    DIY W Rails
    45
    18081
      @s-leon Actually it does lol. PB on + is a pita
        @biell You could get a tiltkit or just diy tilt the controller? Needs about 4-5mm. It creates a different set of problems though. The TFL tiltkit killed a bunch of controllers (how is it kept silent?!). I suspect cause of a capacitor getting squeezed into the bottom of the box which i found out during own experimenting. I asked/adviced Jeff. He tactically avoided answering any questions about it.
          @maciak I am afraid my skills might not be there for that. Also, I would have to tilt the other direction, which might mess up how the connectors line up with the holes in the back of the controller box.
            @biell Darn, looks like i misunderstood the whole thing! So you want the controller side to point down while in mission?
              @maciak I actually want the controller to point straight/level in Mission. My controller is messed up a little. When the Onewheel reports at being 0.0°, the front is actually up 1.77°. Essentially, if I am set in my preferred Mission mode, it is like I am riding Elevated. I can fix this with custom shaping by setting the ride angle at -1. When I do this, my board rides level-ish (I think level would be -0.9). But, I prefer Mission.
              Originally I thought, what if WTF rails were at a 2° angle? Then, I could put my jacked up controller in them and ride perfectly without having to get the TFL controller lid replacement. But, with WTF rails at more than 4°, that isn't going to work. I would still need custom shaping.
              I was also wondering if there was a way of re-calibrating the board, but I doubt there is because then people with WTF rails would have just done that. I also don't know if the issue is in software or hardware.
              I had been ignoring this issue for the last couple years because I was used to it, with most of my riding on my XR. However, now I am riding my GT as much, if not more than my XR. So, the raised front became harder to ignore. Right now I am at -1,-1,6 and it feels a bit like Flow on the GT.
              If you have any thoughts or ideas, I am definitely interested in suggestions.
              Lia M 2 Replies Last reply Reply Quote 3
                @biell Maybe not quite what you're after but u/Izzymonster just posted "Titled Controller Box, work in progress. Appreciate any feedback from experienced tilt kilt installers."
                https://www.reddit.com/r/onewheel/comments/uh03xd/titled_controller_box_work_in_progress_appreciate/
                  @biell When my board with WTF is level, the app shows -3.7 deg. So assuming WTF are 4.2 deg, it would mean that it would be sitting nose-down by 0.5 deg on straight rails for the app to show 0. When the board is really level, this would be -0.5 in the app.
                  So your board still deviates 1.27 deg extra..
                  The pcb is mounted under the lid with 3mm spacers. You could remove (or replace with shorter spacers) the front ones which will not mess too much with the connectors (opposite tilting also puts them at an angle which is no problem).
                  Edit: see img when i tilted the frontside
                  Only thing is the thermal pad, and if anything on the underside of pcb gets pinched against the lid.. gotta see if there's any issues there. I think this could work.
                  Edit: maybe not..there's lotsa stuff in the front that could be pinched against the lid without any spacer. Need to open to really see?!
                  B 2 Replies Last reply Reply Quote 4
                    @lia Thanks, depending on how this shapes up, it could be a starting point for me. Either by trying to make the angle less with WTF rails or by flipping it for straight rails. It will also depend on if it is sold as a product or provided as an STL.
                      @maciak Thanks, I thought about that but was worried about the thermal pad. If you learn something there, please let me know. I haven't opened the controller since I decided this was a problem, so I also want to take a look at the board to see if something looks wrong on there, too.
                        @MacIak @biell Maybe add some aluminium sheets under the pads as shims then JBWeld the edges to stop them shifting?
                        The pads seem pliable enough to tolerate the difference in angle so just getting them to touch is all you need then.
                        M B 2 Replies Last reply Reply Quote 3
                          @lia For usual de-wedging this could work. But for wedging as @biell needs the main problem would be the front components pressed against the lid once those spacers are removed. I do not remember if this would be the case. Too little time to pull apart the OW and look inside atm..
                            @lia Nice thought about JBWeld, I hadn't thought of that. That would certainly make one part of the mod easier. Thank you.
                              I think I may have an idea, I could get the FAF Varials and flip the center piece's left and right sides. It might just be enough to even everything out and have me ride near level. I might reach out to Jeff to ask about this. If I hear anything back, I will let you know.
                                From reddit (Linky)
                                TFL have successfully patented their WRail design, can't say I expected that so I wonder if there was a concern that other companies or even FM were planning to make and build their own?
                                Anyway here it is on Google Patents with a few notable drawings from it.
                                https://patents.google.com/patent/US11325021B1/
                                @MacIak @biell In the patent (towards the end) are approximate dimensions and angles so that should answer our earlier questions :)
                                B 1 Reply Last reply Reply Quote 7
                                  @lia Funny, they were granted a patent this month for a product they stopped selling months ago. I wonder if the are going to patent varirails now, I can only assume they plan to. Then, maybe I can look up the specs on the FAF rails.
                                  The tilt is 5° on WTF rails.
                                    ed_co XR @biell last edited by ed_co
                                    @biell AFAIK was 3 degrees. They were talking in the tech rails group in facebook
                                      biell DIY Plus @ed_co last edited by
                                      @ed_co So it is a bit confusing reading the patent. They clearly state that the footpad section is 3.7° relative to the center section in some parts, but then discuss a net 5° tilt throughout the rest of the narrative. So, if I understand what I am reading (which I may not), then the specific locations of the pivot points come into play, and the net board down-angle is, in fact, 5° when a normal board is registering as level while engaged (in e.g. Mission), but at rest.
                                        @biell said in DIY W Rails:
                                        Maybe is easy to solve:
                                        @MacIak could you please let us know what is the exact angle of the controller box (without any tilting method) in your WTF rails? Thanks
                                          @ed_co I got a confirmation from Fungineers that the new rails for the SF motor is will be compatible with XR .
                                          Looks like WTF rails. Not a rendering anymore, but a preproduction sample. Seems like you can assemble a XR clone with a Lfocer v3 and without a need for a controller tilt kit. All from offshore parts.
                                            Samuraipunch last edited by
                                            Is it me? Or do those rails not look like they're angled up? Although in doing so might put them at risk of violating TFL's patent.... It'd be the shaping at least that's the point of contention, but the multiple holes to change axle height could be enough difference...
                                            While, I'm all for things like this, and IP protection, it's a slippery slope that I think can lead to stagnation in time; once there's enough saturation, as you won't be able to do something without stepping on someone's toes.
                                            L Sirgu 2 Replies Last reply Reply Quote 2
