    Vesc Conversion Status (Rose/Mika)
    37970
      Lemur @LOAF last edited by
      @loaffette Hope you get the the Ubox set up, I had a sutdown problem with my MK8 150 with a shutdown while riding. Apparently, the long press firmware does not have a default auto shutdown while idle, and if you set a shutdown time on the LP firmware, it may shutdown while riding when the shutdown time expires, although it's supposed to reset to no shutdown time after rebooting.
      I switched to the short press firmware just to be safe and had zero problems since and running any lights on the MK8 is risky, I removed light on my MK8.
      LOAF 1 Reply Last reply Reply Quote 0
        LOAF XR @Lemur last edited by
        @lemur I talked with Ennoid a bit over email. He mentioned how if you use an external buck (which i use know) it can cause some weirdness with current rippling, and VOW needed to install a diode to prevent that.
        I have seen people getting LEDs working on the MK8
        I got the new hall sensors in and will be installing them, and will be finishing my conversion later today. Going to go pick up new grip tape later today for my new footpad. Considered pulling off my old grip tape but decided that I should stop with the jank and I should start doing this properly.
          LOAF XR last edited by
          She's alive.
          Board runs great, and I've already given it hell. The new campus I transfered too is very hilly and has some pretty steep inclines, so I've been pushing my board up the hills to try and stress it out.
          I got the Ubox 100v installed, though I had to design my own mount for it and rip it out of the metal housing it came in. Found out the NRF data port and ADC 2 is dead, so that's fun. I have a new MK8 coming in with 120V FETS. Apparently running 150V FETs with a 75.6V battery makes the controller run HOT. Plus, switching to 120V means I can get insane amperage (About 198.6A for Soft max, over 230 abs. max!)
          Motor feels great, and I did the hall sensor replacement on my own. Ended up doing all three, took pictures and then made a pev.dev post about how to do it. It's poorly written, but hopefully it's enough.
          One of the riders at 1Wheelparts hooked me up with their quickies. I modified the pubpad to fit specifically the quickie, and I'm going to modify the foot hooks from VOW to fit the quickies specifically.
          My new footpad runs a V4 Stoked Stock sensor with the first 5mm printed out of thick PETG, then rest out of TPU
          Looking into adding PWM control for my COB LED lightbar, but that will come later if I learn PCB design.
            LOAF XR last edited by LOAF
            Board is holding up well. Thought I would run through some things I've discovered and came up with while working on this board, and tinkering with it.
            First- absolutely do not put off any maintenance or work on the board longer than needed. Will get back to this later.
            I don't have any pictures, but I managed to get access to a makerspace at my new college, which is amazing. The parents aren't as happy that I've now got a place to go work on my projects that has A/C, access to 3D printers, CNC, waterjet and laser cutters. I've signed up to get training on the CNC, waterjet and laser cutters so I can gain some new skills and expand on what I can do next. I have a few projects I want to embark on once I get settled in and see how this semester goes. (Stepper-Motor powered guitar anyone?(Learned that Bambu A1 printers generate their boops and beeps via motor vibration, I'm now obsessed with playing music out of my printer. Roommates might hate me now))
            I got the chance to put on some new heatshrink over the cable harness that runs from the battery to the controller. The hard part was running the new heat shrink over all of the cables. I started out with the largest wires, then pulled through the smaller ones using a length of string tied to the ends of a set of wires through the heat shrink. Also discovered that I had somehow lost length on the XT-60 even though I didn't cut it (black magic I guess). Gonna make a two inch extension using some length of wire and a female/male set of XT-60s so the main battery power leads aren't any tension. Remember to put the cable gland on before you put your XT-60 on or else it'll be trouble.
            Did discover that if you leave neopixels powered but without data plugged into an ESP32, interference from the motor will cause the LEDs to flip out. Plugging in the data from the LEDs into the ESP32 negated this, and there is no reported issues so far. Will let the smart people figure this one out.
            Old wiring harness heatshink wasn't made for the length of BTG, so I barely had any cable gland on the meat of the heat shrink, making for some very poor sealing. Waiting on the new MK8 Ennoid to come in, which has 120V FETs to allow for 20-22S shennanigans once I finally figure out how to properly route and manage wires. Thinking of using some zip-ties and hot glue to work this, and some pre-planning.
            Ordered stainless steel m3 screws to replace the ones in my battery box which have finally stripped out. (I hate tiny torx for a reason. I hate tiny screws for a reason.)
            Need to look at sealing the front and battery box, though I want to do this after I'm absolutely sure my board is 100 percent wroking. Found a couple trails near the college that have some trecherous terrain I could totally throw the board down to stress test it.
            Thinking back on the Hall sensor swap and VESC Tools Hall Analysis tool, I think I may have a reason as to why hall analysis was showing very wacky hall readings. It could be due to the fact that BLE isn't stable and may cause data to be intermitently dropped, leading to data being lost during trasmission. Could be the Vesc software itself on my iPad or computer being generally pretty jank and having some issues that cannot be diagnosed. It could be the VESC itself is old and is just showing it's age. Yes, I'm blaming my tools for a problem I can't solve, but it's the only thing I could think of outside of user error.
