    Onewheel V1 and OW+ controller cutout voltage
      Kiibe last edited by
      I have built a RaD mod for my one wheel v1 , 14s5P big battery, im worried to go down 48 volt because i know for sure the internal battery cuts out at 48 volts. What is the lowest voltage a OW v1 or + will take before controller cuts out ( not the bms) Thank you
        Hi @Kiibe -- I ride a V1 with solely an EGO battery and no BMS. One time I ran the EGO battery to low voltage pushback -- indeed like Captain Morgan. So, my take is that the V1 controller gives low voltage pushback before it cuts out -- it did not simply drop the nose and pitch me off. Sorry, though, that I don't have an actual cut-out voltage for you.
        K 1 Reply Last reply Reply Quote 2
          Kiibe @S. Leon last edited by Kiibe
          @s-leon ive nosedived a couple times without pushback on stock onewheel battery so i wanna be sure ... I will diacharge the battery to 48 and test out various results, i think , would be a shame that it be at 48 volts because lifepo4 16s would normaly cut at 45 volts!!
            S. Leon Plus V1 DIY XR @Kiibe last edited by S. Leon
            @kiibe -- When I got home today about a half hour or forty-five minutes after a fall due to low voltage on my Onewheel Plus (solely EGO powered with no BMS) the EGO battery read 46.5 volts. The batteries do tend to recover a little over time, so it might have been at 45 volts when I nosedived.
            Why was I riding it so low? The gauge on that particular EGO battery always says full, and while I knew I had ridden on it some, I figured I had another six miles worth of power to go on it... Not so!
            Thank goodness for the armor I habitually wear -- elbow, shoulder, and hip, then an immediate intentional roll onto the black, hard plastic clamshell back of Fox Titan Pro. One small scrape/friction burn on my leading elbow, and a mildly sore leading foot from the first step going down are my only hurts.
            Luckily too, I was carrying an extra EGO battery strapped to the wooden fender of my Onewheel Plus... So, I traded batteries right there on the trail, Onewheeled about four miles back to my XPedition ebike -- on which I now have over 1600 miles -- and then another four miles home pedaling that.
            Edit: Although no bruise shows, my hip also hurts a bit -- noticeable lying on it in bed. My knee pads also show fresh scrapes, easily seen because the fresh scrapes on the hard plastic are white gouges, while the rest of the pad is dirty from daily use. No hurt at all in the knee, although my leading big toe has turned a little purple. Again, it is comforting that the armor lets me get right back up and ride.
