    Onewheel GT Stripped Hub Bolts
      TehTEh last edited by
      Hey y'all, I stripped the 2 hub bolts on the maghandle side of my GT pretty bad. I used a TP45 bit but still managed to strip them, I also had 2 feet of leverage on the bolt and it wouldn't budge. Any recommendations on how to get them out?image_2023-07-10_154430615.png
      Puzz360 NotSure 2 Replies Last reply Reply Quote 4
        Puzz360 XR Pint V1 @TehTEh last edited by
        @tehteh
        What a nightmare…
        Been getting knackered bolts out of all sorts of things for years.
        Normally a hammer and a screwdriver will work but being recessed makes it more tricky.
        Have you thought of something like these ?
        You may need to do a bit of drilling first… start small.
        Maybe it’ll help you ?
        Good luck.
        T 1 Reply Last reply Reply Quote 5
          TehTEh @Puzz360 last edited by TehTEh
          @puzz360 I'm definitely going to have to try that, would you think it would be better if I used a dremel and a flat head to get it out? Or maybe a manual impact driver?
            @tehteh
            I'm not sure about a dremel but the impact driver is a good shout too
            Maybe if you have a flat blade bit wide enough to go in the widest part of the allen headed bolt and a good shock with an impact driver may well work...
              NotSure XR Pint @TehTEh last edited by
              @tehteh said in Onewheel GT Stripped Hub Bolts:
              yup
