    17753
      @cheppy44 struggling with the code currently. Trying to have two button inputs and two switch functions but nothing is working for the other LEDs
        @loaffette what are you trying to have the buttons change?
          @cheppy44 if I understand your question correctly, I want one LED to control half of the LEDs (for the left side), and another button control the other half (right side)
            @loaffette ahh ok so you want 1 button each for a left turn and a right turn.
              @cheppy44 yep!
              And I don't know how to get that to work
                @loaffette I am setting up the electronics to try and write the code for it. I might start from scratch with the code, but I can try to explain the code I end up writing! I dont exactly want to rob you of learning how to do this, but it sounds like a fun small project to work on for me.
                  @cheppy44 Thanks man!
                  I really owe you for this one! I'm pretty bad at programming and this really helps!
                  I'll probably get around to building a controller for this and designing a mount for the arduino and the LEDs. Found that under the fender is the only safe bet for now, and the footpad would be a pain.
                  May look at doing on the fender itself (On top) could be an option.
                  cheppy44 2 Replies Last reply Reply Quote 1
                    @loaffette here is a demo! still working out a few kinks
                      cheppy44 XR DIY @LOAF last edited by Lia
                      @loaffette
                      Here is the code I made! it uses 2 buttons and has 2 outputs for a front and a rear strip. Depending on what controller you use, you may have to set up the button inputs a bit differently. The ESP 32 I am using has Internal Pull up/down resistors for the inputs. I attempted to comment my code pretty good so you can attempt to learn a bit if you feel like it. If you've got any questions or want me to make some changes I am more than willing to help you out!
                      #include <Adafruit_NeoPixel.h>
                      #define PIN1        12  // Pin for Front Strip
                      #define PIN2        13  // Pin for Rear Strip
                      #define BUTTON_PIN2 19  // Pin for Button 2
                      #define NUMPIXELS   9   // Number of Neopixels in each strip
                      void setup() {
                        Serial.println("begin");
                      void loop() {
                        if (buttonState1 == LOW) {
                          // turn left turn signal on
                          strip1.fill(yellow, 5, 4);
                          strip1.show();
                          strip2.fill(red, 0, 4);
                          strip2.fill(yellow, 5, 4);
                          strip2.show();
                          strip1.fill(white, 5, 4);
                          strip1.show();
                          strip2.fill(red, 5, 4);
                          strip2.show();
                          delay(500);
                        } if (buttonState2 == LOW) {
                          // turn right turn signal on
                          strip1.fill(yellow, 0, 4);
                          strip1.show();
                          strip2.fill(yellow, 0, 4);
                          strip2.show();
                          delay(500);
                          strip1.show();
                          strip2.show();
                          delay(500);
                        } else {
                          // turn leds back to "normal"
                          //Serial.println("normal");
                          strip1.show();
                          strip2.show();
                      delay(50);
                      LOAF 2 Replies Last reply Reply Quote 4
                        @cheppy44 thanks man!
                        This really helps me out with getting this going!
                        I'll give the code a spin in Tinkercad when I have time later tonight!
                          Got the button code translated to work for the Arduino! Just had to change (INPUT_PULLUP) to (INPUT).
                          Tinkercad simulator is a bit broken though currently, and it's running slow. I'm gonna go and try to find a USB cable for the arduino and test it using real hardware instead.
                          Again, thank you so much for helping me out with the code!
                            LOAF XR last edited by LOAF
                            No dice yet.
                            The arduino isn't recognizing the button press.
                            Gonna try and see what I can chagne or what I can do
                            Changed the } if (buttonState2 == HIGH) {
                            to LOW instead of high, and found that when I hold it down, it pauses the flashing
                              @cheppy44 So I messed around a bit with the code to try and make it work
                              Added a fuction that would print to the console if button two wasn't pressed.
                              I don't have anything plugged into the pin for button 2 or 1 and it's reading that button one is pressed..
                              Could my arduino be messed up?
                              what board are you using, I might try and buy the board you have instead.
                              Also, when I have the button plugged in and I hold it down, the LEDs stop flashing but are stuck on red
                                @loaffette I am using an ESP 32 dev module, but I would not recommend it if you want to implement this on your board. I have a suspicion your issue has to do with pull up/down resistors. Could you post a picture of what your electronics looks like? The purpose of the resistors is to give the digital inputs a default state. If you leave them unconnected or “floating”, they are subjected to back ground electronic noise and are not reliable. Some micro controller have certain pins that have internal resisters that you can enable.
                                  @cheppy44 I may have forgotten about the resistor...
                                    @loaffette the controller you have may have internal pull up you can enable, that was why I was asking what your electronics situation looks like.
                                      @cheppy44 I'm using an Arduino Uno, a button and two separate LEDs (4 leds per strip.)
                                      Going to add the resistor.
                                      Also, I had a cool idea to add on to it later on that would change the color of the LEDs depending on how fast I'm going, or how fast the motor is spinning
                                        @loaffette that will be interesting! You would probably need an IMU to tell how fast you are moving.
                                          @cheppy44 I actually have one lying around
                                          So i tested it in tinkercad since I don't have any resistors IRL. It works with the pulldown, but only button 2 seems to be detected currently.
                                          Also, I had to change the code up for the LED so that strip 1 is for the left, and strip 2 is for the right since I'm going to be placing them under the fender for now
                                          Updated code:
                                          #define PIN1        3 //Pin for Front Strip
                                          #define PIN2        2  // Pin for Rear Strip
                                          #define BUTTON_PIN2 5  // Pin for Button 2
                                          #define NUMPIXELS   4   // Number of Neopixels in each strip
                                          void setup() {
                                          void loop() {
                                              strip1.show();
                                              strip2.show();
                                              strip1.fill(white, 0, 3);
                                              strip1.show();
                                              strip2.fill(red, 0, 3);
                                              strip2.show();
                                              delay(500);
                                              //strip1.fill(white, 5, 4);
                                              strip2.show();
                                              //strip2.fill(yellow, 0, 4);
                                              strip1.fill(red, 0, 4);
                                              strip1.show();
                                              delay(500);
                                              strip2.fill(white, 0, 4);
                                              strip2.show();
                                              strip1.show();
                                              delay(500);
                                            } else {
                                              strip1.show();
                                              strip2.show();
                                          delay(50);
                                          Update:
                                          Checked the serial output and it does detect the button press, but nothing is changing with the LEDs
                                          update update:
                                          Code works! :) Copied code from the rigth blinker and copied it into the if statement for the left blinker and changed strip1 to strip2 and vice-versa
                                          iam smort
                                            @loaffette sweet! the strip.fill commands are pretty useful when you know how to use them.
