    XR rear LED Pinout
    2362
      Lemur @peepermeeper last edited by
      The red leds use orange for positive and grey for negative
      The white leds use yellow for positive and magenta for negative .
      I'm not sure you can use the Xr rear light strip for Thor as I believe the Thor light controller is for rgb(w) . IMG_8219[1].JPG
      P LOAF 2 Replies Last reply Reply Quote 2
        peepermeeper @Lemur last edited by
        @lemur Thank you !! and I think you are right about that I'm going to go with something else!
          LOAF XR @Lemur last edited by
          @lemur do you by any chance know what voltage the LEDs run at?
          L 2 Replies Last reply Reply Quote 0
            Lemur @LOAF last edited by
            @loaffette I can't remember, but I believe each color runs at a different voltage.
            I will find out and let you know.
            LOAF Sirgu 2 Replies Last reply Reply Quote 1
              @lemur alright, thank you!
                @Lemur said :
                ... , but I believe each color runs at a different voltage.
                I'm also curious and following this.
                  @loaffette The red leds run bright at 8v and the white leds run at 14v on my variable power supply. Although they can run a volt or two higher, but 8v and 14 volts are safe
                    @lemur so idealy I could run the white LEDs at 12V?
                      @loaffette 12 volts may be too dim as when the Xr boots up, the white leds voltage shoots up to 18v and drops down to 16v. I mentioned 14 v just to be on the low side.
                        @lemur damn, got it
                        thank you
