    51078
      NotSure XR Pint @S. Leon last edited by S. Leon
      @s-leon said in Hacks & Odds:
      @S-Leon this thing is irreverently bonkers btw. no wonder u busted ass... u forgot the mattress. i mean what's that foot pad made out of?! a old keyboard? dear god. im gonna have a talk with Ruth Anne about this.
        @s-leon Off topic: You have an idea what a plus controller sells for nowadays? Got one, need buyer;)
          S. Leon Plus V1 DIY XR @MacIak last edited by S. Leon
          @maciak -- Two to three hundred dollars for a Onewheel Plus controller is what I have seen on Facebook.
          Is yours 3206 or 3208? I have two 3206 that I use, but I hear 3208 is more desirable.
            @s-leon 3206. Worked great always, just parted the board out. Battery box and hub is on the vesc now, cb+ and bumpers sold. Just need to get this controller a new home.
              Working on putting my Ignite Lifted Plus back in service, while switching over the BadgerSense I noticed the black rubber stall mat sections I was using for freewheel brakes were both cracked at the screws holding them on -- brittle and without much structural integrity! So, I went back to sections of rubber bicycle tire -- much better!
                @maciak -- Tell us more about your VESC -- either here or in the VESC thread.
                Like it? ...Meeting your expectations? ...Anything unexpected? ...Recommendations or advice?
                  MacIak DIY GT XR Plus @S. Leon last edited by MacIak
                  @s-leon Love it. But the Ennoid bms is acting up, it's actually not suitable i think. And the maker is a dick.
                  Will try to make a writeup when i have some time. Was/am planning on documenting a clean build.
                    @maciak -- Can you ride a VESC without a BMS? -- Like I can ride a Onewheel Plus without a BMS. Or maybe just use a BMS in charging?
                      @s-leon Yes, the idea is to use the bms charge-only anyway. The max battery amps for discharge are set in the vesc. I just like to see my cell balance status and battery temperature before/during/after ride on an experimental product. The rest of the board parameters are visible in the vesctool app.
                      External balancing would be great but a bit of a hassle to get 21 balance leads outside the battery box while still keeping it water-resistant.
                        @maciak said in Hacks & Odds:
                        This. Saves needing all that extra space for the fets and heat management.
                        I think most of the DIY eSk8 guys prefer charge only too for this reason along with them generally being much cheaper.
                          Riding my V1 at slower speeds in the grass today I was missing the feeling of the pushback. So, to simulate the pushback stance feeling I put the V1 in Elevated mode -- my back, hips, legs, and feet like it.
                          On the OneDanXR I have the opposite problem, a lower trailing foot than is comfortable. First I tried a thick shard of foam grip-tape just stuck on the footpad, but it wasn't really enough. So here's the hack: A flat skate shoe on the leading foot -- and a thicker clog with a bit of a heel on the trailing foot. Riding the OneDanXR is much more comfortable now with two different shoes, specifically chosen for the purposes -- and the BadgerSense tells me at a glance that I still have plenty of battery power available in reserve, even riding the pushback.
                          On my Leaderboard Plus with no battery underfoot I just built a custom trailing footpad out of three-quarter-inch? plastic wood with a wide strip of black rubber stall mat, about a full quarter-inch thick, on top. The combination is nicely comfortable with matching flat skate shoes -- but the ride does get uncomfortable for any length of time below pushback speed.
                            This hack continues to amaze me: An eight pound 10ah EGO battery so far forward rides well. One photo is to get the sense of where the heavy battery sits in relation to the whole board -- and remember there is NO weight/NO battery under the trailing footpad, so ALL the weight is forward. The other photo is from above, to picture where the battery sits in relation to my leading foot -- note that I strap the battery so that my foot cannot dislodge it up from the contacts of the non-locking LandSurf adapter. Note, too, that while this looks like a Onewheel Plus, it is actually my V1 with Plus rails and an XR sensor pad -- but I have used this same fender/battery set-up with my Plus, too, as the sole-and-only power source.
                              is that pine? looks like pine...
                                @notsure -- Pine indeed. Scrap pieces of 2x4 and half-inch plywood make up the fender/battery platform. Handy. Solid. No cost.
                                  An odd hack that has been working for me: For Onewheeling I have been strapping my leading arm under the wide elastic Velcro of the waist band of my Fox upper body armor. Thus I cannot automatically stick my arm out to try to break a fall. It's the stuck out arm that transmitted the force to break and shatter my collarbone in March 2022; once before I took a twenty-miles-per-hour fall directly on shoulder armor resulting in a sore shoulder -- but nothing broken or dislocated. The difference was not sticking my arm out. So far the tether has not been tested in an actual fall.
                                  In similar precaution, I took the Fangs off the OneDanXR and off my Onewheel Pluses because in case of a fall I do NOT want time to react -- I would rather trust my shoulder armor, hip armor, knee and elbow armor, wrist guards, and helmet to keep me from serious injury at high speed on asphalt-paved Greenway. However, I did put my Sonny Wheels Sliders back on my V1 because riding it in the grass exclusively at speeds topping out at 13 or 14 mph, extra reaction time in that case, at slower speeds, could be good.
                                    @s-leon hmmm coming from a north shore downhill mountain biking background, i have gotten adept at doing ninja rolls. i did a couple recently on pavement doing about 12mph (?) without padding and without losing anything but skin.
                                    not trying to brag, but just wanted to point out that the technique is to use your elbow and roll with the force in a somersault or cartwheel. having my arm strapped down probably wouldn't allow that and i'd be in worse shape.
                                    since you're all armored up, have you considered also getting a mountain biking neck brace? i have one for biking, and it saves you neck at the expense of a collar bone, which is worth it. but it needs to be used with a full face helmet.
