    Onewheel GT 6.5 inch tire solution (hopefully)
    12682
      @lia Not my idea, but the second idea is mine.
      -First is a spacer ring to make up for the difference in the bearing shoulder. I machined a blank, but I need final dimensions.IMG_5242-1.jpgIMG_5239-1.jpg
      -Second is a adapter to center the GT stator/axle in my lathe so I can machine the GT bearing shoulder.IMG_5241-1.jpg IMG_5240-1.jpg
        Lemur @Lemur last edited by
        @lemur Finished the Gt rim adapter, I made it 0.054" thick instead of 0.050" because I can always shim to get the proper end play like OW does. I just to make sure I don't brick the GT if I remove the motor.IMG_5243-1.jpg IMG_5245-1.jpg IMG_5247-1.jpg
          @lemur Oh I get it now, was so confused at first but this makes sense. Instead of modifying the GT stator by shaving off that extended lip you're just shimming the hub plate to it can sit on the extended lip.
          That is so clever, I'd have never thought to do it that way! This is by far the best and least destructive method and I love it.
          L E 2 Replies Last reply Reply Quote 2
            @lia Just scared to tear apart my GT right now. Haha.
            NotSure Lia L 3 Replies Last reply Reply Quote 3
              @lemur said in Onewheel GT 6.5 inch tire solution (hopefully):
              lol yeah that hub may be rigged man. imagine that... the hall sensors maybe?
                @lemur I don't blame you, I was eager to crack mine open after my first ride but now I'm reconsidering it.
                As much as I love to tinker I'm in no position to be a canary for the next potential FM boobytrap.
                That said once things settle a little I'll probably build up the courage to pop it open.
                  @lia It's an expensive board to be messing around with right now especially with so many unknowns . Having said that, I'm trying to source a Torx plus 45 for the rails. Haha.
                    No way they used a 45??? My set only goes up to 40 D:
                      @lemur I think Bob Nicolson took apart his GT but never unplugged the battery or bms, but the red light of death came on when he tried to power it up later, although he managed to get to work later.
                      Maybe he never hooked up the motor when he powered it up and maybe the controller goes through a systems check before giving the go ahead. I know cars and bikes do that.
                        @lemur Possibly, I was surprised when doing diagnostics on my XR that you can get aways with just the controller, BMS and battery to load into an active state. Sort of thought the lack of motor would throw an error, maybe that's what they've done here.
                        Do we have any confirmed reports of the GT throwing specific error codes anymore at all actually? I'm curious if they kept that since it's the only way we know what to look for when fault finding currently.
                          @lemur Are we sure they used a 45? If so, you want to get an ip45 (Torx Plus), not a T45 (standard Torx). I don't get my GT until Wednesday (hopefully), so I can't guarantee this work, but if you say it is a 45, then it will:
                          https://www.mcmaster.com/54305A33
                          You will also need an adapter for your ratchet. Note that is a 5/16" hex on the bottom. Once you break it loose, a T45 should be fine:
                          https://www.mcmaster.com/6963A26
                          If you saw the picture of the TFL slick GT with the Life Savers on, you will notice they totally jacked up the bolt. My guess is they were using a T40 when an ip45 was needed. I am also wondering if FM is using loctite red.
                            Lemur @biell last edited by
                            @biell It's definitely a Torx plus, I can get one with 3/8 " drive from our Snapon dealer at a price of a complete set of a off brand. I don't want to mark up the bolts in case of warranty. I broke a couple of cheap bits on Pint rail bolts until I got a Snapon Torx.
                              ed_co XR @Lia last edited by
                              @lia said in Onewheel GT 6.5 inch tire solution (hopefully):
                              Call me stupid, but I still don't understand the idea...
                                @ed_co It does get confusing, but the new Onewheel GT has a 6.5 inch rim and tires are proprietary which you cannot buy from OW. You have to send the GT in to get a tire changed.
                                This adapter allows the 6 inch rim from a XR to be fitted to the GT and allows many styles of common 6 inch go kart tires from many sources.
                                  I am well aware about the size change from XR to GT. But I don't understand the solution. Are you planning to put the GT rotor inside the XR stator assuming all the magnets/space/configuration will be the same on both?
                                    @ed_co The other way around, GT stator in a XR rotor (rim).
                                      @lemur
                                      Source: https://www.facebook.com/photo/?fbid=10220209549740881&set=pcb.978722056102633
                                      I guess you have all the answers here:
                                      275777425_10220209549620878_6935716758871604536_n.jpeg 275685085_10220209560101140_4866607758880254349_n.jpeg 275618778_10220209561541176_3864382129661908584_n.jpeg 275898358_10220209547780832_4953507255042636824_n.jpeg 275933708_10220209565261269_4741119165093054503_n.jpeg
                                        @ed_co Looks like there's no problem taking apart the motor.
                                          Absolutelly, are you doing it?
                                          L 2 Replies Last reply Reply Quote 3
                                            @ed_co Picking up an expensive Snapon torx plus 45 right now to take the GT axle bolts off. One Snapon socket is the same price as a set of OTC TP sockets. I disconnected the GT motor , footpad cables, reconnected them and the board is still good.
