    Onewheel GT, something wrong after bearing change.
    7655
    • onesweedwheel
      onesweedwheel last edited by
      My onewheel GT wont "start" after bearing change, what did i do wrong?
      Lia L LOAF 3 Replies Last reply Reply Quote 1
      • Moved from General Discussion by  Lia Lia
        Lia GT XR Pint Plus V1 DIY @onesweedwheel last edited by
        @onesweedwheel Hiya,
        Sorry to hear the board isn't working :( When you say it won't start is it powering on but not allowing you to balance or does it just not power on at all?
        If it does turn on you can connect to the app and see if it gives any error codes.
        onesweedwheel 1 Reply Last reply Reply Quote 1
          Lemur @onesweedwheel last edited by
          @onesweedwheel Check your motor and footpad connectors going in to the controller, they may not be pushed in far enough and not locked in.
            LOAF XR @onesweedwheel last edited by
            @onesweedwheel I would jo go and re-plug everything back in, and just do a general look-over of the board. Unusually, something might not have been plugged in all the way
            Also see if your battery box is plugged in too if that helps. Might have come loose or come.unplugged during disassembly
            • onesweedwheel
              onesweedwheel @Lia last edited by onesweedwheel
              @lia
              Hey & thnks everybody for replying.
              I try to attach video below.
              I have tried to do everything once more & make sure everythong is in rightplace and plugged in correctly, did i still do something wrong or did i damage something when i swaped bearings..this is so frustrating, i live in sweden & the amount of time and money it would cost med to send it to futuremotion is not an option :(
              lMy board, this is how it sounds when trying to ride
              Sirgu 2 Replies Last reply Reply Quote 1
              • onesweedwheel
                onesweedwheel @LOAF last edited by
                @loaffette
                • onesweedwheel
                  onesweedwheel @Lemur last edited by
                  @lemur
                    Sirgu XR @onesweedwheel last edited by
                    Does the wheel without the load acts the same?
                    onesweedwheel 1 Reply Last reply Reply Quote 0
                      @onesweedwheel Since you had to remove the stator to do a bearing change, perhaps the motor harness got damaged where it comes out of the axle or the hall sensor circuit board got damaged?
                      • onesweedwheel
                        onesweedwheel @Lemur last edited by onesweedwheel
                        @lemur
                        That is what i did believe at first, i cant se any damage on it but one of the cables looks "bend". What do you beleive, it looks like all of them are connected, image below.
                        Thank
                        /J
                          @onesweedwheel The circuit board looks good, I can't see any cuts on the harness where it bends, so that just leaves the connector pins. Are all the small pins intact?
                          • onesweedwheel
                            onesweedwheel @Sirgu last edited by
                            @sirgu
                            Sorry, what do you mean with "without load"?
                              @onesweedwheel Holding it up in the air and pressing on the front footpad (Both zones.)
                              basically just get the wheel off of the ground and activate it.
                                Sirgu XR last edited by
                                Yup, that what I meant. Without rider's weight on top of the board.
                                Some ways to test it is on top of 'milk crate' or on top of your knees while you sit well - to sense unusual vibrations, clicks etc.
                                @onesweedwheel from the sounds of your video it seems like motor does some tremendous efforts to engage before loud beep comes up. If (by some raw chance) there exists any physical resistance that only appears under the load, you don't wanna repeat that mount/dismount test too often until you know the cause.
                                onesweedwheel 1 Reply Last reply Reply Quote 3
                                • onesweedwheel
                                  @sirgu
                                  I will try this later today. I will post test/result as soon as om at home later tonight.
                                  Thanks / J
                                  • onesweedwheel
                                    @loaffette
                                    Thanks / J
                                    • onesweedwheel
                                      @lemur
                                      From what i can se, i guess i have to separate everything soon again so i will have a closer look and take better pecure! Thanks for helping :)
                                      / J
                                      • onesweedwheel
                                        @onesweedwheel said in This is how it sounds/looks without load..:
                                        Re: [Onewheel GT](something wrong after bearing change.||
                                        LOAF Lia 2 Replies Last reply Reply Quote 1
                                          @onesweedwheel thats...
                                          terrifying
                                            @onesweedwheel It only wanted to rotate once you go it going which makes me wonder if a phase is missing.
                                            Do you have a multimeter that can measure resistance?
                                            If so turn off the board and unplug the motor connector. On the motor side of the cable measure resistance between each of the 3 large contacts. They all should measure something and be similar. Measure A and B, B and C and C and A (the labels don't matter, but just measuring between each to check).
                                            If that all checks out plug the motor back in and turn on the board. Slowly rotate the wheel by hand and look at the lights on the front. If it flickers to red even when you're rotating it forward that will suggest a failure with the hall sensors or wires for it.
                                            onesweedwheel 2 Replies Last reply Reply Quote 4
