    OW Pint VESC Repair
    pint vesc
    82
    37986
        @lia I'm not sure, I just made a 18s pack with each cell at 3.8v, the R7 tested fine with 68 v until I charged the pack to 75 v , pressed the power button and smoke from the vesc.
        @lemur That sucks, because R7 is rated supposedly at 78V and they rate it for 18s. Bummer... I never liked R7 because they were pricey even when there were not reason before shortage... Little focer is the way to go by far...
          @ed_co I think the V3 Lfocer is the way to go now.
            @lemur Sadly is expensive as hell...
              @ed_co Yeah, $300 us is steep.
                MK1 printed successfully minus a bit of nozzle wobble.
                Took a while to get the support material off D:
                Here's what I woke to this morning~
                After a bit of cleaning up and filing down on the little channels for the rear bumper rails to slot into it fits quite well.
                Slapped the rails on to verify that it does indeed fit and it appears to be pretty much spot on
                Thankfully even the charge port looks to be accurate too which is a relief
                Connected up the battery harness to the model after cleaning up the M20 threads with my tap. Everything fits nicely. Didn't have a BMS cover to hand but since that hasn'd changed since the Pint battery housing it should also work still :)
                And now were back to the topic at hand again. The former VESC pint soon to become a PintX
                Still need a name for this board though...
                Not sure about sharing this publicly just yet without some other eyes on it.
                Anyone fancy giving it a look over to see if there could be improvements?
                https://drive.google.com/file/d/1Wn16iHf18XZYL955l8qn4RuGjkmOAliM/view?usp=sharing
                One suggestion for printing, with the supports try blocking the inner-most part of the rail channels else it'll be a nightmare to clean them up after. Getting support just on the outer lip is enough to print the overhang. Screenie below of what I did.
                Just as a bonus some renders of the model :)
                -Wheel view
                -Tail view
                -Left view
                -Top view
                -Bottom view
                  @liaThat's amazing! I can't offer any improvements because the files look like hieroglyphs to me, but is it ok if I get this printed?
                  Lia E 2 Replies Last reply Reply Quote 2
                    @lemur Please do :) Let me know how it works out for you
                      How did it go? Have you printed? What is your opinion? Any feedback? :)
                        @ed_co I have to find another person do do my printing, my present guy moved away. Sorry.
                          I've publicly released the battery housing on MyMiniFactory.
                          Haven't yet mentioned it on reddit though since I don't want to spend this evening responding to lots of comments D:
                          Here's the link in case anyone is interested.
                          https://www.myminifactory.com/object/3d-print-215232
                          E L 2 Replies Last reply Reply Quote 6
                            @lia As usual, just amazing!
                            Have you started with the battery for your pint/pint x hybrid?
                              @ed_co Thanks <3
                              Nothing like that yet, waiting on things to calm down before buying some more gear.
                                @lia I finally found someone to print the battery box for me . Should be done next week. Thank you.
                                  @lemur Thanks for letting me know :) Eager to hear if it works well for you too.
                                    Likely you all know about this, which I happened on today -- preorder for a motor that may work in a XR:
                                    https://fungineers.tech/products/hub-motor-complete-with-tyre
                                    Lia B Sirgu 3 Replies Last reply Reply Quote 3
                                      @s-leon Very excited seeing these, do we know if those are custom fab or off the shelf whitelabel motors?
                                        @lia -- Good question.
                                          @s-leon From what I read, it will work inside the XR rails, but not with the XR controller or battery. The voltage range is 60-80v, which I assume is nominal. If so, an XR with a 54v nominal, would be below spec. The XR adapter they speak of sounds like a mounting bracket and not a connector adapter. Can anyone maybe more knowledgeable about these things correct me?
                                          If you could plug this thing into a GT with 63v nominal, on the other hand, that would be a game changer for many people!
                                            @biell Motor should still work at the lower voltages. That might just be a recommended range for desired speeds.
                                            I don't see a Kv rating anywhere which is how you'd determine the speed per voltage so we'll have to wait and see unless that info is hidden somewhere.
