    Kush low as front footpad
    8439
      Lemur last edited by Lemur
      It's a modified Kush lo with four FSR 406 sensors, cable is a piece of a usb wire. I tried hot glue and silicon glue to hold the wires down but those did not stick, only kaplon tape and tie straps, the sensors come with sticky tape on the back. I used a Dremel to cut the wire grooves and plastic film over the sensors so the grip tape won't stick to them if you wanted to change the grip tape later on. If you look closely o the finished pad you can see the four sensors. I have a Xr and Pint footpad made in the same fashion and they worked flawlessly.
      Lia NotSure L Sirgu 4 Replies Last reply Reply Quote 3
        @lemur I've seen these sensors and wondered if they're any good. I was curious if there is enough coverage for them to work so glad to see you'd tried and confirmed it.
        Happy to hear they work well, I picked up a set of those car seat sensors @ed_co once recommended to me.
        Have yet to work them into something but other people have tried these too and say they work great.
        I assume soldering those sensors was tricky being so close to the membrane?
          @lia I wanted to try the seat senors, but they looked a little wide, but I'll try them in the future.
          Soldering isn't a problem, just do it quickly.
          I have a XR footpad made with four 406 sensors and rode the last part of the year with no problems.
          I have a Pint footpad made up with only two sensors and that worked great too.
            @lemur My only issue with the seat sensor was the delay. Could only find them in China so took forever to show up.
            Nice to hear the Pint can work with just 2, locally those 406's cost like £10+ each.
              @lia I got the 406s from Aliexpress @ approx $5 cdn each, but they also took long time to arrive.
                @lemur oh god i want this. i hate the stock pads with a fierce burning passion.
                b0ardski 1 Reply Last reply Reply Quote 1
                  b0ardski @NotSure last edited by b0ardski
                  @notsure my passion may not be burning but after the cushy concave foot fatigue relief of fish bones under the rug I'll recreate it on Frankenboard.
                  this pic was 2500 mi ago, it don't look that good any more but it's still working.
                  carving turns all year round
                    Lemur @Lemur last edited by Lemur
                    I installed the Kush low with fsr 406 sensors on my XR and tested it out on a long ride. It performed flawlessly, no false starts or ghosting.
                    It did take me a while to get used to the concave, it would be great if they can incorporate a "love hump" in the Kush pad. I think there is a company that made that style than OW.
                    b0ardski 1 Reply Last reply Reply Quote 2
                      b0ardski @Lemur last edited by
                      @lemur said in Kush low as front footpad:
                      Did you make the toe hook?
                      landsurf platypus has the arch hump
                        Lemur @b0ardski last edited by Lemur
                        Yes , I made that out of 1/4" abs and doubles as a float plate.
                        The toe hook really helps me on the heelside turns, I snowboarded for all my life and you really need to be locked in for the heelside carve, turn or slide.
                        NotSure b0ardski 2 Replies Last reply Reply Quote 3
                          NotSure XR Pint @Lemur last edited by NotSure
                          @lemur @b0ardski i have an old kush hi that i replaced with the airpad. could i use it to make one too?
                            Lemur @NotSure last edited by
                            @notsure I went with the low because I wasn't sure if the sensors would conform to a deeper concave.
                            I think they might, I have a Kush Hi that I will try later.
                              @lemur cool! the bottom isn't waffled like urs is. that concave front looks awesome tho!
                              edit: nevermind. i dunno i thought the lo was waffled for some reason.
                                b0ardski @Lemur last edited by b0ardski
                                thats why I made a toe hook and use a flightfin for the back foot.
                                love the incorporated float plate
                                btw I had a Kemper bullet181 raceboard back in the day
                                  Sirgu XR @Lemur last edited by
                                  Interesting project @Lemur
                                  Eager on hearing from it how it goes in time being!
                                  BTW ppl ... recently mr. Matt Hoover (from Land-Surf) have hinted numerous times in variety of FB groups recently that hes been working on FRONT PLATYPUS ;)
                                    NotSure XR Pint @Sirgu last edited by
                                    @sirgu honestly its the sensor pad innovations that have me most interested. concave front foot pads sound really cool.
                                      Sirgu XR @NotSure last edited by
                                      @notsure Understood.
                                      As for myself .. aside the exitement on concaveness .. I do value the extra wideness that comes with Platypus. Although my feet are not that large (~10,5") dual platypus.jpg
                                      Lia M 2 Replies Last reply Reply Quote 2
                                        Lia GT XR Pint Plus V1 DIY @Sirgu last edited by
                                        @sirgu Ooo that green looks nice!
                                          MacIak DIY GT XR Plus last edited by
                                          Just an addition for the topic: Kush-lo+ pint sensor.
                                          Added diy CF plate as anti-ghosting and sturdy bottom plate, kush is kinda flexible;)
                                          Aka "Vommbat"
                                          NotSure 2 Replies Last reply Reply Quote 3
                                            NotSure XR Pint @MacIak last edited by
                                            @maciak said in Kush low as front footpad:
                                            diy CF plate
                                            printed or purchased?
                                            M 1 Reply Last reply Reply Quote 1
