    17751
      @loaffette lookin great!
        the battery came off of it's mount after a jump off a curb and the LED wires snapped off 5 minutes into a ride
        I am going to do research into how to do wiring better lol
          Puzz360 XR Pint V1 @LOAF last edited by Puzz360
          @loaffette excellent job so far… šŸ‘
          I think now you have a working setup, hot glue and something like epoxy resin? would be good to set everything in place. A little permanent but would help I think… ???
          Edit…Heat shrink too
              Ok, update:
              tired
              This weekend I hope to make the first working and functioning prototype for my RGB headlight project. Found some resistors, buttons and a spare LED strip to use. I also got some actual wire for soldering, and I do plan on 3D printing out cable reliefs for the LED strip connections.
                Soldered the LED strips up today, and was gonna connect them to the arduino nano, until I realized that there is only one 5v rail on the Nano. Might either run a long wire from the 5V out on one strip and to the other one, or splice two power wires into one..
                    @loaffette Did a test ride last night!
                    Battery pack stayed on well during riding, and the lights stayed on. However, whenever I dropped off curbs, the battery just flew off. I think there needs to be a better system for connecting the battery to the system, maybe making a mount that matches the shape of the fender and uses double sided tape or a lot of command strips...
                    LEDs were nice, however they were not bright at all. Looking back at the code, I was unsure of how to make the LEDs brighter, and I am looking into trying to add a rainbow color mode to it. I'm trying to get the general system down before moving to making a wired remote. After I get the remote working, I will move to make a wireless remote.
                    also, a dumb idea but part of me want's to add IR LEDs so when someone takes a picture, they see ghost lights on the board >:D
                    Will need to talk with @cheppy44 about making the LEDs brighter through code. I know they can be brighter, but I'm unsure if it's my LEDs or something in the code..
                      Sirgu XR @LOAF last edited by Sirgu
                      Tell us more about that part.
                      -- Priorly I've been guessing the wavelength of IR LEDs only affect equipment aiming you in night vision mode. Since ppl out there late at night or in low-light urban structures likely snap you with their smartphones either just with flash function or without. They likely don't get that glare on picture.
                      Or I'm missing smth? >some reading<
                        @sirgu From what I remember, phone camera's in general are able to see IR light if they don't have a filter of some kind for it. Take a TV remote, point the front at your phone camera with the camera app open and hold down a button and look at it through the camera.
                        I'd need brighter IR LEDS or a lot of them, along with some testing but I do think that if I can get it to work, that it would be a cool effect.
                          @LOAFFETTE You are correct! I tested it with my old-school Pioneer remote (the only IR thingy in my household) -- the phone does spot a tiny ~3mm purple dot out of that 0.7x5cm reddish plastic strip. But it's far from any glare.
                          Oh, I get it now ... could it be that our interpretation about "ghost lights" were likely two different worlds?
                          E.g. dotted hidden messages/figures on OW fender can be cool as well.
                          From my perspective, the top notch effect lies in bright glare covering the whole unit without ever leaving the chance to guess out of its silhouette what's on the picture under the persons feet. For that purpose .. without the assistance of any night vision mode .. those IR LEDs better be darn powerful!
                            @sirgu I'm looking around, just seeing what's available
                            I want to get the brightest that I can run without a cooler and that I can run on a button cell battery!
                            I'm working to get a fender mounting kit for the LED kit along with seeing how I can get the lights to shine brighter
