    Infrared footpad experiment
    1721
      Lemur last edited by
      Fun infrared footpad experiment for vesc I had this cheap Aliexpress infrared sensor to build a better mousetrap from a couple of years ago, project never got started.
      After seeing Tech rails project with electronic sensors, I ran a simple experiment to check the feasibility with this sensor as a footpad sensor, either single or dual zone. This could work as some vesc would have 12v aux to power the sensor and triggering a simple small relay, either mechanical or electronic.
      This is for personal use and not for sale, just fyi.
        @lemur I love the idea. Wouldn't direct sunlight be an issue for these though?
          @lia I just tried a powerful led flashlight about 2cm away from the infrared module and it didn't affect the sensor, maybe full spectrum sunlight may, I have to test it when we get some sun.
          Certainly mud or snow will affect it, I'm going to make a mount, source a relay today and test as a single zone as I only have one of the sensors for now, super cheap on Aliexpress.
            @lemur I hope it works out!
              @lia The infrared footpad sensor exceeded all my expectations!
              I set it up as an one zone, goofy foot sensor. Heel lift, hop off and quick stop worked flawlessly, all in bright sunlight too.
              I can see snow, mud or other debris will create a ghosting problem, so I'm trying to engineer some kind of fail safe .IMG_E8005.JPG
              Lia NotSure 2 Replies Last reply Reply Quote 3
                @lemur Amazing work!
                I'm so happy it worked out fine. Any thoughts so far on how to stop those? Maybe a hydrophobic layer on the sensor or something.
                  @lia Maybe I can figure out how to wire two in series so both have to be activated to turn on the footpad, if one is obsured (activated) , the other is deactivated the circuit will be broken.
                  Not a 100% solution, but a redundant system, side by side sensors.
                  Or tiny windscreen wipers. Hahaha
                    @lemur lol
                      Lemur @Lemur last edited by
                      @lemur Figured out a getto solution to keep the sensor clean. HahaIMG_8016[1].JPG
                        Sirgu XR @Lemur last edited by
                        @Lemur it's awesome how your experiment progression (or part of what has been shared publicly) is step ahead of Tech-Rails idea.
                        Outstanding video footage on FB 'DIY Squad' group! Guessing with such heel proximity no hard debris does not accumulate on sensor sight. Mud & moisture do leave some hesitations. I'll be following with excitement on your fail safe ideas on that experiment.
                          Lemur @Sirgu last edited by Lemur
                          @sirgu I have a few ideas that need tweaking.
                          What I realized that this sensor system is super cheap and works for deep concave footpads like the Kush where a stick on pressure sensor has problems.
                          A friend is going to help me design and print a fender or half fender to incorporate this type of sensor.
                          FYI, I won't be selling any kits as liability is too high, I will post the whole procedure for those that want to diy after more testing.
                          Sirgu 1 Reply Last reply Reply Quote 3
                            @Lemur said :
                            ... FYI, I won't be selling any kits as liability is too high, ...
                            This is evidently understood. Likewise all of your one-off projects.
                            It is still admirable that you share all this know-hows and experiences.
                            • cheppy44
                              cheppy44 XR DIY last edited by
                              @Lemur that's so cool!
