    V1 -- Original Onewheel
    v1
    10106
      @lia -- This evening after switching the orientation of the adapter to hold the EGO battery, instead of a stubby screwdriver -- which proved too long -- I used a valve stem tool, friction-fit into a hole drilled in the wood of the fender. With it in the battery seems very secure. Still I plan to strap the battery tight, as well, because that provides two moorings holding the fender tight to the rails.
      Edit: Added photos under the tag.
        Ha! Popped off, it did, and got lost (the valve stem tool in the photos). Now I use three yellow plastic wire nuts friction fit in half inch holes drilled in the wooden platform/fender to butt up against the end of the EGO battery, securing it in position.
          @s-leon Holy crap, I forgot those existed!
          I remember doing a lot of those in my Cub Scout years, going on campouts and finding geocaches everywhere! Stopped doing it as a Boy scout though since at those camp outs, there's usually something else to do and a work to do. The last one I saw on a campout was during a canoeing camp out
            @s-leon His board is powered by a nuclear reactor or got struck by lightning
              @s-leon if it works, it works!
                The nose of the board is at the bottom of the photo. The EGO battery in secured slide adapter is cantilevered over the high arch of my foot. The three yellow wire nuts friction fit into half inch holes in the plywood keep the battery from sliding out. Simple but effective.IMG_4812.JPEG
                In sixteen Onewheel miles yesterday on the Greenway somehow this board did not feel as comfortable as it should -- keep in mind I hadn't ridden this V1 since the worn-out flat tire last autumn -- then, cleaning my car I found the clog-with-a-raised-heel that I remember it takes to make my trailing foot relaxed while riding on the V1.
                  Happy to see the V1 again :) Might have to take mine for a spin again.
                  @s-leon said in V1 -- Original Onewheel:
                  Do you prefer the clog over an angled footpad? I’ve retired my old boots and been using flats which I notice my feet getting tired way sooner.
                    Hi @lia -- In a word, Yes! Even a slightly raised heel can make a lot of difference. It's whatever makes your legs and tendons happy. With my narrow Onewheel stance an angled footpad does not help. So then, riding pushback habitually, I made my own angle by affixing a piece of thick, surfboard grip to the trailing footpad so I stand on it with the outer edge of the ball of my foot. That then made my heel slightly and uncomfortably lower. The thick rubber, heeled clog makes up for it. Of course, on the leading foot I am wearing a no-heel rubber clog... what can I say... each of the two feet have different jobs to do!
                      All my ones and zeros yesterday:IMG_4836.jpeg
                        And today a long string of ones:IMG_4863.JPEG
                          V1 with Onewheel Plus rails -- heavy and awkward on the bike at a standstill or walk, although not especially noticeable at cruising speeds.IMG_4950.JPEG
                            @s-leon This picture makes me happy, it's just a perfect blend of function, ingenuity and still with style.
                              @lia -- If that one makes you smile, this one might, too:
                              A nearly identical bike... with a nearly identical Onewheel. Each Onewheel is in a long-term relationship with its own electric bicycle. Both sets of batteries are switchable -- bike-to-bike and Onewheel-to-Onewheel. This one, of course, is not a V1, this one is my Onewheel Plus.
                              Lia Sirgu 2 Replies Last reply Reply Quote 4
                                @s-leon Both having their own bike companion just made this so much better 🥰
                                  If I ride my V1 early enough in the day now, it shows up at #5 on the V1 Daystreak -- then later toggles to #6 when Diovyon rides and edges a day ahead. As long as I have more miles logged than they do in the streak, I can share the position.
                                    @s-leon said :
                                    ... If that one makes you smile, this one might, too ...
                                    It does! .. a lot.
                                    More precisely ... the picture gives me endless chuckles!
                                    Can't help but asking away -- Does the bench really reads :
                                    ------------------- IN HONOR to ----------------------
                                    --- CHUCK NORRIS and DAVID CARRADINE ---
                                    ? :D
                                    Sorry for a little bit of off-topic, @S-Leon
                                    S. Leon LOAF 2 Replies Last reply Reply Quote 5
                                      @sirgu -- Well... can't say I can confirm your interpretation of the names on the Greenway bench... but then I won't deny it either... !!!
                                        @sirgu I wholeheartedly believe this to be the actual words on the bench, and nothing else
                                          In the app for my V1 battery percentage I got a huge negative number yesterday: " -25,136%"
