    Vesc Conversion Status (Rose/Mika)
    37970
      LOAF XR @Lia last edited by
      @lia they just told me it's dead and needs to be sent back
      I'll probably poke around inside and see if anything looks broken or busted
        @loaffette Assuming the fuses did their job you should be fine.
        https://spintend.com/products/single-ubox-100v-100a-motor-controller-based-on-vesc
        Check continuity between the highlighted components. If one shows Open Loop then that needs replacing with another fuse.
        Good luck!
        LOAF 2 Replies Last reply Reply Quote 1
          @lia I'll check
          if that's the problem and the board powers on afterwards, then I'm golden
          I did notice earlier that when i have the power button plugged in, there is that little pop, but still no power
            all of them seem fine, but BF on mine is a tad bit flakey
              LOAF XR last edited by
              Update
              No bueno on that old controller, it's deader than a doorknob. I held on to it for measurment references and to recycle the XT-60 on it since I was out of those. Spent the rest of my time experimenting with COB LED strips
              They seemed bright and worked well. The idea is to utilize the 12V (1A assumed) power output from the Ubox 100v. Split it so two of the wires carrying the voltage goes through a boost converter to bump 12 to 24v for the LEDs. At the same time, run the other two wires to a buck converter to drop it to 5V for the Wemos D1 which will use WLED. That will let me control the LED's colors and brightness.
              It worked on the bench, so I buttoned the rest of the board up enough so it could be taken back to college
              Re-terminated the wires on the motor just so it was cleaner, and covered it in heat shrink. I might end up peeling that heat shrink off and re-doing the wiring again because it was a pain to fit through the cable gland, and I think I could make it look cleaner.
              So, remember how I've been having trouble with the screw threads on my rails?
              I took the Easy Access box STEP and pulled it into CAD. I added these little legs that extend out enough to cover the back screw holes for the bumpers. There's a hole for 10-32 heated inserts to go in, where it should give me new threads. I had to sand it down a bit, but I got it to fit and it works well!
              After I moved in and my new controller arrived, I got right to work placing in the new controller. I had some fun with my iPad automatically updating to Vesc Tool 6.05 which made connecting to the board impossible via iPad (stupid thing) so I did it on my Galaxy Fold, which hadn't updated the app.
              After too much work, I got it all put together! However, the LED bar on thr front started to flicker like crazy. I checked the wiring, checked for any shorts via continuity across the wires and even swapped out the Wemos D1. I even ran the LEDs with only the power and ground connected, and it still flickered and changed colors.
              I was going to replace the LED strip but I can't find the rest of mine, and I don't feel like ordering new ones
              The board works now, and is working great! I'm hoping to waterproof it soon before it rains. I printed the controller box out of PETG with a 5 layer thick wall, so hopefully that should keep it sealed.
                The board compared against my mom's pint. I'm hoping to soon replace the tire after 500 miles and to get her an enduro. She can ride the board and balance on it, but she goes very slow and her feet and ankles are shaking on the round tire of the pint.
                That's a later project though
                  @loaffette said in Vesc Conversion Status (Rose/Mika):
                  Nooooooooo 😭 Anyone nearby who's handy with a reflow station that could take a look?
                  Are there filter caps on the LED strips. It's possible there's enough noise from the run length to cause it.
                  LOAF 1 Reply Last reply Reply Quote 0
                    @lia Nope, not yet on the reflow station
                    Everyone I knew who had one left for greener pastures (They're all smarter and crazier than me and got scholarships to better colleges)
                    The LEDs flickering might have been a good thing too. It made me realize that those strips weren't bright enough for what I wanted (even though they were 24V)
                    Though I may end up putting my old stock XR headlights back in for now
                      New update:
                      The motor has started to vibrate whenever I apply breaking. It's like haptic buzz vibrating. Updated firmware, recalibrated the motor and went through motor crunch troubleshooting.
                      What fixed it was unplugging the Hall sensor plug in my veac and plugging it back it.
                      A little confused now
                        I'm ALIVE!
                        So, found out the reason why my LEDs were freaking out was due to EMF from the phase wires. Will spend some time this weekend to cut up a spare USB cable to shield the headlight cable.
                        Also, I am considering seeing if I can look at waterproofing my board completely
                        I have a feeling the rain this year is going to be insane
                        I also built a trunk thing for the onewheel
                        I was gifted actual power tools and so I used them!
                          hey, you wanna hear an idea so stupid it rolls around to being absolutely genius!?
                          No?
                          too bad
                          I went to Houston this past week. It was fun, and I got to ride a really cool bike path! However, I forgot my charger in Dallas.
                          While I was sitting in the park, waiting for my dad to pick me up from my ride, I was looking down at my phone powerbank. It has PD that could easily power a steam deck or a macbook. I then looked at my board.
                          Then the part of my brain that everyone wishes would stop working turned on, and I had a really cursed idea.
                          What if you could charge a onewheel off of USB-C PD? The idea is simple: You have a Type-C port that automatically demands 20V/the highest PD that the charger can support. You then had a DC converter that steps 20V (or whatever voltage you can pull out of your macbook/ipad charger) and step it up to say.... 75V?
                          Have an XT-30 plug that you can plugin GX-16, XLR, XT-30/60/90, Pint/GT, or whatever cursed plug your insanity-tinted glasses head likes to use!
                          Would this be useful? Probably! It's going to be ~$60 to build in parts, not counting filament cost.
                          I'm waiting on this for now as I have a couple projects I need to finish up.
                          Lia L 2 Replies Last reply Reply Quote 1
                            @loaffette Nick and I thought about something like this but I've never seen PD outlets in the wild (at least in the UK). Especially any spec'd for high wattage.
