    Rebuilding a 4206 Xr
    2035
      @lia I tried another bms and the same result, but I'll open up the the battery box and check for voltage.
      I will also check every small wire on the harness for continuity when i have it apart next time., I only repaired the orange rear light wire and didn't check the other wires.
      I believe that this older board can charge by the wall charger when it's turned on because of the third wire(yellow/green) as "regen" .
      Thanks for the suggestion.
        @lemur At a loss there. Fingers crossed it's that diode!
          @lia Yea! Figured it out, you were right about the bms not being triggered, it's a broken wire to the bms. I hooked up a XR harness that I made that is proven to work and used a different battery as the one in the board is at 100%. I'll check which wire is broken and go from there, thanks.IMG_6015-1.jpg
            @lemur Nice one!
            Gonna assume it's purple that's bust then :) I think that comes off the charge port's yellow/green wire. Blue and Black were the power button from memory and green/white were BMS comm.
            L 2 Replies Last reply Reply Quote 4
              @lia You're exactly right! I just probed the purple , it's a open circuit, and it does connect to the Yel /Grn on the charge port according to the schematic.
                cheppy44 XR DIY @Lemur last edited by
                @lemur Oooo I have a board with the same exact issue! Now to figure out how to fix it.
                  Lemur @cheppy44 last edited by
                  @cheppy44 I'll try to write up an easy way for you to test your harness.
                    @lia I repaired the harness , replaced most of the purple wire because it had multiple kinks.
                    I used a piece of stiff wire and soldered on a purple wire to thread it through the piece that fits in the cable gland, put new heat shrink and good to go.IMG_6018-1.jpg IMG_6019-1.jpg IMG_6020-1.jpg
                      @lemur Amazing work as usual! Clean fix too, certainly better than buying a whole new harness.
                        @Lemur Been using this thread to guide @cheppy44 through the same process (and repairing a headlight cable). Very thankful for the images <3
                        As was the case with yours the purple wire is severed somewhere deep in the guts of the insulation so looks like we'll be doing the same surgery.
