    Anyone tried changing their Onewheel tire pressure for smoother rides?
      emilysmith last edited by
      I ride my Onewheel around the neighborhood and some of the sidewalks here in Louisville are pretty rough. I've been thinking about adjusting the tire pressure to see if it makes a difference in how it handles bumps and cracks. The stock pressure feels a bit stiff to me, but I'm not sure if lowering it would hurt the range or make the board feel sluggish. I don't want to mess with anything that could cause a flat or wear the tire out faster either. I mostly ride on pavement but occasionally cut through grass or gravel paths. Curious what pressure other riders in this area tend to run, especially if you deal with similar surfaces. Has anyone found a sweet spot that balances comfort and control, or is it better to just stick with what Onewheel recommends? Any input would be helpful.
      • Moved from FloatWheel by  Lia Lia
        LOAF XR @emilysmith last edited by
        @emilysmith It does. Lower PSI gives the board more cushion and makes drops easier (lots of trail riders drop their PSI for this reason)
        However, I've heard that dropping your tire PSI too low can cause your tire's sidewall to wear out quicker, and you do risk damaging your rim
        The general rule of thumb is 10 percent your body weight. So I'm about 140lbs, so I tend to ride around 12-14 PSI, 10 PSI for trails.
