    BMS Component ID Help
    bms
    4189
      Ando last edited by
      Hey Y'all,
      I've been going crazy trying to figure out what component I punted off my BMS while violently unplugging an XT60.
      I tried following the great troubleshooting steps in the SMD Reference thread but I just got stuck in a loop of step 3 & 8 over and over again.
      It is one of 15 duplicated components to the right side of the output XT60 and directly above the 6-pin connector.
      (Not my actual BMS, just a reference image, don't panic)
      The PCB silkscreen reads C11 and with the component missing and the connection open the 11th cell in any pack connected to the BMS reads as overcharged.
      Based on the visual appearance and silkscreen code I'm assuming a capacitor, but that's not much to go off of. I can't find text on any sides of component and it measures 2mm x 1.5mm.
      Any help would be greatly appreciated.
      Lia vulkito K 3 Replies Last reply Reply Quote 3
        Lia GT XR Pint Plus V1 DIY @Ando last edited by
        @ando Hiya :)
        C11 is definitely a capacitor. I’m measuring 2x1.2mm meaning it’ll be a 2012 (metric) / 0805 (imperial) sized component.
        Without desoldering one I’m measuring 0.95 uf across all of mine.
        That leaves the voltage. These all are for the balance lines so I don’t imagine they will see voltages above 4.2v so anything 5v and above is probably fine. I see these usually in 16,25 and 50v versions so should be more than enough headroom.
        A 1 Reply Last reply Reply Quote 2
          Ando @Lia last edited by
          Thanks Lia!
          You're likely right on the 1.2mm width, I didn't remove the conformal coating to measure.
          I'm a bit hesitant to toss a 1uf capacitor on the board and call it good. From my limited research it's difficult to measure capacitance on soldered components.
          I plan to enlist my EE friend who's much better as surface mount soldering than I am. Hopefully he can lift a capacitor or two to get an isolated reading.
          Or we can just send it and see if OWIE reports cell 11 in line with the rest of the pack. ¯\__(ツ)_/¯
          Anything else I should be planning for before I hand the BMS over? Thanks for getting me most of the way to the solution.
            @ando Welcome :)
            I've tried to de-solder mine with my reflow station but I can't seem to get enough heat there before the ground plane saps it all away so I can't measure one of mine for you sadly.
            Your EE friend will probably have the gear to remove one to test it isolated or know enough to ballpark a replacement. Thn it's just a case of ordering one o of somewhere like Mouser.
              Ando @Lia last edited by Ando
              @lia said in BMS Component ID Help:
              Ah bummer. That makes me a bit less optimistic that this will be an easy fix for him, but hey, it's not like he could break it much more.
              It's crazy generous of you to try on my behalf though. Do you have some spares or did you tear into your board on a whim? (Or more logically, some experience from a past attempt.)
              Feels like I should start searching for a spare myself, just in case. Maybe a dead board to keep costs down. =P
                Lemur @Ando last edited by Lemur
                @ando I pulled a few off a dead bms, I couldn't get a accurate capacitance reading. They can be sodered on with a 35 watt soldering pencil.
                Where are you located?
                A 1 Reply Last reply Reply Quote 4
                  Ando @Lemur last edited by
                  @lemur : I'm in MN, USA.
                  Would you be willing to toss a couple in the post? I would be more than happy to cover costs and buy you a long distance pint.
                  cheppy44 L 2 Replies Last reply Reply Quote 3
                  • cheppy44
                    cheppy44 XR DIY @Ando last edited by
                    @ando oo someone else from MN??? Hi friend!!!
                    A 1 Reply Last reply Reply Quote 3
                      Ando @cheppy44 last edited by
                      @cheppy44
                      *waves excitedly *
                      Where are you located? Always looking to expand the local riding group (or alternatively, build a list of cool places to ride for weekend trips).
                        @ando I will dm yo u
                        • vulkito
                          vulkito @Ando last edited by
                          @ando Hi there! I had to replace that same capacitor. it is a 1uF 2012 package and I used a 10V rating. You can buy them in Newark
                          https://www.newark.com/kemet/c0805c105k8ractu/ceramic-capacitor-1uf-10v-x7r/dp/64K2894?st=2012 1f capacitor 10v
                          A 1 Reply Last reply Reply Quote 5
                            Ando @vulkito last edited by
                            @vulkito
                            Thanks so much for adding a confirmed ID for these.!
                            Surely I'm not the only joker that will damage one of those caps with that big ol' XT60 connector. Whoever does it next can enjoy some immediate gratification.
                            W 1 Reply Last reply Reply Quote 1
                              Ando last edited by
                              Just wanted to close the loop. I got my CBXR up and running! I also [unnecessarily] changed the bearings while I had it apart and it's like a whole new board. Between the CBXR and the ReWheeled Quart I've been too busy having fun to report back.
                              Many thanks to @Lia and @vulkito for offering their knowledge and an extra special thank you to @Lemur for going above and beyond and mailing me some spare capacitors.
                              Photo Tax, because it will never look that clean ever again.
                              Lia 1 Reply Last reply Reply Quote 9
                                @ando Love to see a board back out there. Well done with the repair and slick looking makeover!
                                  koryzory @Ando last edited by
                                  @ando please advice - Where could I buy BMS XR?
                                  A 1 Reply Last reply Reply Quote 1
                                    Ando @koryzory last edited by
                                    @koryzory
                                    Witz Wheel in the US, eBay internationally, or get connected with local riders and figure out who has the largest stash of spare parts.
                                    Best of luck!
                                      wowserpancakes @Ando last edited by
                                      @ando also just broke c11 capacitor while pulling out massive plug
