    Stokedstock bms
      Lemur last edited by Lemur
      I replaced the Maxkgo charge only bms with the Stokedstock bms, I don't believe the Maxkgo ever balanced my battery pack as I never charge to 100%, the SSbms can be set to balance at a lower cell voltage.
      After a few charge cycles with the SSbms, I can see the cells even out and is now at 0.01v deviation and in this case I set SOC to 100% at 4.15v.
      The SSbms has it's own app and will read cell voltages in real time with many programable settings.
      The SSbms is the best bang for the buck in my opinion.IMG_E9821[1].JPG IMG_9822[1].PNG
      S 1 Reply Last reply Reply Quote 2
        syanelli @Lemur last edited by
        @lemur can i see your wiring harness? i’m wiring an SSBMS and confused on charge and discharge path
          Lemur @syanelli last edited by
          @syanelli Here's a simple crude diagram, but basically I eliminated the positive charge wire as it is tied into the controller positive from the charge port.
          S 1 Reply Last reply Reply Quote 0
            @lemur does the 3-10a when charging not affect the controller?
              @syanelli Charging does not do anything to the controller as the charge negative goes to the bms.
