    Onewheel GT 6.5 inch tire solution (hopefully)
    12679
      @lemur said in Onewheel GT 6.5 inch tire solution (hopefully):
      @ed_co It does get confusing, but the new Onewheel GT has a 6.5 inch rim and tires are proprietary which you cannot buy from OW. You have to send the GT in to get a tire changed.
      This adapter allows the 6 inch rim from a XR to be fitted to the GT and allows many styles of common 6 inch go kart tires from many sources.
      I am well aware about the size change from XR to GT. But I don't understand the solution. Are you planning to put the GT rotor inside the XR stator assuming all the magnets/space/configuration will be the same on both?
        @ed_co The other way around, GT stator in a XR rotor (rim).
          @lemur
          Source: https://www.facebook.com/photo/?fbid=10220209549740881&set=pcb.978722056102633
          I guess you have all the answers here:
          275777425_10220209549620878_6935716758871604536_n.jpeg 275685085_10220209560101140_4866607758880254349_n.jpeg 275618778_10220209561541176_3864382129661908584_n.jpeg 275898358_10220209547780832_4953507255042636824_n.jpeg 275933708_10220209565261269_4741119165093054503_n.jpeg
            @ed_co Looks like there's no problem taking apart the motor.
              Absolutelly, are you doing it?
              L 2 Replies Last reply Reply Quote 3
                @ed_co Picking up an expensive Snapon torx plus 45 right now to take the GT axle bolts off. One Snapon socket is the same price as a set of OTC TP sockets. I disconnected the GT motor , footpad cables, reconnected them and the board is still good.
                  @ed_co Did the conversion today, I have to make another shim as the present one is a little too thin, leaving too little axle endplay. It runs ,but can't upload a video. IMG_5261-1.jpg IMG_5260-1.jpg drawing.jpg
                  E NotSure Lia 3 Replies Last reply Reply Quote 7
                    @lemur this is absolutely stunning man!! Congrats, you did it!
                      @lemur lol yeah man thats fuckin awesome!
                        @lemur Amazing work!
                        For a vid I'd recommend uploading to Youtube and linking it here if you can.
                        Would love to see this working. Barely a week after launch and the community is undoing these roadblocks.
                          Great work! How is the clearance on the footpad sides, looks marginal or just the img?
                            ed_co XR last edited by ed_co
                            Any change/improvement/news? Overcoming the wheel issue sounds outstanding TBH.
                            The promised wheels from C&R and TFL sounds a very expensive solution, there would be a bump in the price for sure... (the new tooling system the companies could require for a custom solution makes it much more expensive).
                              Lemur @MacIak last edited by
                              @maciak The clearance is close, The wheel is moved over to one side by 1/8" due to hub differences. The stock tire is very close to the footpads too.
