    6 pin and circular pin connectors diagram
      wheelngear last edited by wheelngear
      I have been looking online to try and find what each of the pins on the onewheel motor connector represent. I got my own vesc to try and hook it up. For the 6 pin white connector, since the wires are fairly thick, I'm guessing 3 of the pins are for the motor polarity, 2 are power and ground, and I don't know what the last one would be for. The circular connector I'm not sure either. For the 6 pin connector two wires are green colored, two are blue, and 2 are yellow. Does anyone know what the pins are?
        Lemur @wheelngear last edited by Lemur
        @wheelngear The square one is the 3 phase wires, they double up, 2 blues, 2 yellow, 2 green . The circular one is one is for the hall wires yelow, green, blue, white is temperature, black is ground, red is 5v positive.
        The Onewheel Hypercore motor is a brushless motor, you have the colors wrong though, check again.
        W 1 Reply Last reply Reply Quote 3
          wheelngear @Lemur last edited by
          @lemur I see, that makes sense now. Thank you!
            yknow, the plug does look like a weird cousin of the S-Video plug..
              cheppy44 XR DIY last edited by
              is anyone is curious i believe they are produced by switch craft model number EN3P6FPX.
              https://www.mouser.com/ProductDetail/Switchcraft/EN3P6FPX?qs=o3ifyepdn6OZtLPGCQNhUA%3D%3D
