    Multi-Modular Onewheel Stand
    onewheel stand
    2740
      With the GT on the way my Pint's usually orbiting somewhere near wherever I leave the XR I thought about having a stand to hold multiple boards.
      Trouble being something for multiple boards will usually mean large lengths of timber or detached stands that will frustrate even those without some form of OCD when the boards don't line up.
      I'm thinking of making something like this (ignore the fact I used the XS to model these, they scale up by 2x to perfectly match the XR)
      The way it'll work is you'll print 2 end pieces and however many middle pieces for every additional board you want to add. Then you'll have lengths of 320mm and 620mm 20x20 square timber to connect the printed pieces. By using the 620mm timber offset between a middle hole and an end hole it angles each board 30 degrees so they aren't just flat up against the wall making it easier to see your boards when not slightly off angle from the front. It will also mean several long lengths of timber are needed so you can make this with relatively simple tools.
      Need to adjust the printed middle sections so they'll fit on most 300x300 build plates.
      Will also design specific board cradles to seat the board depending on what model yo have. The idea is to have them slot over the timber so they can be quickly swapped out to reconfigure which board goes where.
      Additionally this can be expanded to add more boards later by taking off an end piece, replacing a 320mm piece of timber with a 620mm one and add another middle section then complete the end again.
      Any thoughts on the design? It'll be possible to have them all lined up rather than at 30 degrees by just using longer 20x20 timber and using only the end pieces... but this looks cooler ;)
        @lia i have the landsurf wall thingy for my xr. i like it. the verticality is nice for display n storage. My pint fits in a 5 gal bucket tho.
          @notsure I liked the look of those but there aren't many studs in my walls to make placement practical. They're really cool though, super clean look!
            @lia said in Multi-Modular Onewheel Stand:
            i discovered ur secret to boundless productivity btw...
            [drinks simultaneous blend of all 39 monster energy drink formulas]
              @notsure You got me!
              I've kept at least 1 can of each flavor. Exhausted all 9 flavors my local shop sells though.
                youtube below
                  @notsure You have no idea how often I try to work the 100 coffee clip into a meme. One of these days...
                      Picked this one up again now that I got some more 20x20 pine.
                      Decided to do away with the cradle idea since that'll just break and require more bulky prints. Instead a common sized sheet of plywood (300mm or 1foot x whatever length needed) will cover this design.
                      Started assembling some of it, works okay and once I start making the slot in spacers to keep all board types at the same angle (since their thickness alters and changes the angle they sit at) I can start adding the finishing touches like maybe some pretty lighting to backlight the boards ;)
                      Sort of wish I only printed 1 of the larger pieces since I've redesigned it to look nicer. Prior to that I wanted to get it ready for the GT... which is gonna take a bit longer so no rush now :D
                        Yikes it's been a month. Nearly done with this one :D
                        Was waiting on more filament. Have it scheduled to come each month so I save a little money through Amazon scheduling.
                        Fitting all the base sections together took some time. Between the alignment, dowel fitment and screws to help keep it locked together I spent a fair chunk of time doing it.
                        Needed to cut more 20x20 pine to finish all 4 stands. Got the Pint(X) to check how it sits.
                        Made sure the large hexagon left room to put a charger through it if needed. I could have lined it up dead centre but drawing all those triangles and hexagons was a pain and in this config less end up obstructed by the pine framing.
                        Holds the XR and Pint(X) so far, still need to do 1 more large bracket and a small end one to finish it in it's current form. Since it's modular I can add another segment... if I end up filling all 4 slots.
                        Designated spot for the boards moving forward. This angle leading into the bedroom where I can easily see and grab whichever one I want.
                        The other viewed angle from the bed. Can easily see them still and get a decent angle of them rather than the usual head on view from normal stands.
                          @lia -- Love the photo with the scale XR included!!!
                            @s-leon Glad you spotted it :D
                            The XS and the XR controller will fight for the empty spot ;)
                              Finally finished and uploaded the design in case anyone wanted to make one too :)
                              https://www.myminifactory.com/object/3d-print-221518
                              BOM and relatively simple visual instructions included. This design can be later expanded which I'll likely need to do now ;)
                              Added support to hold the chargers with the LED visible. A right angled C7 power lead is required but other than that it's a simple install.
                              Have Google setup to charge the boards depending on which I ask her to charge, thinking of also adding some addressable LED's on the back to have a nice light show emit behind them but that'll be a later thing to add.
                                @lia That is genius! Great work.
                                  @lemur Thanks :) Hopefully it'll fit a GT. I'll have to see when I finally get one.
                                    It has been extended!
                                    Had to fix my printer first as it decided it instead only wanted to draw straight lines, more on that in the spoiler, otherwise here's the extended stand :)
                                    Printer decided that the X axis was no longer real. All the voltages were present and no shorts across caps so that left me with either a broken main IC or just the X axis stepper driver. Some printer motherboards have swapable stepper drivers but I bought one with them integrated for like £40 2 years ago. Newer replacements now cost £80 for comparable function and I'm looking to save money currently for personal matters.
                                    Took a chip of a TMC2209 module. My motherboard has them integrated so bought this for like £5 only to remove the chip and put it in place of the existing IC. It's tiiiiny...
                                    Swapped and cleaned. Props to Jessa Jones at iPad Rehab for making videos that gave me tips on how to successfully use a reflow station effectively on chips like this :)
                                    Aaaaaanyway...
                                    First step is to pull off the end. The extended parts will go between.
                                    Simple case of replicating the prior steps to add the additional stands. No need to go over that again.
                                    And of course some stain to protect and add color to the stand :)
                                    Back together, barely just fits to allow me to close the door. Not that I do anyway.
                                    (XS will grow into it ;) )
                                    NotSure S. Leon 2 Replies Last reply Reply Quote 3
                                        @lia -- Great line-up! -- And a nice variety of tires, too.