            Off-topic time:
            I went to San Japan over Labor Day Weekend. It's not my normal crowd, but it was fun. Sucked going alone, but it was genuine fun to see people and get to meet people who seemed to be important. Used my board to get to and from the convention between the convention center and my hotel. Got caught in the rain saturday night on the way back, and that soured my mood for a moment.
            Anyways, they had a car meetup thing in one of the halls where they had a bunch of crazy cars with anime/waifu wraps, similar to how Warstik was back in 2024, but better. It made me want to do it again, but Craft and Ride is dead and even if they weren't, I don't wanna drop the money on rail gaurds that wouldn't be removable or easy to protect. Came up with the idea there to have removable rail guards using the screw holes found in stock XR rails for those rail clips. BTG WTF rails don't have these, but they can be added with the help of a drill and tap set. Could have a set of screw holes, two on each half of the rail, one on top and one on bottom. You'd have a bit of the rail guard wrap over the rail and would be bolted in place to hold them on. Can't really prototype without proper training on a laser cutter or CNC, but it doesn't mean I can't make ideas. Now I just have to find a way to print on acrylic on the cheap.
              LOAF XR @LOAF last edited by
              WELL
              I managed to obliterate my motor cable on my Superflux
              hell.png "
              I don't want to talk about it
              Convinced Fungineers to send me a new motor cable for free, and it arrived on Friday of last week
              Spent about six hours yesterday doing the cable swap
              I'm tired, I still have a headache from that and I'm very sure the lead content in my body has gone up by a considerable amount
              It's not pretty
              I will go back to clean it up
              I'm tired, I don't want to deal with it for any longer than I have to
                @loaffette said in Vesc Conversion Status (Rose/Mika):
                Oh.... wow!
                Sorry that happened but dope you got a new cable for free.
                Fingies crossed it all works again so you can go clear out them lungs with some zoomy zooms.
                  LOAF XR @Lia last edited by
                  @lia It worked
                  I did get something else, more on that later
                    Well, I'm still alive!....
                    somehow
                    So, how is my board doing?
                    Well, actually! I haven't had many issues with it, and it's been fine. I re-did the o-rings on the axle, and I've done some small tweaking to the foot hooks. Thanks and shoutout to VOW for the free foothook design, and Onewheel Parts for hooking me up with their quickies, those things are indestructible.
                    Since last July, I've had to replace my footpad sensor twice. Great, and I had to buy one for a higher price from someone else since StokedStock is no longer with us.
                    I am now considering either a magnetic-style footpad, or using one of those pressure sensors for car seats
                    (cursed)
                    Apparently, the VESC peeps engineered a way to use a little magnet that you tie to your ankle as a way to activate and deactivate your footpad. It uses a mangetic sensor, and it's pretty neato
                    To dwell on this further later
                    Troque Box is holding up, but i may need to 3D print a new battery box or shell out the cash for the torque box 2
                    New tire too. The Thundercat didn't last as long as the previous tires, the sidewall probably gave out around mid-feb, lasting about 7-ish months before it would loose air. By the time I decided i was done re-airing the tire every few days, it was mid-june and the tire would go flat over the course of a 90 minute lecture.
                    I am going to replace the battery soon. 18s2p would be the easy and sensible route, but since I'm going to college near a major city now, I can actually go to group rides weekly!
                    THESE PEOPLE ARE FAST AND CRAZY AND I CAN BARELY KEEP UP
                    but they are pretty cool
                    also I've found that while I have mellowed out in the past year or two and I'm not trying to hit 80-80 duty cycle, I'd like some more headroom. 26s1p was on the table for a bit because of my 120V Ennoid, but I was told that I'd have to charge my board no more than 4.09V, nullifying the need for the battery. 24s2p split pack scares the hell out of me (My old ride group had a couple split pack issues and one fire from one), and 24s2p with 18650 using a SuperSpeed Box would be VERY expensive, and with that kind of money, I'd already be going for the fifth option. Fourth Option was a 24s1P pack made for PintV, but my gut didn't like that one.
                    Fifth option?
                    I may have gone a little insane since I last spoke here
                    Uhm..
                    I decided after talking with some engineering buddies I know and people who can handle money better than I can that spending more money now on a much better setup is worth it in the long term.
                    I am going to have to get a 150V Ennoid. I was told to contact Ennoid about seeing what can be done about my 120V, but apparently he's on vacation until next week, so I'll have to wait.
                    30S1P on RS50 should give me similar range as my ME4T pack, but an exponentially more amount of the pucker factor in terms of raw power.
                    I'm still in shock that I'm even ORDERING a 30s1p pack, let alone going to install one.
                    So, yay
                    Probably time to start looking at Leatt gear and to probably get life insurance.
                    final notes?
                    Using the quickies from OneWheelParts, I'm designing a clip that bolts onto the unused holes so I can carry around the board like a duffel bag. Supposed to be a one day print, but my printer (Now a heavily modified SV08 which could honestly have it's own form post) is tempermental about ASA.
                    If I get it done tonight or tomorrow, I will share pictures
                    i think i'm slowly going insane
