    XR board with dead MCU?
    1953
      MK_ last edited by
      I have a XR board which has the following symptoms:
      • It doesn't turn on at the press of a button
      • When charger is connected, it appears to charge fine (light turns red on the charger)
      • When charger is connected, app sees the board, which seems to mean the bluetooth module is fine, however, it is unable to fully connect to the board (stuck on activating...)
      I have taken the board apart and the battery does appear charged, BMS looks good.
      Main board also looks good visually, I haven't yet starting probing voltages. (I'm a EE so fairly comfortable with this)
      Question to the forum, have you guys come across these symptoms?
      My initial though is the main micro is not coming up. Could be something with the power rail (I don't know at this point if the BLE module is on the same rail as the MCU).
      Thanks for any info as it will invariably shortcut my troubleshooting steps.
      Cheers.
      _MK
      Lia LOAF 2 Replies Last reply Reply Quote 1
        Lia GT XR Pint Plus V1 DIY @MK_ last edited by Lia
        @mk_ Can you probe both ends of the blue wire on the battery harness with a mustimeter n diode mode to verify if there is a break in the cable. The blue wire is what connects the power button all the way back to the BMS to turn it on.
          MK_ @Lia last edited by MK_
          @lia Thanks. The whole harness Ohms out OK.
          Maybe this is a BMS issue after all; when I press the power button on battery only the voltage never gets to the power connector going toward the main board.
          _MK
            MK_ last edited by
            Q15 seems suspect. Ohming out base, junction and collector I’m measuring open circuit between two pins.
            I’m coming up dry on the PN of the transistor. Not sure if Q15 could explain the behavior.
            Also; the board came up on the app this time.
            Battery shows 1% SoC even though voltage is 61.5V.
            My suspicion has moved to BMS.
            _MK
              LOAF XR @MK_ last edited by
              @mk_ A smiliar issue like yours happened when I got water in my battery box. I would check for water in your battery box, or check the health of your BMS/Battery
              M 1 Reply Last reply Reply Quote 0
                MK_ @LOAF last edited by
                @loaffette thanks. I don’t visually see any damage aside from a discoloration around Q15. That in itself doesn’t seem like a smoking gun. Ohming it out makes me think Q15 is damaged.
                Do you have any info on recommendations for verifying the BMS health?
                _MK
                  @mk_ for me, I found that letting the BMS and battery dry out, wiping them down of any water, along with the internals of the battery box helped. I'm not an expert in electronics repair, but within a couple hours I had a working board
                    I took some iso to a pair to check. Q15 on the BMS appears to be marked with 1A with either a J or 4 marked sideways. I didn't find much for 1AJ but did for 1A4. Both appears to be a SOT-23 package.
                    BMS 1
                    BMS 2
                    A little googling claims this is an NPN medium power transistor. Here's a selection: https://www.s-manuals.com/smd/1a
                    This one is specifically for 1A4.
                    https://www.s-manuals.com/pdf/datasheet/z/x/zxtn25040dfh_zetex.pdf
                      @lia Thank you! This helps. I'll get some of these from DigiKey and see how far that gets me.
                      In the interim, I poked around the BMS some more.
                      When I connect power to the battery connector (external supply plugged into battery connector) and trigger the power button I briefly get a 5V coming out of the power supply but it shuts off after only a few seconds.
                      Q2 (large FET on the battery side) Ohms out OK (high impedance between pins), but I get no output on the Source pin when triggering power on. (I read the input power on the Drain pin (the fat pad of the transistor) but the transistor doesn't get turned on when power button is applied to get the power to the rest of the board.
                      Q12 (large FET on the controller side) appears dead; measuring a source to drain short circuit there.
                      Any thoughts from the community appreciated as to where to poke around next.
                      Cheers.
                      _MK
                        MK_ @MK_ last edited by
                        Thanks for your help, everyone, my board is back up and running.
                        I swapped out Q15 and Q12, both of which Ohmed out broken.
                        What's interesting to note was that when I first assembled the board I got a warning that my battery is dead (below 10%) and it was showing 1% on the app so I figured there is more to do. I then plugged it into a charger to see what happens and within a minute the battery went to 99% and I went for a ride. Pretty stoked.
                        Lia K 2 Replies Last reply Reply Quote 5
                          @mk_ Congrats on the repair!
                          Regarding the battery percentage that sounds typical for a BMS like this. I wouldn't worry about that, just the gas gauge reading needed resetting via a charge cycle :)
                          Float on ^-^
                            kallepetter @MK_ last edited by
                            @mk_ great work. Will investigate if I have same problem. Did you buy the transistors Lia suggested or which kind did you replace them with?
                              MK_ @kallepetter last edited by
                              @kallepetter Sorry for a late reply.
                              I ended up going with a higher voltage rated replacement for Q15:
                              https://www.mouser.com/ProductDetail/522-ZXTN19100CFFTA
                              This is the stock one:
                              https://www.mouser.com/ProductDetail/621-ZXTN25040DFHTA
                              For Q12, I got these:
                              https://www.mouser.com/ProductDetail/595-CSD19536KTT
