    New XR!!!!
    • Wheelwizard
      Wheelwizard last edited by
      I have noticed the power outlet is not in the same place as the original XR and is not center to the rail.
      In the new vid Kyle did say it was new bumpers but same footpads as GT
      • Wheelwizard
        https://youtu.be/cTUSJmvXv-4?si=Cqogx2Gsf6ucSV-X
        • Wheelwizard
          Also Ricky Glaser got one and Bodhi comfirmed gradient tracking
          https://youtu.be/6B1P8H8hXQA?si=mfVhffHcYTb5eBLK
            @lia said in New XR!!!!:
            Thankfully this isn't considered a flagship board so I'm safe still making a tiny GTS.
            I'd have ripped around the Bellagio lobby till they chased me down and ordered me to stop! Was very interested in popping over to that place nearby to rent one last time. Needs to be plane friendly and TSA-approved.
              @notsure Technically, yes, but practically, no.
              Any conversion is going to have a loss component (heat). Stepping voltage down isn't so bad because you sip current to do that, but to step voltage up you need to draw more current, so you are pushing the batteries harder in addition to the waste.
              This is why the car charger requires a 24v, 10A capable cigarette lighter outlet, but still can only slow charge the board.
                @biell It was very much a theoretical inquiry - inspired by waves!
                  teardown vid by FixMyPEV
                  Wheelwizard 1 Reply Last reply Reply Quote 3
                  • Wheelwizard
                    Wheelwizard @LOAF last edited by
                    @loaffette from what he can see GT (not GTS) in an XR frame one of the comments said the motor is different but we shall see when that is confirmed by either Justin or probably TFL.
                    • Wheelwizard
                        Justin has done some science for the community to see if GT rails fit the XRC modules and vice versa.
                        TLDW; XRC modules will fit in GT rails but you won't fit a GT battery box in the XRC rails. Controller module will fit regardless.
                          legolas @Lia last edited by
                          WOW new beast!Like a lot!GT sux,too heayv
                          Diffrence:battry& rails
                          You made battery box for GT,rigth?Made 4 XR Classc! Would take 20 min 4you!
                          ,has same lid,proly same led window,just shallower.
