    Organising the Archive
    The Archive
    archive old forum
    63017
      @notsure Totally get it, I'd love to do it that way and re-assign posts back to the OG authors but I don't have the confidence to edit a live database and not bork it up. Manipulating the HTML seems more attainable for me at least.
      It also sort of feels wrong. Not illegal but really weird to be handling abandoned data and manipulate it in that way rather than just rebuilding the displayed output and putting it on display. Feels more like an archive this way and probably less of a target for FM if I'm simply hosting the frontend instead of fiddling with the data. I'm not the British Museum after all ;)
      With this method I can keep the 2 sites separate. Old and New where the old one is a picture in time while the new one is where everything is now. Solves possible issues with incompatibilities and possibly corrupting the older pages with updates and plugins.
        @lia ooooooh.... laws n stuff... well, i consider it orphaned data. some of it may not even be around anymore. technically its ur contributions, which you have some legal access too. wont be me calling the cops lol!
        im not a web dev so i chose a data solution. @biell may feel differently.
          @biell Uploaded the France riders I managed to get, should be plenty in there to really give a script something to chew on if you can get something to function.
          [redacted]
          Don't worry if you can't get it to work, really appreciate the offer to take a look.
            biell DIY @NotSure last edited by
            @notsure I agree, this would be the reason to try and render the pages as static HTML, then there should be no server-side concerns.
              @lia Thanks, I downloaded it and was expecting to find HTML files also, but all I seem to have ones ancillary/media files. Did I miss something. You will have to excuse me, I have been supporting a change this weekend and it didn't go well, so I have been working for about 12 hours so far today.
              Lia 2 Replies Last reply Reply Quote 2
                @biell Oh balls it didn’t compress the actual html links. I’ll fix that in the morning, sorry about that D:
                Hope what you’re working on goes well, I know the feeling getting stuck on a work project that just doesn’t go anywhere.
                  @biell There we go, put all the files in this time (and I checked it again just in case lol).
                  20 FRANCE OneWheel Riders _ Onewheel Forum_files.zip
                  The HTML files have a corresponding folder that contains images and other dependencies that was downloaded when I saved the pages.
                  For the one I repaired I just merged all the folders into 1 then made sure all the references to the files in the master HTML were pointing at the master folder and not the individual ones if that makes sense.
                    *clears throat *
                    Haven't given the site an SSL certificate yet buuuuut...
                    archive.owforum.co.uk
                    Totally got Will Smith to show this one off for me. Thx Will x
                    Seems to work fine on mobile too so far. I'm tempted to put an iframe window on the right side to preview the clicked topic but need to figure out how to do that.
                    For now any feedback would be great (be gentle lol).
                    To Do List
                    • Add a custom header to all archived topics to return to the main page.
                    • Maaaaybe figure out an okay-ish search facility
                    • Git gud
                      @lia -- I am in awe!!! -- of your drive, of your dedication, and of your abilities!!!
                        @s-leon Thank you <3
                        You all give me the strength and desire to do all of this. I can't think of anything else that would have me attempt even a fraction of this.
                        • Pinned by  Lia Lia
                          @lia So, this should be pretty easy. The posts are all contained within a single giant unordered list. Each post is a list item, and there is metadata with a "data-index". So, both getting the correct post order and deduplicating entries from the different files will be a breeze.
                          All the files media/aux files under the _files structure are identical across all posts by name (e.g. 2170-profileimg.jpg is always the same picture).
                          If you are still interested, it would only take an hour or two to write the program, and then it could stitch all of this together. I would write it in perl, because I'm old. So, either you could upload zip files like this or I can easilly write it so the most basic perl install will work for you to run it yourself.
                          I can also program to rewrite the header to clean it up, for example I could remove the "Register" and "Login" links. I can also remove the text added by Google Cache, if you would like.
                          I can also remove the upvote/downvote links while I am at it, if you want. Or, I can completely remove that section, including the vote-count.
                          Let me know how you want it, I can then write version 1, send you the output, and we can tweek from there. But, this should all be very straight forward.
