    Onewheel XR Clip model
    1669
      UPDATE!
      Working on clips for the Badgersense! Currently, I've gone through two designs, and I'm printing out the third iteration as I type this. I will try and post the full model on Printables once it's finalized and I know it works!
      Here are pictures of the previous two iterations
        Update:
        So...
        Hows everyone doin?
        I have a lot of exams in the upcoming week, and I'm bogged down with studying for said exams. I will admit, my brains isn't all there at the moment since I've had a lot of crazy stuff happening as well.
        When I do have free time, I'm working in my Onewheel. Now, back to the topic. I've updated the bracket, and instead of clipping on, you slide the LED strip into it. Its a snug fit, it holds up pretty well, and with normal use, it should all be fine!
        I will post the updated model tomorrow after my CAD exam and Chem Lab, and I'll let you guys know if I make any more changes.
        I am working on one for the little controller box, but thats a whole can of worms for future me to panic about.
          @loaffette said in Onewheel XR Clip model:
          Hope you're doing well and coping fine. Best of luck with the exams too!
          Eager to see the model when you're done with it, don't burn yourself out though if things are a bit stressy :)
            NotSure XR Pint @LOAF last edited by
            Chem Lab
            how many electrons can occupy the P and S shells respectively? no googling!
              LOAF XR @NotSure last edited by
              @notsure no please no oh God no nononnononon-
                Clip model for the badgersense LED strip is posted!
                All you need to do to install the strip is to slide each end of the strip between the small clips on the top of the model, then clip those onto the rail itself. >1hr print, and can be printed using PLA!
                I may also do a repair and a mod over the weekend if I decide not to sleep the entirety of Saturday
                  Working on a clip model for a Tile Mate (2022)!
                  I am thinking of making a two-piece mounting kit to protect the tile from water/dirt and grime. Also, the weird shape of the tile is.. hard to model/model for.
                    Update:
                    First test print, and it fits perfectly! Doesn't rattle around, doesn't fall out. It just sticks in there and doesn't come out! A simple test of throwing the test print at the ground with the tracker in proves that the tile stays in!
                    Will work on making a lid for it, though wondering if it should be a clip, or if it should be glued in.
                    What do you guys think?
                      @loaffette It's really cool, how well does the tile work on the Onewheel? I've only used Airtags
                        @lia so far, it's been nice. I Don't know about it's tracking capabilities but it's something that I can use to decently track it. I don't own any apple devices so I can't use an AirTag. I might go for the samsung one or find an old iPad and use it to set up airtags
