    54628
      @notsure -- Pine indeed. Scrap pieces of 2x4 and half-inch plywood make up the fender/battery platform. Handy. Solid. No cost.
        An odd hack that has been working for me: For Onewheeling I have been strapping my leading arm under the wide elastic Velcro of the waist band of my Fox upper body armor. Thus I cannot automatically stick my arm out to try to break a fall. It's the stuck out arm that transmitted the force to break and shatter my collarbone in March 2022; once before I took a twenty-miles-per-hour fall directly on shoulder armor resulting in a sore shoulder -- but nothing broken or dislocated. The difference was not sticking my arm out. So far the tether has not been tested in an actual fall.
        In similar precaution, I took the Fangs off the OneDanXR and off my Onewheel Pluses because in case of a fall I do NOT want time to react -- I would rather trust my shoulder armor, hip armor, knee and elbow armor, wrist guards, and helmet to keep me from serious injury at high speed on asphalt-paved Greenway. However, I did put my Sonny Wheels Sliders back on my V1 because riding it in the grass exclusively at speeds topping out at 13 or 14 mph, extra reaction time in that case, at slower speeds, could be good.
          @s-leon hmmm coming from a north shore downhill mountain biking background, i have gotten adept at doing ninja rolls. i did a couple recently on pavement doing about 12mph (?) without padding and without losing anything but skin.
          not trying to brag, but just wanted to point out that the technique is to use your elbow and roll with the force in a somersault or cartwheel. having my arm strapped down probably wouldn't allow that and i'd be in worse shape.
          since you're all armored up, have you considered also getting a mountain biking neck brace? i have one for biking, and it saves you neck at the expense of a collar bone, which is worth it. but it needs to be used with a full face helmet.
                    @s-leon said in Hacks & Odds:
                    I loves me some smooooooth pavement!
                      The grassy avenue I have been riding my V1 on, and my Plus with its low-pressure, out-of-round tire, is oriented east and west. And the time I ride it tends to be evening, near sundown. The leg east is great fun, and slightly downhill. The other, return leg, has been blind -- although featureless -- heading straight into the sun. So, here's the solution I came up with: A ball cap under my skate helmet. It fits. And it does a remarkably good job of blocking the sun and letting me see the grassy avenue in beautiful sunshine.
                        When I asked the physician who put the metal strut in next to my collarbone, "What if I fall again?" His response was, "If I were you I'd worry about my hips!" -- probably in reference to research that showed that many old folk die within a year of breaking a hip.IMG_4461.JPEG
                        So, the same dancer/mountain biker who had gifted me the Fox Titan Sport jacket CE vest that I now wear, at the same time gave me SixSixOne knee and shin guards -- which I have found to cover hips and outer thighs nicely. A fall while averaging 20 mph would call for protection! -- Those are NOT the shoes I wear Onewheeling.
                          Had to walk today -- for the first time in a long time. A pull-stick I made from a fallen branch worked well for an easy drag the three and a half miles back to the car.
                          A contact blade on the adapter for the EGO battery got pushed in to the point of losing contact -- and I had no tools with me. I had stopped Onewheeling for a moment, the board powered off -- and then would not power back on.
                          Apparently contact-blade-movement on these adapters is a common problem, because once a while back the blades moved on a Sonny Wheels adapter I used, and now I see a blade retracting in on a LandSurf adapter I use.
                          My solution to the problem is pull the blade to where it should be, drill a hole through the 3D-printed-plastic and the blade, and put in a pin or a screw to anchor the blade -- being very careful not to short the connection by two opposite polar anchor screws touching deep in the plastic.
                          cheppy44 1 Reply Last reply Reply Quote 6
                            cheppy44 XR DIY @S. Leon last edited by cheppy44
                            @s-leon I found the perfect bucket for you!
                            If you flip it upside down it even spells out your name :p
                              The BadgerSense LED strip needed more than just the clips holding it onto to the baling wire sticking out from my sensor pad... So, I twisted the baling wire around the BadgerSense LED... The shadow of twisted wire is entertaining to look at as I ride -- ever changing!
                                @cheppy44 -- Finding the right fit of a can or a cooking pot as a Onewheel fender is surprisingly time-consuming. The only reason my stock pot fit was that I was using extended rails and a narrow 5.5 Hoosier tire, the combination of which allowed for the arc of the lip to not interfere with the sensor pad. The height, or depth, of the pot was a little bothersome for mounting batteries on top -- so, I was looking for a shallower cooking pot of the same dimension, and did not find one. For the convenience of easy modification I then went back to wooden fender/battery platforms.
                                  @s-leon yeah that one is a bit too narrow and tall, but when i saw it I thought of you and your stock pot fender and just had to share it. :)
                                    Covered with a 3'x5' piece of scrap metal siding that I found in the roadside ditch on the way to the Greenway, like in a locker I left my Onewheel Plus out-of-sight in the woods trailside. Turns out I did not like the awkward forty-plus pounds of Onewheel and EGO battery strapped to the back of the electric bicycle -- which likely means I would not like that weight strapped to an electric motorcycle either. Of course, I brought back the external EGO battery -- my Onewheel Plus's only power source. In the case of a predicted snowstorm this winter I will probably bike the Onewheel home ahead of time, too. In the meantime it will be interesting to see if I like the system of leaving the Onewheel alone by itself in the woods, just bringing a fresh battery to it on the bike... when I want to Onewheel the Greenway.
                                    Edit to add: With twelve miles logged on one day back riding my Onewheel Plus today, I am number 57 on the Plus Daystreak -- which seems not-too-bad for the number of Onewheel Plus riders the day after a late November holiday.
                                      @s-leon wow thats very bold just leaving it out there. or maybe im confused on what you are actually doing with it.
                                        S. Leon Plus V1 DIY XR @cheppy44 last edited by S. Leon
                                        @cheppy44 -- Yes, I left my Onewheel Plus in the woods rather than carry the heavy and awkward thing back strapped to my electric bike. Tomorrow I will ride the bike over, taking an EGO battery, and Onewheel the Greenway -- then bring the Plus home as heavy rain is predicted for Sunday... See the "Where's Onewheel" thread for a photo.
                                          Again! The other EGO adapter contact blade got loose, retracting in as I slid the battery on. (See photos in posts above.) No contact, the board would not engage. A somewhat long walk ahead, I decided to play with the blade and connection. Gingerly sliding the battery on, getting the motor to engage, I headed back, riding at walking speed across drought-dry, bumpy grass. Dumped by disconnection I was, sure enough, a few hundred yards later. Play again, ride again, dumped again -- but this time almost there.
                                          Back at the house I drilled into this blade through the plastic, 3-D printed housing and -- instead of inserting a metal screw like the other side -- I tapped in a plastic pin. Both contact blades now are good and solidly secured. I should have secured the second one long ago when I secured the first.
                                          Lia S. Leon 2 Replies Last reply Reply Quote 1
                                            @s-leon Hopefully that's the last time the connector causes any troubles :)
