    Onewheel XR Clip model
    918
    • LOAFFETTE
      LOAFFETTE DIY last edited by
      I completely forgot about this, but here's something I think I should let the community have.
      I recently made a model that allows someone to clip something to the rails of their XR (If you're using stock rails, unsure of modified rails.)
      I have been riding around with them last week, and they haven't fallen off since! Just as a note, I wouldn't stick anything wide on the rail clips if you're prone to doing stupid stuff¹ on your onewheel and subsequently having your board go flopping all over the place. Your board rolling or landing on it's side will basically shred/crush whatever is sticking out. You can get away with sticking something on the top or bottom of the clip.
      It's up on printables with the .step and .f3d models! Feel free to remix and do whatever to them, just mention me if you do upload it!
      Can't wait to see what wacky stuff you guys come up with!
      https://www.printables.com/model/387554-onewheel-xr-rail-clip
      ¹ is defined as either doing tricks on your board, riding like a crazy lunatic, throwing your board down the stairs or ignoring pushback. May void warranty.
      LOAFFETTE 1 Reply Last reply Reply Quote 3
      • LOAFFETTE
        LOAFFETTE DIY @LOAFFETTE last edited by
        UPDATE!
        Working on clips for the Badgersense! Currently, I've gone through two designs, and I'm printing out the third iteration as I type this. I will try and post the full model on Printables once it's finalized and I know it works!
        Here are pictures of the previous two iterations
        • LOAFFETTE
          Update:
          So...
          Hows everyone doin?
          I have a lot of exams in the upcoming week, and I'm bogged down with studying for said exams. I will admit, my brains isn't all there at the moment since I've had a lot of crazy stuff happening as well.
          When I do have free time, I'm working in my Onewheel. Now, back to the topic. I've updated the bracket, and instead of clipping on, you slide the LED strip into it. Its a snug fit, it holds up pretty well, and with normal use, it should all be fine!
          I will post the updated model tomorrow after my CAD exam and Chem Lab, and I'll let you guys know if I make any more changes.
          I am working on one for the little controller box, but thats a whole can of worms for future me to panic about.
            Lia GT XR Pint Plus V1 DIY @LOAFFETTE last edited by
            @loaffette said in Onewheel XR Clip model:
            Hope you're doing well and coping fine. Best of luck with the exams too!
            Eager to see the model when you're done with it, don't burn yourself out though if things are a bit stressy :)
              NotSure XR Pint @LOAFFETTE last edited by
              Chem Lab
              how many electrons can occupy the P and S shells respectively? no googling!
              LOAFFETTE 1 Reply Last reply Reply Quote 1
              • LOAFFETTE
                LOAFFETTE DIY @NotSure last edited by
                @notsure no please no oh God no nononnononon-
                • LOAFFETTE
                  Clip model for the badgersense LED strip is posted!
                  All you need to do to install the strip is to slide each end of the strip between the small clips on the top of the model, then clip those onto the rail itself. >1hr print, and can be printed using PLA!
                  I may also do a repair and a mod over the weekend if I decide not to sleep the entirety of Saturday
                  • LOAFFETTE
                    Working on a clip model for a Tile Mate (2022)!
                    I am thinking of making a two-piece mounting kit to protect the tile from water/dirt and grime. Also, the weird shape of the tile is.. hard to model/model for.
                    • LOAFFETTE
                      Update:
                      First test print, and it fits perfectly! Doesn't rattle around, doesn't fall out. It just sticks in there and doesn't come out! A simple test of throwing the test print at the ground with the tracker in proves that the tile stays in!
                      Will work on making a lid for it, though wondering if it should be a clip, or if it should be glued in.
                      What do you guys think?
                        @loaffette It's really cool, how well does the tile work on the Onewheel? I've only used Airtags
                        LOAFFETTE 1 Reply Last reply Reply Quote 0
                        • LOAFFETTE
                          LOAFFETTE DIY @Lia last edited by
                          @lia so far, it's been nice. I Don't know about it's tracking capabilities but it's something that I can use to decently track it. I don't own any apple devices so I can't use an AirTag. I might go for the samsung one or find an old iPad and use it to set up airtags
