    Owie chip standalone
    owie bms
    2192
      Anyone know if the Owie chip works only when a BMS is present or is it capable of entirely spoofing the data signal without needing a BMS to feed it?
      Been looking through the github for clues. As with JWFFM chip it takes the existing signal but I don't know if it just uses that for reading the battery voltage and nothing else.
      Any ideas? Kind of want to get the XPint project going again as I'm a bit deflated on the others at the moment.
      Samuraipunch L 2 Replies Last reply Reply Quote 1
      • Samuraipunch
        Samuraipunch @Lia last edited by
        @lia You'd want to hit up the ow discord (and ping Adoah) for answers on that to be sure. But I want to tentatively say it'd still be dependent on the BMS, as it's essentially a piggyback, and modifying the signal from the BMS.
          @lia Unfortunately, the Owie and JW chip only changes the bms signal to the controller, it cannot be used as a stand alone sub for a OW bms. I'm not sure what's happening with your XPint project, but the Owie can pair any Pint bms to any Pint controller. It works because I've tried it and have installed an Owie in my Pint controller box permanently.
            @lemur Assumed that might have been the case. I'll try pickup a BMS from somewhere at some point. I have an XR BMS still from Dax but I want to use that for the accompanying 4209 controller... when I get around to giving it a body >.>
            L 2 Replies Last reply Reply Quote 3
              @lia I tried an Xr bms with an Owie to try to pair to a Pint controller, but that doesn't work. Only same platform, Pint to Pint, XR to XR.
              I did reflash a 4208 bms to be a Pint bms and that works with an Owie. I've since reflashed that bms back to a 4208.
                @lia I finally got my hands on a friend's 4212 Xr with code 16, turned out to be a harness problem.
                Anyhow, I got to test Owie 1.3.0 which has the magic number "428448455" hard code for the bms number and it works to pair the 4212 controller to my 4208 bms.
                Thanks to "datboig" on discord for the hard work!
                https://github.com/lolwheel/Owie/releases/tag/v1.3.0
                  biell DIY Plus @Lemur last edited by
                  @lemur Oh Future Motion, you could have at least used "3735928559" for your magic code.
                    Lemur @biell last edited by
                    @biell Does it mean "unknown error code"?
                      @lemur "4289449455" is "0xFFABCDEF" in hexidecimal. Cute, but "3735928559" is "0xDEADBEEF" in hexidecimal. A value with a storied history.
                      NotSure 1 Reply Last reply Reply Quote 5
                        NotSure XR Pint @biell last edited by
                        @biell lmao
                        Swinefeaster 1 Reply Last reply Reply Quote 3
                        • Swinefeaster
                          Swinefeaster @NotSure last edited by
