    Reflashing a OW bms
    4525
      @lemur I've got a 4209 BMS that I'd love to test in my XPint.
      Is it simple to do?
      L 2 Replies Last reply Reply Quote 1
        @lia You need a Pic tool, mplab ipe and a tutorial. That Jw chip is just for an extended Xr battery and the photo has the green wire broken off, it was on during flashing.
        https://github.com/radimklaska/onewheel/blob/master/bms-firmware.md
        https://www.microchip.com/en-us/tools-resources/production/mplab-integrated-programming-environmentIMG_6933[1].jpg
          me_josh @Lemur last edited by
          @lemur yo so you can put an XR in a pintx frame and have it run on pintx battery?
            Lemur @me_josh last edited by
              @me_josh Not sure what you mean, but a Xr controller doesn't fit in a PX frame. and bms's don't pair.
                @lia I think I misread your question. I haven't tried reflashing a PX bms with XR firmware. I believe the PX bms is read protected and you cannot extract the hex file, you should be able to overwrite the Px bms with XR firmware but cannot go back to PX .
                  @lemur Aha it's okay. I've got an XR BMS that I was considering pairing with an OG Pint controller but just increasing the cells to 2p setup. No PintX involved but I do want to give it the range of one with a bigger bat at some point.
                    tekshalcre @Lemur last edited by
                    @lemur how do I go about pairing a pint bms on to my xr I'm curious what I need to do exactly.
                    L Cloud 2 Replies Last reply Reply Quote 1
                    • Cloud
                      Cloud @tekshalcre last edited by
                      @tekshalcre This may help you
                      https://klaska.net/onewheel/bms-firmware/
                        Lemur @tekshalcre last edited by Lemur
                        @tekshalcre You need to physically change the Pint bms firmware to XR bms firmware with hardware and software. Read this first and I have the XR hex files when you need it.
                        When you get all that done. you can pair the converted xr bms to the 4212 with nrf.
                        T B 2 Replies Last reply Reply Quote 1
                          @lemur so I will need to purchase that pickit to flash the xr hex files to the pint bms then pair using nrf right is that what I'm understanding correctly
                            @tekshalcre yes, you will get a error code when you install the flashed Xr bms but just use nrf to pair
                              sdmods @Lemur last edited by
                              @lemur I got a PICKIT and MPLABX IPE Program and I get this error when flashing Pint hex to XR BMS:
                              The program file could not be loaded: "The line checksum on line 2086 of the hex file is incorrect; the hex file appears to have been corrupted.
                              :080000000000010019009D0015"
                              I also get:
                              Erasing...
                              Erase successful
                              2023-12-17 23:43:53 -0800 - Programming...
                              Device Erased...
                              Programming...
                              The following memory area(s) will be programmed:
                              MPLAB's memory is blank so no programming operation was attempted.
                              2023-12-17 23:43:57 -0800 - Programming complete
                              *** Hold In Reset mode is enabled ***
                                Lemur @sdmods last edited by
                                @sdmods Where did you get the Pint hex file?
                                  bradster3 @Lemur last edited by
                                  @lemur not to bring a sub back from the dead, but you know where i can find the xr bms files. I had a old xr bns i pulled the hex from with no lock but it got messed up somewhere. I have a brand new pint bms and when i try to push the hex the ow does nothing, does not turn on, no light, nothing. Im guessing the hex is bad because the old error was the board wouldnt turn off....guess i found the root issue. If you could point me in the right direction i would be greatful since i cant ride if no power lol.