                          Lia NotSure 2 Replies Last reply Reply Quote 5
                            @biell music to my ears, removing those bits will be fine as I plan to go in and add a template header that’ll call to some master .css for the rest. Getting all the broken topics together would be a dream.
                            Would it be possible to have it spit out a txt or something per completed topic of missing post ids? I’ll go in after and add a placeholder list item and later try locating them on archive.org
                            I think we can keep the up/downvotes, Those might be interesting to see still and I’m working to repair the missing icons and later a way to do the timestamps.
                            Thanks for taking the time to have a look, will be sure to give you some credit on the archive page for helping simplify this mammoth task.
                            B 2 Replies Last reply Reply Quote 4
                              @lia Providing a list of missing posts should be very easy.
                              If you copy over from the current forum the "/assets" directory structure into an "/assets" in the archive website, then the missing icons should be fixed. From what I can tell, that is where they were, and where I hope for them to be looked for after I de-googleify the pages. Or, if you like, I could try to point the missing assets to this forum.
                                @lia What's wrong with the timestamps? Do you just want them rendered in UTC, or do you want them rendered localtime? If you want it in UTC, I can just hard code it into the page from the metadata and put that in the correct place. If you want it rendered in localtime, I should be able to add a touch of javascript to render that, but it will take longer to get working.
                                  @biell sorry I meant the icons like up arrow, down arrow, pinned, online, offline etc. You probably noticed the header nav icons are missing. They appear to currently rely on some internal site icons from FontAwesome but I plan to add custom ones and reference them instead so they render.
                                  Time stamps don’t render currently, seems like the data is there but compared to a working page the html elements are not there. They seem to exist as a meta tag only. If I gave you the template for a working timestamp element would it be simple to insert onto the posts using the meta data stored in these tags?
                                  I’m genuinely impressed with how capable this all seems. I was previously looking to try doing something in python but it seemed way out of my league since I’m not even an amateur D:
                                    @lia Send me what you want for the timestamp template, and I will see what I can do. There are lots of options. The best way to do all of this is to write the program to make all the changes you want, then it can just do the work for you all at once, straight from the source files. Then, if we want to tweak anything, we just update the program and re-run it against the source files. If you find more pages to fill in gaps, you just re-run the program with the new files in place, and it recreates everything exactly how you want it.
                                    Those icons at the top are done the same way, they are esentialy from a font, linked to from the CSS file, and the forum stores that data under /assets. Here is an example, navigate to this page, then "View Source": https://owforum.co.uk/assets/fonts/glyphicons-halflings-regular.eot
                                      lol
                                        Good find, I did notice some of it appears to be in the client.css file but the icons don't show regardless. I'll likely simplify it and just create the icons myself then refer to them instead.
                                        For the time stamps I've dug some more and think I found it, there's a class "timeago" that I assume might be missing and stopping it render. Going to dig around and see if I can either find it or rebuild it. Edit: Ah never mind it's a Jquery D:
                                        In that case since they all exist like below:
                                        <span class="visible-xs-inline-block visible-sm-inline-block visible-md-inline-block visible-lg-inline-block">
                                           <a class="permalink" href="https://community.onewheel.com/post/3836"><span class="timeago" title="2015-09-09T19:09:53.329Z"></span></a>
                                        Can it be replaced with this format:
                                        </small>
                                        <small class="pull-right">
                                              <a class="permalink" href="">2015-09-09T19:09:53.329</span></a>
                                        This closes the above "pull left" and sets the timestamp to pull right relying on the already existing closing statement. The href gets null'd along with the timestamp becoming detatched from the Jquery as just text. Ends up looking a bit like this:
                                        (I've imported the client-darkly.css for this hence the difference in color)
                                        If it's possible to have Perl re-write that as something more human readable like "9 September 2015, 09:53" that would be ideal :)
                                        NotSure B 2 Replies Last reply Reply Quote 1
                                          lol uh oh @biell ... u know where this train goes...
                                            @notsure Oh no is that an issue?
                                            NotSure 1 Reply Last reply Reply Quote 0