                            I know the spec can go to 240W which is insane but other than a few premium battery banks that might give you 5-10% charge after losses it's not something you'd see a lot to make work in a pinch.
                              bought a Superflux HS Mk2
                              Will drop it in soon
                              Also working on a couple things rn, will keep ya'll posted once I finish it
                                Got the Superflux on, currently don't have a picture yet
                                Things to note about installing a superflux-
                                The thunder tire is literal landfill. Just throw out the tire, it's not worth it. I had my tire for about two days, went on a trail ride and the tire developed a flat. Swapped it out for my old Enduro and it was much better
                                The male connector has way too much meat on the connector. IT needs to be trimmed because making it fit within the rails is a hassle and a nightmare. They should cut it by about half an inch from the cable in terms of connector for better flexibility. I already know two trail riders local to me who have done this.
                                The superflux hs HAS SOME GAS
                                That thing flies like a bat out of hell
                                It's one hell of a motor, and it was worth every penny
                                  Here's a pic of the tire change. You can see how terrible the old motor was (the motor with the purple cable)
                                  I'm not even going to sell the motor. It's got 6k miles, the cable is messed up and the bearings are the same ones from day one. I'm going to bring it to a lecture one day to take it apart for a lab then keep it as a trophy.
                                  The current goal now is to waterproof the board, finish my headlight project and then to give the board a visual overhaul
                                    Lemur @LOAF last edited by
                                    @loaffette I use to carry a solar charger, a 36v hoverboard battery, charging adapters, in a camera bag for group rides.
                                    The solar charger converts the 36v to any higher voltage up to 90 v all programable with memory for different boards.
                                      LOAF XR @Lemur last edited by
                                      @lemur very interesting
                                      I'll have to look into that option
                                      I remember Wren for CD using a setup like that for his board
                                        JankeyRider last edited by
                                        Hey just wanted to say Ive read pretty much the whole thread due to somehow finding this page when searching for DIY solutions to VESC issues. It was a fun journey to see everything you've done to build a really decent board!
                                        Im riding a totally self built VESC board and I love it. Think ill upgrade to WTF rails soon and some decent sensors and footpads as im still using tiny spintend sensors and homemade footpads from plywood and griptape.
                                        But I ride every day and I love it. Cheers for sharing your journey!
                                        its a big learning curve.. lots to work out and its a real sense of achievement once you get things really dialed in theres nothing like building your own board from scratch!
                                          Alright, I think ya'll need an update for the board.
                                          As of writing this, I have switched to a metal controller box based off of the Pubbox design, which is amazing (outside of the thirty lid screws), went to the ennoid MK8, then back to the old ubox 100v. Added LEDs, 3d printed footpad with the first five milimeters being near-solid PETG with the rest being TPU and the stoked stock v4 sensor, and then the thundercat with WTF BTG rails.
                                          The board is currently in a weird state of un-death. I made some idiotic choices and browned out my MK8 enough times to do what I'd assume permanent damage to it, along with finding that somehow an SMD capacitor came off of the MK8 (wild). Spent the better part of a couple days then switching back to the ubox, only to find that the NRF data and ADC2 being dead. Greeaat
                                          For the past month, I've been fighting the board to keep it running. It started with adding LEDs running directly off of the MK8. Bad choice, as that would cause the board to brown-out mid ride, and I'd get some very nice road-rash. Took out the LEDs, and it seemed like the problem went away, for two weeks. About two weeks ago, I switched to the metal controller box. The first ride with the board, I did a curb nudge after about twenty minutes of riding, and the board stated to make crunching noises intermittently, with no real pattern. Re-calibrating the motor caused this issue to go away, but after about twenty or so minutes later, the crunch came back. Double-checked settings, uploaded new firmware, reflashed the MK8, nothing fixed it.
                                          I spent a solid week chasing everything that could possibly be the issue.
                                          I can't tell you how many times I considered either tossing the board, parting it out or just straight up taking my mom's pint and doing unholy crap to that.
                                          I think I've dialed it down.
                                          VESC Tool has a command in the terminal called hall_analyze, which lets you.. analyze the halls? Idk, it's VESC Tool. It's both the best and worst thing to exist. It's supposed to be used to troubleshoot your motor halls. You're supposed to get nice, clean square-wave output, with nothing weird or fishy about it.
                                          Above is my hall sensor. It's not clean, and it looks a little suspect. Those strange, sharp dips could be either Vesc tool absolutely crapping its brains out, my halls in the motor screwing up, or a mix of both. I already tried this with both my MK8 and Ubox, got similar results on both. Could be the motor, could be VESC tool. I hate this damn hobby-
                                          So, where are we at right now?
                                          Well, I have four new hall sensors coming in, because one of the hall sensors DEFINITELY has damage to them, and it'd probably be a good idea. I've ordered a replacement MK8 with 120V MOSFETTS, and I'm currently trying not to go insane.
                                          Also, this is all happening in between finishing up my last couple weeks at work, packing up for my transfer to Texas State, preparing for an event I'm going to called San Japan (Going with a group of friends against my willpleasesendhelp-) and having to juggle adulting stuff.
                                          Hopefully I figure this out in time.
                                          I'll keep ya'll updated.
                                          I have no idea how ya'll do this crap
                                            LOAF XR @LOAF last edited by
                                            One more thing-
                                            GX-16 can be used in place of the switchcraft connector, it fits if the screw part of the connector is oval-shaped.
                                            And I somehow managed to gaslight my Ubox 100v into making it think pitch was roll, vice-versa. I assume that I've either done something I shouldn't have, or I've messed up on IMU calibration.
                                            Once I get this whole thing figured out, I'll post a more detailed write-up on my board as it currently stands.
