    17751
      @cheppy44 It's possible and would be cool but that's a huge leap
      I'm still at the phase of trying to figure out where to mount all of this stuff and seeing if I can get the code down. Maybe when I have mounting down and I have code that works then I'll look into it.
      You don't build the rocket if you don't know if it will take off
      Thanks for the recommendation though!
        The beauty of the engineering process!
        So, I got the clips to stay on, found the right clip model that works, and it sticks pretty well!
        So, I printed this puppy out!
        LEDs would mainly face the ground but also back and fourth for the initial design. Need to add some more width so the LED strip and fit inside but it works for a proof of concept.
        I stuck a pair on my board without the strips, and just rode through the day.
        They looked fine
        until..
        awfuck
        Welp.
        So, it got completely olbiterated. The clip also shifted around a lot, and the LED strip would have been shredded into little strips (hah) if I had them on there.
        The next idea could be under the fender actually.
        Kind of like a lighting kit for a car or something.
        The only problem would be leaves, dirt and water but I could probably put them in an enclosure or something.
        I've been thinking about the footpad idea and I might work on that later, maybe during the summer when I have some more time and I have a summer job.
        Got the code down, but there's an issue with making the LEDs blink continuously.
        No luck with making the code work with buttons and stuff, so I'll have to either ask a programmer friend to cook something up or just keep at it
          @loaffette what controller are you using with the LEDs? I am more than willing to try and help out with your code!
            @cheppy44 probably an arduino Nano or something small.
            I have an uno that I could use for testing if I can get a printer cable (Not serial/parell) but I wouldn't take it out on a ride and I'm unsure if it works.
            The code:
            #include <Adafruit_NeoPixel.h>
            int buttonPin = 4;    // momentary push button on pin 0
            int oldButtonVal = 0;
            #define pixels 8
            #define PIN 3    // Parameter 1 = number of pixels in strip
            Adafruit_NeoPixel strip = Adafruit_NeoPixel(pixels, PIN, NEO_GRB + NEO_KHZ800);
            int nPatterns = 2;
            int lightPattern = 1;
            uint16_t currentPixel = 0;// what pixel are we operating on
            uint16_t led=0;
            unsigned long previousmillis = 0;
            unsigned long time = 50;
            void setup() {
              strip.begin();
              strip.show();                // initialize all pixels to 'off'
              currentPixel=0;                           // initialize the BUTTON pin as an input
              pinMode(buttonPin, INPUT);
              digitalWrite(buttonPin, HIGH);  // button pin is HIGH, so it drops to 0 if pressed
            void pattern1() {
             strip.setPixelColor(0, 255,255,0);
             strip.setPixelColor(1, 255,255,0);
              strip.setPixelColor(2, 255,255,0);
              strip.setPixelColor(3, 255,255,0);
             strip.show();
             delay(10);
              strip.setPixelColor(0, 0,0,0);
             strip.setPixelColor(1, 0,0,0);
              strip.setPixelColor(2, 0,0,0);
              strip.setPixelColor(3, 0,0,0);
             strip.show();
             delay(10);
            // Pattern 2 - Red light, all LEDs in the strip are red
            void pattern2() {
              strip.setPixelColor(led,0,0,255);
              strip.show();
              led++;
              if(led == pixels){
                led = 0;
              currentPixel=0;
            // the loop routine runs over and over again forever;
            void loop() {
              // read that state of the pushbutton value;
              int buttonVal = digitalRead(buttonPin);
              if (buttonVal == LOW && oldButtonVal == HIGH) {// button has just been pressed
                lightPattern = lightPattern + 1;
              if (lightPattern > nPatterns) lightPattern = 1;
              oldButtonVal = buttonVal;
              switch(lightPattern) {
              case 1:
                if ((unsigned long)(millis() - previousmillis) >= time) {
                  previousmillis = millis();
                  pattern1();
                  break;
                case 2:
                    pattern2();
                    break;
              cheppy44 XR DIY last edited by cheppy44
              I figured the issue you are having with the lights strobing. In your pattern1 you have delay(10) which will only delay it for 10 milliseconds. I changed the 10 to 1000 for one second and here are the results.
              I also recommend changing your "time" variable name to something else such as "timer". There are certain variable names that are reserved for other things.
