    Suspension build redux
      Lemur last edited by
      Here's my suspension build that I modified as the old setup would drag the tail on hard braking or moderate braking on downhills, because of suspension squat.
      I tried custom shaping with nose down, but it never really felt right.
      -FF Tail Rails added for tail kickup
      • Xr controller
        -Pint wheel
        -JW battery
        -custom wiring
        I'm working on gen 2 suspension and hoping to make it a drop in
        LOAF XR @Lemur last edited by
        @lemur That looks sick!
        What was the board originally before you modified it?
          Lemur @LOAF last edited by Lemur
          @loaffette I only used the XR controller and bms, Pint wheel, Kush footpads and Fox shock. The rest, rails, suspension pieces, wire harnesses were all custom fabricated. The original rails were 6060 ornamental aluminum, that's the reason for the brace behind the wheel. The Tail Rails are 7075 aluminum and I left that brace off.
          LOAF 1 Reply Last reply Reply Quote 4
            @lemur I aspire to the kind of stuff you do
            This is cool!
