    18686
      @cheppy44 So I messed around a bit with the code to try and make it work
      Added a fuction that would print to the console if button two wasn't pressed.
      I don't have anything plugged into the pin for button 2 or 1 and it's reading that button one is pressed..
      Could my arduino be messed up?
      what board are you using, I might try and buy the board you have instead.
      Also, when I have the button plugged in and I hold it down, the LEDs stop flashing but are stuck on red
        @loaffette I am using an ESP 32 dev module, but I would not recommend it if you want to implement this on your board. I have a suspicion your issue has to do with pull up/down resistors. Could you post a picture of what your electronics looks like? The purpose of the resistors is to give the digital inputs a default state. If you leave them unconnected or “floating”, they are subjected to back ground electronic noise and are not reliable. Some micro controller have certain pins that have internal resisters that you can enable.
          @cheppy44 I may have forgotten about the resistor...
            @loaffette the controller you have may have internal pull up you can enable, that was why I was asking what your electronics situation looks like.
              @cheppy44 I'm using an Arduino Uno, a button and two separate LEDs (4 leds per strip.)
              Going to add the resistor.
              Also, I had a cool idea to add on to it later on that would change the color of the LEDs depending on how fast I'm going, or how fast the motor is spinning
                @loaffette that will be interesting! You would probably need an IMU to tell how fast you are moving.
                  @cheppy44 I actually have one lying around
                  So i tested it in tinkercad since I don't have any resistors IRL. It works with the pulldown, but only button 2 seems to be detected currently.
                  Also, I had to change the code up for the LED so that strip 1 is for the left, and strip 2 is for the right since I'm going to be placing them under the fender for now
                  Updated code:
                  #define PIN1        3 //Pin for Front Strip
                  #define PIN2        2  // Pin for Rear Strip
                  #define BUTTON_PIN2 5  // Pin for Button 2
                  #define NUMPIXELS   4   // Number of Neopixels in each strip
                  void setup() {
                    Serial.println("begin");
                  void loop() {
                    if (buttonState1 == LOW) {
                      // turn left turn signal on
                      strip1.fill(yellow, 5, 4);
                      strip1.show();
                      strip2.fill(red, 0, 4);
                      strip2.show();
                      strip1.fill(white, 0, 3);
                      strip1.show();
                      strip2.fill(red, 0, 3);
                      strip2.show();
                      delay(500);
                    } if (buttonState2 == LOW) {
                      // turn right turn signal on
                      strip2.fill(yellow, 0, 4);
                      //strip1.fill(white, 5, 4);
                      strip2.show();
                      //strip2.fill(yellow, 0, 4);
                      strip1.fill(red, 0, 4);
                      strip1.show();
                      delay(500);
                      strip2.fill(white, 0, 4);
                      strip2.show();
                      strip1.show();
                      delay(500);
                    } else {
                      // turn leds back to "normal"
                      //Serial.println("normal");
                      strip1.show();
                      strip2.fill(red, 5, 4);
                      strip2.show();
                  delay(50);
                  Update:
                  Checked the serial output and it does detect the button press, but nothing is changing with the LEDs
                  update update:
                  Code works! :) Copied code from the rigth blinker and copied it into the if statement for the left blinker and changed strip1 to strip2 and vice-versa
                  iam smort
                    @loaffette sweet! the strip.fill commands are pretty useful when you know how to use them.
                      @cheppy44 yep!
                      Tomorrow I'll order the arduinos, some resistors and I'll add them on later on this week.
                      Need to focus on studying for two exams this week, but also I'd like to do a lot of my Onewheel work when I get everything for the Onewheel in! (This, life savers and the Badgersense!)
                        @loaffette did you decide which controller you are going to buy? For the application I do thing that any of the name brand arduinos may be a bit big.
                          @cheppy44 going for the Nano due to its compact size and okay price, though that's what I'm going to be using for now. Later i might switch it up to something else
                            Update!
                            The Nano(s) are ordered and will be here next Tuesday! I will begin working on making a mount for the arduino and the battery. I will make a test mount for the battery and I'll probably modify an already existing nano mount for now
                              Arduino Nanos have arrived!
                              Won't be able to do any work on them until tomorrow. Got slammed with two exams yesterday and today I've got classes until 5 PM then two homework assignments
                              Tomorrow, I will work on the arduino and I'll post the results
                                UPDATE!
                                Everything is soldered together, but we have a few problems, mostly on my end.
                                1: Soldering job is horrible and I need to find a better way to connect the wires to the strips and I need actual wire that would be good for soldering. I have wires constantly coming off and I have to solder them back on, so I will have to go and find a way to solder those better..
                                The LED strip I have are old and a lot of them are broken, and I also don't ahve any resistors.
                                But the code works with my arduino, I just need some better wiring and better soldering
                                Lia cheppy44 2 Replies Last reply Reply Quote 2
                                  @loaffette Looking good so far!
                                    @loaffette lookin great!
                                      the battery came off of it's mount after a jump off a curb and the LED wires snapped off 5 minutes into a ride
                                      I am going to do research into how to do wiring better lol
                                        Puzz360 XR Pint V1 @LOAF last edited by Puzz360
                                        @loaffette excellent job so far… 👍
                                        I think now you have a working setup, hot glue and something like epoxy resin? would be good to set everything in place. A little permanent but would help I think… ???
                                        Edit…Heat shrink too
                                            Ok, update:
                                            tired
                                            This weekend I hope to make the first working and functioning prototype for my RGB headlight project. Found some resistors, buttons and a spare LED strip to use. I also got some actual wire for soldering, and I do plan on 3D printing out cable reliefs for the LED strip connections.