              Check out the Neopixel Uber Guide for a bunch of information about the leds and the library. For example you can set the whole "strip" to a color with a single line of code, instead of having to create a function to iterate through the addresses.
              https://learn.adafruit.com/adafruit-neopixel-uberguide/arduino-library-use
                @cheppy44 You are a life saver, holy crap
                all I need to do is add a part so if I use a second button, I can control the other four LEDs
                  Puzz360 XR Pint V1 @cheppy44 last edited by Puzz360
                  @cheppy44 good find…. 👍
                  Typical… NOT available on Amazon UK or EBay UK !!!
                  Edit…. Found it in RS;)
                  I think maybe sticking one on the helmet and using voice commands could be an idea, easy to keep PSU and device safe top end (hopefully).
                    cheppy44 XR DIY @Puzz360 last edited by
                    @puzz360 let me know how it goes! I am tempted to pick a few up to experiment with.
                      @cheppy44 struggling with the code currently. Trying to have two button inputs and two switch functions but nothing is working for the other LEDs
                        @loaffette what are you trying to have the buttons change?
                          @cheppy44 if I understand your question correctly, I want one LED to control half of the LEDs (for the left side), and another button control the other half (right side)
                            @loaffette ahh ok so you want 1 button each for a left turn and a right turn.
                              @cheppy44 yep!
                              And I don't know how to get that to work
                                @loaffette I am setting up the electronics to try and write the code for it. I might start from scratch with the code, but I can try to explain the code I end up writing! I dont exactly want to rob you of learning how to do this, but it sounds like a fun small project to work on for me.
                                  @cheppy44 Thanks man!
                                  I really owe you for this one! I'm pretty bad at programming and this really helps!
                                  I'll probably get around to building a controller for this and designing a mount for the arduino and the LEDs. Found that under the fender is the only safe bet for now, and the footpad would be a pain.
                                  May look at doing on the fender itself (On top) could be an option.
                                  cheppy44 2 Replies Last reply Reply Quote 1
                                    @loaffette here is a demo! still working out a few kinks
                                      cheppy44 XR DIY @LOAF last edited by Lia
                                      @loaffette
                                      Here is the code I made! it uses 2 buttons and has 2 outputs for a front and a rear strip. Depending on what controller you use, you may have to set up the button inputs a bit differently. The ESP 32 I am using has Internal Pull up/down resistors for the inputs. I attempted to comment my code pretty good so you can attempt to learn a bit if you feel like it. If you've got any questions or want me to make some changes I am more than willing to help you out!
                                      #define PIN1        12  // Pin for Front Strip
                                      #define PIN2        13  // Pin for Rear Strip
                                      #define BUTTON_PIN2 19  // Pin for Button 2
                                      #define NUMPIXELS   9   // Number of Neopixels in each strip
                                      void setup() {
                                        Serial.println("begin");
                                      void loop() {
                                        if (buttonState1 == LOW) {
                                          // turn left turn signal on
                                          strip1.fill(yellow, 5, 4);
                                          strip1.show();
                                          strip2.fill(red, 0, 4);
                                          strip2.fill(yellow, 5, 4);
                                          strip2.show();
                                          strip1.fill(white, 5, 4);
                                          strip1.show();
                                          strip2.fill(red, 5, 4);
                                          strip2.show();
                                          delay(500);
                                        } if (buttonState2 == LOW) {
                                          // turn right turn signal on
                                          strip1.fill(yellow, 0, 4);
                                          strip1.show();
                                          strip2.fill(yellow, 0, 4);
                                          strip2.show();
                                          delay(500);
                                          strip1.show();
                                          strip2.show();
                                          delay(500);
                                        } else {
                                          // turn leds back to "normal"
                                          //Serial.println("normal");
                                          strip1.show();
                                          strip2.show();
                                      delay(50);
                                      LOAF 2 Replies Last reply Reply Quote 4
                                        @cheppy44 thanks man!
                                        This really helps me out with getting this going!
                                        I'll give the code a spin in Tinkercad when I have time later tonight!
                                          Got the button code translated to work for the Arduino! Just had to change (INPUT_PULLUP) to (INPUT).
                                          Tinkercad simulator is a bit broken though currently, and it's running slow. I'm gonna go and try to find a USB cable for the arduino and test it using real hardware instead.
                                          Again, thank you so much for helping me out with the code!
                                            LOAF XR last edited by LOAF
                                            No dice yet.
                                            The arduino isn't recognizing the button press.
                                            Gonna try and see what I can chagne or what I can do
                                            Changed the } if (buttonState2 == HIGH) {
                                            to LOW instead of high, and found that when I hold it down, it pauses the flashing
