    Smd resistor id
      Lemur last edited by Lemur
      Basically a question on smd resistor values.
      Need to confirm values of R12 and r13.
      I get R12 as 33k ohm and R13 as 750 k ohms, am I right?
      Also how about the values of R12 and R13 in the second photo for a 4212 controller?IMG_7499[1].JPG
        @lemur When I popped these off and measured them I got R12 as 33k and R13 as 750k too :)
          @lia Thank you! Just working backwards to find a value for 64 volts? I think 64 volts would trigger a overcharge error code for an XR.
            @lemur Maybe use a variable resistor and just be careful not to crank it too much to feed the poor STM a big voltage? Then you can measure that and go for a set value :)
            I think diagnostics tab in the app might give you the voltage it thinks it is so you can be a bit more scientific ^-^
