draws 0.72A per bar @ 5V
                      Full red (That's Just the red channel at 255 and nothing else) draws 0.16A per bar @ 5V
                      So in theory you have 2 with opposing white/red total current draw is 0.88A @ 5V per bar or 4.4Watts to run a pair in a "normal" config.
                      BatteryMooch 1 Reply Last reply Reply Quote 5
                        Okay I had too...
                        If you have RGB you have to have it shoot rainbows.
                        Also added a demo turn signal animation as a proof of concept.
                        You could probably get way more creative with it and make it more clear. On cam it just blows out the sensor so not easy to record it but you get the idea.
                        K 1 Reply Last reply Reply Quote 6
                        • BatteryMooch
                          BatteryMooch @Lia last edited by
                          @lia thank you for creating this and doing these tests! It’s great to see it working so well.
                            Lia GT XR Pint Plus V1 DIY @BatteryMooch last edited by
                            @batterymooch It's been a lot of fun :) Learning how to do full production CAD in EasyEDA and get a PCB fab to make these was new.
                            Thanks for swinging by <3
                            TheBoardGarage 1 Reply Last reply Reply Quote 1
                            • TheBoardGarage
                              TheBoardGarage @Lia last edited by
                              @lia
                              I must buy these. They look fantastic.
                              In your testing, what are you using to drive and/or control these?
                              Cheers!
                                Lia GT XR Pint Plus V1 DIY @TheBoardGarage last edited by
                                @theboardgarage I’ll be sure to keep a set reserved for you on the first batch :)
                                For testing I’m just feeding a data signal using a seeeduino (tiny little Arduino the XS will be using) using the neopixel library. Really simple to test with and I hear the VESCs support RGB and RGBW now so this should just drop in with a decent buck converter to supply the 5v.
                                BatteryMooch 1 Reply Last reply Reply Quote 2
                                • BatteryMooch
                                    Packaging being made. Nearly ready to put up orders for the first batch :3
                                    Hopefully this weekend with @cheppy44 's help.
                                    Each box gets a bit of my shoddy spray painting (It's artistically bad I promise)
                                    The rest of the boxes waiting to dry :3
                                    Test of the foam inserts and fitment. I think it looks nice and doesn't come loose no matter how much I shake it.
                                    There's only a few on the first batch because I have no idea what sort of demand there are for these but I've already ordered 2000 LEDs for another few batches just in case with an altered LED orientation.
                                    Back to work I guess <3
                                    Follow-up post with better pics, included bits and whatever else I'm forgetting.
                                    H TheBoardGarage 2 Replies Last reply Reply Quote 6
                                      HanahsDax @Lia last edited by
                                      @lia said in ELM custom headlight and taillight (VESC):
                                      The overspray look of the ELM logo is incredible!
                                        @hanahsdax I really like how that turned out too, it's crazy messy but worth it :)
                                        • TheBoardGarage
                                          @lia
                                          Looks excellent. I look forward to these.
                                            Lia GT XR Pint Plus V1 DIY @TheBoardGarage last edited by Lia
                                            @theboardgarage Thankies <3
                                            I'm sure you'll love them :) I can't wait to see what people do with these with whatever special sauce is being added to the VESC firmware.
                                            Nick tells me you're after a few more so we'll set aside a bunch from the next batch for you too. Still have 1 from this batch reserved as well x
                                            We're going to allow orders on Saturday Noon (Central Time) in Discord.
                                            Once the first batch are gone (there's like 11 left) we'll be doing a wait-list as I'm currently waiting for the delivery of the LEDs to begin the next batch which I'm ordering WAY more of this time.
