    Trace Map Continued
    44
    16283
      Planning on picking this up again as I want to make a better XR but while doing a bit of casual research for another project I found I'm not the only one that managed to clone this PCB.
      Take a look at the one on the left and then compare it to the pic of an XR controller on the right.
      Bear in mind the current sensing chips beside the motor connector are actually also the same as on the V1/Plus. Everything is the same, down to some of the silk screening.
      So what is it? It appears to be a controller for an EUC back from 2016. I found the image on a forum (linky). Image courtesy of esaj.
      I did a bit of digging and traced the company called HopeMotion whose website no longer exists but archive.org got a few links saved. https://web.archive.org/web/20160308233001/http://hopemotion.com/
      The company states in 2013 it "is mainly engaged in the development and industrialization of high-efficiency and energy-saving motors, drivers, and controllers for electric vehicles. The company has a group of high-quality R&D and management teams".
      I assume FM either worked with them or had them manufacture their initial runs in which the PCB design got yoinked. The only information regarding the cloned PCB starts in 2016 which is well after the kickstarter for the Onewheel completed and a year before the Plus.
      Anyone know more about this? Maybe worth it's own topic if there's more to this.
      I did initially assume this may have been related to the CES incident back in early 2016 but I couldn't find a connection.
      Anyway in other news I've managed to get my hands on a 4212 PCB (for a repair I'll post about another day) so I can work on redoing the design on a more modern layout minus the stuff that bricks modding.
      This redesign was more sensibly designed with no need for the large power wires jumping the PCB. Also the motor and footpad sensor connectors got a well needed reinforcement.
      T LOAF 2 Replies Last reply Reply Quote 3
        tribacon @Lia last edited by
        @lia I saw you missed C68 on your pcb, I’m dealing with a 4212 board that C68 appears to be bad. Do you happen to know what capacitor it is so I could order one to try and replace it? I’m pretty new to this and can’t seem to find anybody other than you who has posted so much and has the knowledge like you seem to have so figured it was worth the ask.
          Lia GT XR Pint Plus V1 DIY @tribacon last edited by
          @tribacon No problem. Just pulled up my schematic and I have C68 down as a 2nF 0603 capacitor :)
          Good luck with the repair!
          T 2 Replies Last reply Reply Quote 0
            tribacon @Lia last edited by tribacon
            @lia Awesome thanks! Now to hopefully find some local so I don’t have to order 4000 from Newark!
            Started with the Error 21 issue!
              I finally fixed it! Turns out past Lia sucked at reflowing. A few chips had pins that looked connected but weren’t and the IMU wasn’t fully hooked up.
              But now I finally have it booting up 🥰
              I guess now I should probably consider putting it in a board and taking it for a spin then maybe make some upgrades!
              A 1 Reply Last reply Reply Quote 6
                Atlowshop @Lia last edited by
                @lia This is some insanely awesome work! I haven't used forums in forever and just registered to applaud your work! I wish I had known about this and I could have helped you with component values, trace maps, x-rays, etc. I have heard your name came up multiple times now in this space and every time it's something amazing, Hope to one day be able to meet you!
                  Lia GT XR Pint Plus V1 DIY @Atlowshop last edited by
                  @atlowshop Thank you 🥰 If you're ever in the UK lemme know ^-^
                  Might be taking a swing at the GT next. Would be fun to try putting an XR chip on a GT controller or other ay around and see what diabolical creature I can build.
                    @lia I don't know if you're interested in it, but I have my old XR BMS if you want it
                    It's a little toasty but it still powers on!
                      @loaffette Thanks for the offer. I have a few at the moment so should be fine 🥰 Appreciate the offer though. Toasty in what way though? Got me curious about that bit :3
                      Haven’t had the desire to take a swing at the bms but it might be worth it since I’ve had to fix 3 of them without schematics.
                          @loaffette Ooooh my gosh that is toasty! I’m amazed it still powers on! Gimme a poke in DM’s if you want anything for it 😊
                            @lia so it wasn't c68. Ended up VESCing the board. But kept controller and bms. Took some time today to check out the controller board and I'm wondering if this isn't my culprit for 21 error.
                            Happen to know what this component is?D4 on XR controller
                              Lia GT XR Pint Plus V1 DIY @tribacon last edited by Lia
                              @tribacon D4 is a diode to stop voltage being present at the charger when the board is powered on. Without this it won't charge.
                              https://www.vishay.com/docs/89000/ss10ph10.pdf
                              T 1 Reply Last reply Reply Quote 0
                                @lia thanks! Gives me something to shoot for swapping and seeing if I can throw together another board!
                                I also think D21 next to c68 looks a little swollen. So probably gonna swap that too while I'm at it.
