    First thread! Waterproofing/bumper change
    • TheAdman
      TheAdman XR FW adv Pro last edited by
      Hi there, I'm Adam. From a small UK town some of you know well.
      I recently bought an XR and included are a few sets up bumpers. Apparently it's been water proofed and I wondered if there's anything special I need to do when changing the bumpers so the waterproofing isn't ruined.
      Also, one of the the holes for the fender bolts has been shredded. Is there a replacement I can get so it isn't held on by just three bolts?
      Thanks all
      Smiles per hour.
      NotSure Lia TheAdman 3 Replies Last reply Reply Quote 1
        NotSure XR Pint @TheAdman last edited by
        @theadman said in First thread! Waterproofing/bumper change:
        stock rails?
        https://www.fungineers.us/products/rails-and-adapter-3d-printed-filed-for-enclosures-and-bumpers
          Lia GT XR Pint Plus V1 DIY @TheAdman last edited by
          @theadman Hiya :)
          Swapping out the bumpers shouldn't undo the waterproofing. That's all done on the housing behind the bumpers.
          • TheAdman
            TheAdman XR FW adv Pro @TheAdman last edited by
            Thanks all
            I believe they are, black and white striped pattern. I just need the threaded metal insert if is possible to buy those.
            Smiles per hour.
              @theadman You've got stock rails, just had some vinyl rail guards on.
              Is it the actually thread that's bust or the bolt is chewed up?
              TheAdman 1 Reply Last reply Reply Quote 0
              • TheAdman
                @lia ah yes, I see they are covers now. Nah threads gone, tried several bolts. I'm gonna run it with no fender given its dry, but the additional thread that's dropped out will needs replacing.
                Smiles per hour.
                  Sirgu XR @TheAdman last edited by
                  @TheAdman said :
                  ... Nah threads gone, tried several bolts. I'm gonna run it with no fender given its dry, ...
                  Hi & welcome! If you are not after the flawless looks - some good tight cable tie will handle, since it's your first and ONLY stripped thread out of whole setup and since it's just sustaining fender in place. Especially if you've got some stripe-pattern railguards .. look for colored cable tie that matches the appearance. With the max. width the hole allows.
                  You can postpone this work for now.
