    17753
      @cheppy44 I'm using an Arduino Uno, a button and two separate LEDs (4 leds per strip.)
      Going to add the resistor.
      Also, I had a cool idea to add on to it later on that would change the color of the LEDs depending on how fast I'm going, or how fast the motor is spinning
        @loaffette that will be interesting! You would probably need an IMU to tell how fast you are moving.
          @cheppy44 I actually have one lying around
          So i tested it in tinkercad since I don't have any resistors IRL. It works with the pulldown, but only button 2 seems to be detected currently.
          Also, I had to change the code up for the LED so that strip 1 is for the left, and strip 2 is for the right since I'm going to be placing them under the fender for now
          Updated code:
          #define PIN1        3 //Pin for Front Strip
          #define PIN2        2  // Pin for Rear Strip
          #define BUTTON_PIN2 5  // Pin for Button 2
          #define NUMPIXELS   4   // Number of Neopixels in each strip
          void setup() {
            Serial.println("begin");
          void loop() {
            if (buttonState1 == LOW) {
              // turn left turn signal on
              strip1.fill(yellow, 5, 4);
              strip1.show();
              strip2.fill(red, 0, 4);
              strip2.show();
              strip1.fill(white, 0, 3);
              strip1.show();
              strip2.fill(red, 0, 3);
              strip2.show();
              delay(500);
            } if (buttonState2 == LOW) {
              // turn right turn signal on
              strip2.fill(yellow, 0, 4);
              //strip1.fill(white, 5, 4);
              strip2.show();
              //strip2.fill(yellow, 0, 4);
              strip1.fill(red, 0, 4);
              strip1.show();
              delay(500);
              strip2.fill(white, 0, 4);
              strip2.show();
              strip1.show();
              delay(500);
            } else {
              // turn leds back to "normal"
              //Serial.println("normal");
              strip1.show();
              strip2.fill(red, 5, 4);
              strip2.show();
          delay(50);
          Update:
          Checked the serial output and it does detect the button press, but nothing is changing with the LEDs
          update update:
          Code works! :) Copied code from the rigth blinker and copied it into the if statement for the left blinker and changed strip1 to strip2 and vice-versa
          iam smort
            @loaffette sweet! the strip.fill commands are pretty useful when you know how to use them.
              @cheppy44 yep!
              Tomorrow I'll order the arduinos, some resistors and I'll add them on later on this week.
              Need to focus on studying for two exams this week, but also I'd like to do a lot of my Onewheel work when I get everything for the Onewheel in! (This, life savers and the Badgersense!)
                @loaffette did you decide which controller you are going to buy? For the application I do thing that any of the name brand arduinos may be a bit big.
                  @cheppy44 going for the Nano due to its compact size and okay price, though that's what I'm going to be using for now. Later i might switch it up to something else
                    Update!
                    The Nano(s) are ordered and will be here next Tuesday! I will begin working on making a mount for the arduino and the battery. I will make a test mount for the battery and I'll probably modify an already existing nano mount for now
                      Arduino Nanos have arrived!
                      Won't be able to do any work on them until tomorrow. Got slammed with two exams yesterday and today I've got classes until 5 PM then two homework assignments
                      Tomorrow, I will work on the arduino and I'll post the results
                        UPDATE!
                        Everything is soldered together, but we have a few problems, mostly on my end.
                        1: Soldering job is horrible and I need to find a better way to connect the wires to the strips and I need actual wire that would be good for soldering. I have wires constantly coming off and I have to solder them back on, so I will have to go and find a way to solder those better..
                        The LED strip I have are old and a lot of them are broken, and I also don't ahve any resistors.
                        But the code works with my arduino, I just need some better wiring and better soldering
                        Lia cheppy44 2 Replies Last reply Reply Quote 2
                          @loaffette Looking good so far!
                            @loaffette lookin great!
                              the battery came off of it's mount after a jump off a curb and the LED wires snapped off 5 minutes into a ride
                              I am going to do research into how to do wiring better lol
                                Puzz360 XR Pint V1 @LOAF last edited by Puzz360
                                @loaffette excellent job so far… šŸ‘
                                I think now you have a working setup, hot glue and something like epoxy resin? would be good to set everything in place. A little permanent but would help I think… ???
                                Edit…Heat shrink too
                                    Ok, update:
                                    tired
                                    This weekend I hope to make the first working and functioning prototype for my RGB headlight project. Found some resistors, buttons and a spare LED strip to use. I also got some actual wire for soldering, and I do plan on 3D printing out cable reliefs for the LED strip connections.
                                      Soldered the LED strips up today, and was gonna connect them to the arduino nano, until I realized that there is only one 5v rail on the Nano. Might either run a long wire from the 5V out on one strip and to the other one, or splice two power wires into one..
                                          @loaffette Did a test ride last night!
                                          Battery pack stayed on well during riding, and the lights stayed on. However, whenever I dropped off curbs, the battery just flew off. I think there needs to be a better system for connecting the battery to the system, maybe making a mount that matches the shape of the fender and uses double sided tape or a lot of command strips...
                                          LEDs were nice, however they were not bright at all. Looking back at the code, I was unsure of how to make the LEDs brighter, and I am looking into trying to add a rainbow color mode to it. I'm trying to get the general system down before moving to making a wired remote. After I get the remote working, I will move to make a wireless remote.
                                          also, a dumb idea but part of me want's to add IR LEDs so when someone takes a picture, they see ghost lights on the board >:D
                                          Will need to talk with @cheppy44 about making the LEDs brighter through code. I know they can be brighter, but I'm unsure if it's my LEDs or something in the code..
                                            Sirgu XR @LOAF last edited by Sirgu
                                            Tell us more about that part.
                                            -- Priorly I've been guessing the wavelength of IR LEDs only affect equipment aiming you in night vision mode. Since ppl out there late at night or in low-light urban structures likely snap you with their smartphones either just with flash function or without. They likely don't get that glare on picture.
                                            Or I'm missing smth? >some reading<
