    Fix stripped controller thread
    1624
    • Swinefeaster
      Swinefeaster last edited by Swinefeaster
      Anyone know how I can fix this? I tried to do the heli-coil thing but the bit doesn't thread well into the brass. Would muchly appreciate Amazon links or whatever to the parts I'll need :)
      • Samuraipunch
        Samuraipunch last edited by Samuraipunch
        I've replaced the inserts on a few controllers... You could see if you have something that will thread in and fit, and basically pull it out... Or try to drill it out. Basically try not to make the hole in the plastic bigger, or crack it is the big thing.
        Then when you have a new insert, I like to fill it (the hole around the insert) with a bit of epoxy/jb weld/etc, around the insert, and reassemble that portion of the board, so you can get screws to line up when everything's put back together. It's important to not use too much so that it doesn't over run, and glue the board together so you can't dissasemble it, and or get the screw out. But a little bit to hold it in place, let it cure, then go back and add more to fill it iin, works well too.
        Swinefeaster 1 Reply Last reply Reply Quote 3
        • Swinefeaster
          Swinefeaster @Samuraipunch last edited by
          @samuraipunch thanks
          i bought these
          https://www.amazon.com/dp/B09ZNWBBR3?psc=1&ref=ppx_yo2ov_dt_b_product_details
          and used epoxy
          but sadly the fucker started spinning once tightened.
          any suggestions?
          Samuraipunch Lia 2 Replies Last reply Reply Quote 2
          • Samuraipunch
            Samuraipunch @Swinefeaster last edited by
            @swinefeaster Is that a new insert? I use these. Pinch the end you insert into the controller a little, so when it cures a bit, and you screw in the screw all the way, it expands into the epoxy/plastic and stays snug.
            https://www.amazon.com/gp/product/B08P1T1FVP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
              Lia GT XR Pint Plus V1 DIY @Swinefeaster last edited by Lia
              @swinefeaster I need to do this repair on my Plus at some point. Will share if I find something that works really well.
              • Swinefeaster
                @samuraipunch yes that was a new insert. thanks for the link, will try those! any thoughts on type of glue to use?
                  Lemur @Swinefeaster last edited by Lemur
                  @swinefeaster Use a dremel and grind down two sides of the insert on the inside to the plastic and collapse the insert and remove the insert.
                  Then heat install new 10-32 inserts with a soldering gun , the new inserts are slightly larger than the originals and work perfectly.
                  I used a milling machine and a 1/4 inch bit to remove the stripped inserts . Photo is a box I got for free that was given up for dead and all six inserts were replaced.
                  https://www.ebay.com/itm/292804595649inserts.jpg
                  Swinefeaster 1 Reply Last reply Reply Quote 4
                  • Swinefeaster
                    Swinefeaster @Lemur last edited by
                    @lemur ok thanks so the inserts i got are also heat set inserts. in this case the hole is too big to just melt it in. what material should i fill it in with? some other plastic and then melt it again? or glue?
                      @swinefeaster I'm not sure about your inserts, but the ones I use are larger in diameter than the originals. Jb weld epoxy will work.
